Re: Fallout New Vegas: NCR Veteran Ranger
Big update!
First up,
a shot of some of the junk i thought may be useful for the 'details' of the helmet and mask.
(btw, i shared this costume on the bethesda official forums, Joshua Sawyer, the lead designer and project director of the fallout new vegas game gave me a fine compliment about it, so i've been extra motivated)
i decided to try out gluing my pep files directly onto plastic and bandsaw cutting them.. not a bad result in the end, but extra sanding required to removed the paper later.
i also began work on part of the right ear piece.
and used a heat gun to heat a strip of plastic against the ear, and helmet, to create a support for some extra insurance it doesnt break off.
and i've finished the left ear blub, which i don't seem to have a shot of right now.. it was half a clear Christmas bauble. (tis the season?)
i may add some holes into it do i don't get noise bouncing around as much inside the mask.
ive made a sort of headset cable that will come out from the right earset, and plus into the mask around the right lower cheek.
it's got a piece of metal tubing around a small part of it to make it look more "natural" and actually a piece of existing tech.
this is the makings of the larger camera on the side of the helmet.
the switch could potentially work, and there is a plastic lens in the front of the camera.. if someone were to give me some advice on how to rig a simple LED setup connected to this switch, then i could easily have a working light for it.
to go with the eyes.
i've taken a wireless network ariel and added a telescopic "thingy" to it, for the helmets ariel.
slapped some bondo on the camera to improve the design, will wait for it to cure and then trim it down to a nicer shape.
i'm a fan of striking the iron when it's hot, or rther, trimming the bondo when it's not yet hard.. with what you say? these handy tools.
see bondo gets slowly harder (like i'm waiting for over a half hour right now for it to set enough that i can trim away at it like clay) my choices are, trim now or sand alot more later..
speaking of bondo.. denting a fiberglass helmet liner is not possible.. i tested this by giving it a god few whacks with a ballpeen hammer with no effect.. other than my wife laughing at me..
so i took a knife to the area, and cut a hole, as well as taped it over for my plan..
i slapped a bunch of bondo into the hole, from the inside.
and then pushed the other side of the hole a little with my finger.
no idea if this will work, but hopefully it will make a good looking dent in the helmet.. i feel like a post apoc bobba fett..
now i've been planning on going for the colt single action route for my armaments.. but you know.. i've always liked the NCR flag..
why buy one though.. when you can buy two, and cut the head off one, to stitch to the other!
now, i need to add the lettering too.. i considered taking a few letters from the cut up flag, but i decided to use a test piece and see how well painters tape works on a flag, when you use that rubber paint plastidip spray.
no bleed whatsoever!
so lets use this knowledge for practical .. practice.
needs some dirt, and bullets holes, tattered edges and such.. but i really like this, and it was very fast and very easy to do.
i could easily make more.
