Page 1 of 5 12345 LastLast
  1. Formerly Kylash327 Dr Talyn's Avatar
    Join Date
    Jul 2002
    Message Count
    7,411
    Mar 25, 2006 - #1
    Ive had one of these for about 2 weeks, picked it up at the register at Walgreens cause it openned up all cool and unfolds itself. It's a pocket sized book light for $2.99. Just went and finally saw V For Vendetta today and saw they used it as a prop! It's the scrambler that the police and V use to scramble wiretaps when theyre talking about sensetive stuff to make sure no one is listening. It appears all they did was maybepaint some areas black and change the bright white LED to a red one.
  2. dr_slurpee's Avatar
    Join Date
    Oct 2003
    Location
    Ontario, Canada
    Message Count
    1,861
    Mar 25, 2006 - #2
    Cool find! Does anyone have any screen grabs of it in the film? Just in case there are more than one model of these?
    Any chance you could get more Kylash?
  3. Formerly Kylash327 Dr Talyn's Avatar
    Join Date
    Jul 2002
    Message Count
    7,411
    Mar 25, 2006 - #3
    i could definetly get more Screencaps would be great though!
  4. nickytea's Avatar
    Join Date
    Nov 2001
    Location
    Southern California
    Message Count
    3,326
    Mar 25, 2006 - #4
    They also shortened the body length in half, and yes, it does appear to be painted a darked gray/bronzish color.(except for the crome top piece.
    Ive been having the darndest time finding caps...no surpise, its only shown twice, maybe three times in the pic.
  5. Warlord of Barsoom SurferGeek's Avatar
    Join Date
    Feb 2002
    Location
    Helium of Mars
    Message Count
    5,869
    Mar 25, 2006 - #5
    I've seen those at Brookstone as well, although I don't remember the price.
  6. What is a plethora, Jefe? hydin's Avatar
    Join Date
    Jan 2001
    Location
    La
    Message Count
    19,999
    Mar 25, 2006 - #6
    im heading to the store later on tonight to get some shopping done. whats the brand name on these and ill see if my local one carries em as well.
    thanks!
    chris
  7. Formerly Kylash327 Dr Talyn's Avatar
    Join Date
    Jul 2002
    Message Count
    7,411
    Mar 25, 2006 - #7
    no brand name or copyright, they were just in a box near the register at Walgreens
  8. I Need a Hug Mike J.'s Avatar
    Join Date
    Aug 1999
    Location
    St. Petersburg, FL
    Message Count
    6,214
    Mar 26, 2006 - #8
    Don't ask, don't tell
    -Mike
  9. dr_slurpee's Avatar
    Join Date
    Oct 2003
    Location
    Ontario, Canada
    Message Count
    1,861
    Mar 26, 2006 - #9
    Well to me it looks like that's the right light. Another cheap prop.
  10. Adar Tallon's Avatar
    Join Date
    Aug 2000
    Location
    Maryland
    Message Count
    4,049
    Mar 26, 2006 - #10
    [snapback]1213356[/snapback]
    Yeah I saw them there too. Thought they were more expensive than just $4 that's for sure.
  11. RPF Premium Member JediCarl's Avatar
    Join Date
    Apr 2005
    Location
    Atlanta, GA
    Message Count
    560
    Mar 26, 2006 - #11
    I just remembered that I got 2 of these in my stocking this past Christmas!
    Time to do some screen-accurate conversions.
  12. CriticalMass's Avatar
    Join Date
    Oct 1999
    Location
    New Orleans, LA
    Message Count
    416
    Mar 26, 2006 - #12
    Nice find Kylash!
    Time to hit up the local walgreens
  13. Funky Jedi's Avatar
    Join Date
    Jun 2000
    Location
    Tulsa Okie-dokie
    Message Count
    11,687
    Mar 26, 2006 - #13
    Has anyone taken one of these apart yet to see if the guts will be interefered with by cutting it in half?
  14. Formerly Kylash327 Dr Talyn's Avatar
    Join Date
    Jul 2002
    Message Count
    7,411
    Mar 26, 2006 - #14
    eeeeeeeeek.....that bottom half they cut off....thats where the 3 batteries are ^^; and i am not good with electronics.
  15. Funky Jedi's Avatar
    Join Date
    Jun 2000
    Location
    Tulsa Okie-dokie
    Message Count
    11,687
    Mar 26, 2006 - #15
    Crap...I was afraid of that!
  16. dr_slurpee's Avatar
    Join Date
    Oct 2003
    Location
    Ontario, Canada
    Message Count
    1,861
    Mar 26, 2006 - #16
    I actually was thinking that was the battery area. I imagine it would be quite easy to fit a coin cell in there to run it...problem is that unless you get really good ones they wouldn't last as long.
  17. Join Date
    Jun 2005
    Location
    Somewhere between Middle Earth and the Batcave, with a great view of the Deathstar
    Message Count
    322
    Mar 26, 2006 - #17
    Just got one, and does anyone think that it would be possible to just move the battery case part into the upper half that they left?
    Also, the spring action in the movie was not slowed down like the model I have. Is there any way to get rid of that?
    EDIT: Just took a look at the guts, and I realized that it's impossible to move the batteries to the upper half. Any other ideas?
  18. Funky Jedi's Avatar
    Join Date
    Jun 2000
    Location
    Tulsa Okie-dokie
    Message Count
    11,687
    Mar 26, 2006 - #18
    If the battery DOES have to be replaced to a small coin battery, the bulb should be removed and replaced by a smal red LED as it draws less power.
  19. Join Date
    Jun 2005
    Location
    Message Count
    322
    Mar 26, 2006 - #19
    Well, I got the movement down. It seems that the spring-loaded joints were just filled with some wierd waxy glue. All you need to do is take it apart, remove the springs, and treat each individual joint piece with a thinning agent (I used some stuff called "Goo Gone"). Then, just reassemble, and you've got fater joints.
  20. Banned
    Join Date
    May 2005
    Location
    Los Banos California
    Message Count
    1,509
    Mar 26, 2006 - #20
    it looks taller to me...which leads me to believe that when they removed the excess battery compartment that they just put the battery area on the bottom of the prop making it a bit taller.
  21. Join Date
    Jun 2005
    Location
    Message Count
    322
    Mar 26, 2006 - #21
    I was actually thinking the same thing. Now, the real question is how do you make a completely new bottom piece to fit onto this?
  22. Formerly Kylash327 Dr Talyn's Avatar
    Join Date
    Jul 2002
    Message Count
    7,411
    Mar 27, 2006 - #22
    or they just made it not unfold as much, which makes it taller to stand straight.
  23. Join Date
    Jun 2005
    Location
    Message Count
    322
    Mar 27, 2006 - #23
    I think he means that the base seems kinda thicker. Maybe I'm wrong, though.
  24. Formerly Kylash327 Dr Talyn's Avatar
    Join Date
    Jul 2002
    Message Count
    7,411
    Mar 27, 2006 - #24
    oh..hmm, no i dont think so...its about that thick, but thats just me..
  25. Join Date
    Jun 2005
    Location
    Message Count
    322
    Mar 27, 2006 - #25
    Well, if it really is that thick, then there is the problem of somehow encasing the batteries in the half that they left.
Similar Threads
  1. Spinal Tap
    ob1al, Entertainment and Movie Talk
    Last Post: Sep 21, 2012, 5:09 PM
  2. Replies: 3
    Last Post: Mar 3, 2008, 9:40 AM
  3. V for Vandeta Scrambler
    kdawg1, Replica Movie Props
    Last Post: Jun 3, 2006, 12:30 PM
1 2 3 4 5 6 7 8 9 10 11
