Re: DancinFools Iron Man Mark III Pep File Development
Yep 90% done with the "filler" work I don't use Bondo, way to hard and time consuming. Watch out scaling different pieces at differently they will have trouble fitting together properly and look add at the end build. You should find a scale that works for your size and mod the pieces as you need them. Like take the curve out of the front of the shin or make the calf area larger but keeping the joining pieces correct to scale.
