Hello all,
I need some urgent help ! :wacko
I am having some problems with the rotocasting process because of the resin. I use poliurethane resin (two components) at a 50% ratio.
If i make a normal piece (solid) without rotocasting, the resin result is perfect. The part that i am showing is small (like 2 inches by two inches)
The problem occurs when i rotocast. Then i get some spots, like sun burning. At the beggining i did not know that they were huge bubbles until i scratch them with a knife...
Here you can see that it is hollow. The spots/bubbles are everywhere !!
I have tried changing the mixture ratio, with less hardener... but nothing happens... :unsure
I have read in some forums about heating the silicone molds before using them... which i will try in a few minutes...
Has anybody had the same problem?
How did you solved it? :confused
Thanks guys!! :thumbsup
Alfredo
Alfredo
