the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > PROPS > Replica Movie Props
"Terra Nova" prop gun build
Discussion on "Terra Nova" prop gun build within the Replica Movie Props forum, part of the PROPS category; Day 2... Measure the size of the join point for
Reply
LinkBack Thread Tools
Old 10-19-2011, 10:53 PM   #26
Jonny B's Avatar
Jonny B has a reputation level greater than 10!
Re: "Terra Nova" prop gun build
Day 2...
Measure the size of the join point for the Stocks ~arm~.
Cut off the piece you need, compair to the pictures and you'll get a good idea on the size the arm is.
From here it's a choice: If this is just a display piece, make the arm dead on accurate, If you're like me and this is going to be carried at Con's as part of a costume, make it a bit more beefy like I did. Yes, Mine it 1/4" thicker then the one in the photos from the show. I DID make the accurate one...twice, and both broke.
This round part, at the end of the Recon, is what I attached the stock to.
I ripped a 2x4 to the corect size, making it a lot longer then I knew I really needed.
Then drilled the mounting hole that will attach it to the rifle.
Test fit to be SURE it aligns corectly. If the mounting hole is off, it'll be way out of alignment and not look right.
distance I used was 3/4", cut TWICE with a 1/8" saw blade, then measure again 3/4", repete...
Fit onto prop for compairison, then dremel the cuts to soften the sharp edges.
Jonny B is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 10-19-2011, 11:20 PM   #27
Jonny B's Avatar
Now for the shoulder piece...
Cut and sand the bottom...
Sand off the round piece...
Top section is at the wrong angle so you have to cut it off, then re-attach it...
Dremel the piece so it fits togeather corectly...
Fill the piece with fiberglass, NOT bondo, you'll be drilling and tapping into it so you'll need the tougher material...
Rough sand all the joins flush...
Next we make two pieces for the sides. I used 1/16" clear acrilic.
Shaped to fit, gorilla glued on...
next!...
Old 10-19-2011, 11:28 PM   #28
Jonny B's Avatar
Cut out templates for the pieces that mount to the sides...
Sand both togeather so they're exactly the same size...
while still togeather, drill and then counter sink the holes...
Fitment done, sanded, painted, check how it looks...
next....soon as the images upload to imageshack :P
Old 10-19-2011, 11:49 PM   #29
Jonny B's Avatar
The, uh..."Top Scope thingy"...
Disassemble the two lites from the Recons.
Of course they don't just get glued togeather, that would have been easy. They both need to be cut as shown to line up corectly.
Line up and glue, then cut the front and rear. NOTE!!! there IS a left/right side to this piece, make sure you check the original prop pictures so you get these cuts right!!!!
Fill the piece with fiberglass, rough sand it to corect shape. Next the holes need to be drilled. I used a drill press with a piece of wood bolted down so the line of holes was absolutly dead on in line. Do the same with the smaller holes.
The trigger guard has a little nubby on it, cut or sand it off, also remove the clip release buttons for the Nerf Dart Clip. Fill both and rough sand to shape.
Using the second Nerf guns stock, cut as shown in the picture, also remove the round piece on the main body. This is where the lower hand-hold attaches.
Mark where the pieces will join, this makes ligning them up when gluing them SO much more easy.
Me loves Gorilla Glue
NEXT!...
Old 10-20-2011, 12:10 AM   #30
Jonny B's Avatar
Recon #2...
Sad that this is all you use, it gets choped up a LOT. NOTE!! look at the next picture, you need to save that front piece with the rounded part on it!!
Cut to fit. The piece with the RED lines an it shows where that needs to be cut as well. That piece is joiined to the underside of the front, under the barrel.
Here's where that piece goes, make sure it's a good fit and will hold well. This part suports the flashlite you'll get to later.
Short Strand Fliberglass, NOT BONDO!
While thats setting up, finish the lower hand hold...
Fun time...glue Recon #1 to #2. Yeah, this part is critical, if not aligned right it'll ruin the look or the gun. Me, I made a jig out of some wood so the 2 pieces fit togeather perfectly and then glued them. The scope site is just sitting the NOT attached yet...
Cut out this section in the side...
Make the pieces to fit there, but don't glue them in yet...
Dremel the hole for the flashlight, make a bracket to hold it inside the body, THEN glue everything down and fill the edges with fiberglass..
next....
Old 10-20-2011, 12:31 AM   #31
Jonny B's Avatar
Now for the little finishing pieces...There's 2 on Nerf #1 and 4 for Nerf #2. If someone is seriously doing the build and needs a template for these I could maybe make one for download.
Just a trick but you might not know it...Lining up pieces it easyer with a guide. Tape holds it and then everything is corect in relation to the other pieces...
The clip feed is made of some 1/4" thick acrilic, angle is 14.5 degrees.
Now, as I said I think, my stock is a tad beefyer then the show props, this is how I joined the but plate to the arm. dowl rod, glued and then fiberglassed in place.
Scope is glued down, glazzing putty in all those nasty little pin holes, the entire prop is given a final sand with 800
Ta Da! Here's my Dad...ready to hunt Dino's!
So much for "it's just a cupple of Nerf guns glued togeather" !!!!!
Honestly, I have no idea why they put so much work into a prop....that's a Nerf gun. To me, it would have been so much more simple to just make something from scratch that no one has seen before.
Still, it makes it cool for us who want stuff like this!
If there's any questions, feel free to ask.
Old 10-20-2011, 01:52 AM   #32
kevinericon's Avatar
kevinericon has a reputation level greater than 10!
YEAH! Great job! It doesn't really look like prop "replica", it's like watching prop master preparing for a show!
I can accept modded Nerf for a show, just not blatant repainted toy! I guess they had to use some cheaper toys because too many people are carrying a rifle, now that so many sixers showed up.
kevinericon is offline   Reply With Quote
Old 10-20-2011, 02:10 AM   #33
Bowelrock's Avatar
Bowelrock has a reputation level greater than 10!
Your Props
Smaller pictures!!!!!!!!!!!!
Bowelrock is online now   Reply With Quote
Old 10-20-2011, 04:29 AM   #34
Jonny B's Avatar
Quote:
Haven't got the hang of the Forum yet. If someone would exlpain a bit on posting pictures? We have quite a few builds going on and would really like to post them.
Old 10-20-2011, 07:33 AM   #35
Panzer's Avatar
Panzer has not been awarded enough reputation to matter.
I have a new appreciation for the prop makers for the show now, that's a lot of work! Great job emulating it.
Panzer is offline   Reply With Quote
Old 10-20-2011, 05:33 PM   #36
I'm a pixel pusher
Mike J.'s Avatar
Mike J. has a reputation level greater than 50!
... G*d ... d*mn ...
That's a hell of a lot of very clean work to make a very nice replica.
What I previously considered rather lightly altered and repainted Frankenstein Nerf guns are clearly something more.
Congratulations! Great job!
-MJ
Mike J. is offline   Reply With Quote
Old 10-20-2011, 06:01 PM   #37
sean's Avatar
sean has a reputation level greater than 10!
Nice work on that rifle.were can I find a picture of the TV one?
sean is offline   Reply With Quote
Old 10-21-2011, 03:04 PM   #38
Jonny B's Avatar
Quote:
Here ya go, one of the ref pictures I used. I liked it because it was shot outside in actual daylight.
Old 10-21-2011, 03:17 PM   #39
Hirohawa's Avatar
Hirohawa has not been awarded enough reputation to matter.
Quote:
Originally Posted by kevinericon View Post
I'm all for the using modded toys for futuristic look. But a rifle prop with $25 toy and a can of spray paint is just lazy.
Yup!
It's laughable that they are probably spending $2 million an episode and using such a well known toy as their main source for weapons.
Amazing build to the OP. Great work.
Hirohawa is offline   Reply With Quote
Old 10-21-2011, 07:20 PM   #40
sean's Avatar
thanks for the pic....you guys did a fantastic job on this...........
Old 10-22-2011, 04:14 AM   #41
MandalShArK has not been awarded enough reputation to matter.
Superb work sir!, and Thanks for the Detailed shots!
Goes to show the TN crew can create something from scratch, and this brings an end to me scratching my head at whats what on the rifle.!
MandalShArK is offline   Reply With Quote
Old 12-14-2011, 05:19 AM   #42
DmsdyMachn's Avatar
DmsdyMachn has not been awarded enough reputation to matter.
Amazing build. PM on the way.
DmsdyMachn is offline   Reply With Quote
Old 12-14-2011, 05:34 AM   #43
DmsdyMachn's Avatar
Quote:
Okay, tried to PM, but not sure it it went through. Let me know, please.
Old 12-14-2011, 02:45 PM   #44
checkM8alice has not been awarded enough reputation to matter.
Looks great.
checkM8alice is offline   Reply With Quote
Old 01-17-2012, 05:31 PM   #45
Roughneckone's Avatar
Roughneckone has not been awarded enough reputation to matter.
Awesome build and tutorial, thanks very much for taking the time to do this, definitely going to have a try at this build myself.
One question I have to ask though is that I've looked all through the Tut but can't see any mention of the top magazine slot surround build (acrylic in the pics by the look of it), did I miss the construction of that or was it just never mentioned?
Thanks
Roughneckone
Roughneckone is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Terra Nova? blip Entertainment and Movie Forum 315 03-18-2012 01:31 AM
Terra Nova: Pistol Build Tutorial Jonny B Replica Movie Props 123 02-15-2012 06:36 AM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
