1. saxe coburg's Avatar
    Join Date
    Jan 2004
    Location
    Knoxville TENN.
    Message Count
    637
    Sep 28, 2008 - Too thick silicone... help #1
    Hey guys, here’s my situation…I’ve got a couple of gallons of RTV silicone that has been sitting in the shop for several months. Yeah, I got busy with other things and completely forgot about using it. The silicone still seems to be “good” but has thickened just slightly. I degassed some earlier today and it is still usable but just a little too thick to just pour.
    So with that said, is there anything I can use to thin the silicone to make more flowable?
    Thanks in advance for your time.
  2. JtotheP's Avatar
    Join Date
    Jun 2008
    Location
    Apopka, FL
    Message Count
    345
    Sep 28, 2008 - Re: Too thick silicone... help #2
    Yes there are thinning agents that I've seen Smooth On makes. Reynolds advanced materials carries Smooth On products or you can go straight to Smooth On directly. For some molds the thicker silicone can be an advantage unless you are pooring it in a case mold. It may be ideal if you are layering your silicone after each layer kicks.
  3. zorg's Avatar
    Join Date
    Jul 2002
    Location
    Scotland
    Message Count
    3,771
    Sep 28, 2008 - Re: Too thick silicone... help #3
    dont know about the thinning agents?
    but if i were you i would get some new silicone and use that as your initial coats on whatever your molding then bulk it out with this thicker stuff.
    z
  4. gobler's Avatar
    Join Date
    Mar 2002
    Location
    Peoples Republic of Khalifornia
    Message Count
    1,229
    Sep 28, 2008 - Re: Too thick silicone... help #4
    Add a very small amount of silicone oil. most silicones have a shelf life of at least six months (depending on temp)
    Cheers,
    Jeff
  5. fettster's Avatar
    Join Date
    Dec 2005
    Location
    Solihull, West Midlands
    Message Count
    2,200
    Sep 28, 2008 - Re: Too thick silicone... help #5
    you can also use lighter fluid
Similar Threads
  1. Need help with cutting something thick
    juntari, Replica Movie Props
    Last Post: Jun 9, 2012, 7:16 PM
  2. Mask building: Thick or thin?
    TheAtomicSoul, Replica Movie Costumes
    Last Post: Feb 2, 2012, 11:08 PM
  3. How do you get a thick seam out of latex?
    Funky Jedi, Replica Movie Props
    Last Post: Sep 20, 2011, 2:42 PM
  4. Replies: 12
    Last Post: Sep 19, 2011, 2:18 PM
1 2 3 4 5 6 7 8 9 10 11
