griffey
Hello all!
I've been chosen to direct a local community theater production of Little Shop of Horrors, and we've no budget to rent professional puppets. Which means we build!
I've build a ton of props, but I've never specifically built puppets, much less 9 foot tall ones. I would love any and all advice on this front, keeping in mind significant budgetary limitations. We've got talent and time but little money.
There are 4 total puppets to be built. Pod 1 and Pod 2 are hand puppets, and are doable with foam and paint mostly. Pod 3 is typically done as a "wearable" upper body puppet where the lower jaw is an arm and the upper jaw of the pod is the upper body and arm of the puppeteer. Pod 4 is the big boy, and has to be large enough for actors to be "eaten" by it live onstage...so we're talking a minimum of 4 feet wide, and 7-9 feet tall depending. This one has a few different build styles that fall into two general camps: either a very large wearable that uses a backpack and aluminum struts to support the top jaw, while the bottom jaw is actuated by the puppeteer with their arms OR a central support of some sort that the puppet rests upon, and the puppeteer controls the puppet with levers.
For the largest pods, I'm considering using half-inch PVC as the skeleton, over which we attach as cheap a foam layer as I can find, and then spray glue fabric over the foam which is then painted via airbrush. I'm worried about both heat and weight, although we can mediate both in different ways.
I would love ANY advice at all. Is PVC pipe entirely wrong for this? Would some form of bent aluminum be better? What sort of foam should I use, or should I find another material (plastic door screen?) to cover the skeleton? Hinges? Best source online for large fabric orders? Help!
