Page 1 of 2 12 LastLast
  1. Join Date
    Feb 2011
    Location
    Alamo, Texas, United States
    Message Count
    34
    Mar 1, 2011 - Spiral spring - Hidden blade #1
    I've seen many designs for Assassin's Creed hidden blade design, and I think they are all great, but my one peeve was that none of them were truly retractable. They only extended by a coil spring or force, and were pushed back in. I've come up with a design I wanted to test out but have no idea where to find or how to make, a spiral spring, AKA clockwork spring.
    The spring is the key to the design and only needs winding once in a while to operate.
    It's not the best looking picture I know and it's definitely not to scale but I hope you can make sense of it. The string pulls the bell crank, which allows the snail cam to spin out half a turn to extend, and then again to retract. For safety reasons I didn't make it definitively locking on the opposite side of the cam but another bell crank like mechanism could make it so.
    The spiral spring will be attached to the underside of the cam and will keep the force on the cam, which can be wound with the key.
    I know it's rough but I wanted to know any improvements on my design that anyone may have and if anyone knows how to make a spiral spring. What thickness of metal and type of metal do I use? Do I just wind it around something or do I have to heat it so when it cools it will keep it's shape? Can I just take apart a tape measure?
    I don't honestly think It will only need two scissor mechanisms to extend properly but this is just a representation.
    Any questions, comments, concerns, and feedback is greatly welcome.
    Thank you all very much.
  2. Ruskin's Avatar
    Join Date
    Feb 2011
    Location
    Port Elizabeth, South Africa
    Message Count
    29
    Mar 1, 2011 - Re: Spiral spring - Hidden blade #2
    Hey there,
    I'm also working on a retractable hidden blade that wrist flicks out - for me the problem has always been getting it back in and not out, so I'm not too worried if it doesn't shoot out.
    I think your best best for clockwork springs are watchmakers, but the kind who assemble grandfather clocks and so on. Check the pic below for the spring that I have!
  3. Ruskin's Avatar
    Join Date
    Feb 2011
    Location
    Message Count
    29
    Mar 1, 2011 - Re: Spiral spring - Hidden blade #3
    I'm farmiliar with the system you're going to use to build yours, but I must confess that I don't like the scissor jack system myself - I'm interested to see your progress on this though
  4. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 2, 2011 - Re: Spiral spring - Hidden blade #4
    Thanks for the advice on where to find the spring.
    Yeah I had thoughts of the scissor jack too, not sure how far I can extend it and keep everything at the length it should be at. Any recommendation of what I should use? I'm not a fan of the drawer slider though, only seems to lend it self to sliding things out not back in, but I'll work on that when I have time tonight.
    I like how yours is looking, may I ask how you are building yours?
  5. Who's your Paddy? youngpaddy1's Avatar
    Join Date
    Dec 2010
    Message Count
    378
    Mar 2, 2011 - Re: Spiral spring - Hidden blade #5
    personally I'd have gone with a 'centrifugal' style of deployment (just throw it out like a gravity knife) you'd need some way to lock them when out and a loose spring to pull the blades back in when you unlock, but it would stop your problems with overly complex mechanisms.
    cheerio
  6. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 2, 2011 - Re: Spiral spring - Hidden blade #6
    youngpaddy1 said: View Post
    cheerio
    Well my only complexity for me (at the moment anyway) is the spring, if it's strong enough and etc.
    But that's not too bad of an Idea, I could think up a few ways to do that. The problem I think would be that it could come out if I were to run or is someone bumped into me, It wouldn't be sharpened but it does still have a point. And if I did make a locking mechanism to keep it in, I would need the ring or something similar to allow it to open so it wouldn't be too bad. I'll look into it, Thanks for the thought.
  7. Join Date
    Dec 2007
    Message Count
    30
    Mar 2, 2011 - Re: Spiral spring - Hidden blade #7
    Idle,
    Very interesting idea! For the spring, why not disassemble a wind-up alarm clock or kitchen timer? There are some smallish ones that should have a useable spring along with other parts that might come in handy...
    Mark in Okinawa
  8. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 2, 2011 - Re: Spiral spring - Hidden blade #8
    FlyingDachshund said: View Post
    Idle,
    Mark in Okinawa
    THAT.... is an excellent Idea! wow that would save me a lot of searching online and around town. Thanks a lot for that Idea
    Now I just need to hit up the flea market and downtown this weekend.
    In the mean time does anyone have a better suggestion to scissor jacks while staying true to my design? I was thinking something LIKE a drawer slide but I'd rather make it from scratch or mod an extending tai chi practice sword so it isn't as bulky. The only thing I could come up with is a pulley system
  9. Ruskin's Avatar
    Join Date
    Feb 2011
    Location
    Message Count
    29
    Mar 2, 2011 - Re: Spiral spring - Hidden blade #9
    That is a good idea, now that you mention it, you could also take apart a tape measure, but you may need to trim the height of the spring.
    I'm building mine, using a combination of straight spring, coil spring and a flywheel with inertia out deployment. I'll try do some rough sketches tonight - my design is purely theorectical and may not work, but I won't know until it's built!
    I am using a type of slide, but not a draw slide. Basically it's a track mounted on each side of the casing. and the sliding sections have bars which fit into the tracks.
  10. Join Date
    Dec 2007
    Message Count
    30
    Mar 2, 2011 - Re: Spiral spring - Hidden blade #10
    Idle,
    To replace the scissor jack you might consider a rack-and-pinion gear setup like this. The cam spins the pinion, and the rack is affixed to the part that holds the blade. You can play aound with gear ratios to get the amount of extension you want.
    Mark in Okinawa
  11. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 2, 2011 - Re: Spiral spring - Hidden blade #11
    Ruskin: I like that sound of what your doing, hope I get to see it.
    FlyingDachshund: That sounded really good.. till I started drawing it out. to get the blade to extend the full amount the back end of the rack would stick out when closed... Unless I got a plastic one that curves around the inside... like one used in those toy tops! .... I'll have to work on this. Thanks for another idea!.. I hope it's strong enough, this may end up making things more complicated.
    EDIT: wait... the cam spins in the same direction. If I pull it twice it will just push the blade out farther. unless I use the ring pull system to pull the blade out and the spring to push it back in. In which case I could just use a regular spring instead of a coil spring but uhh... I dont think I can pull or twist my hand/wrist far enough to extend the blade all the way out.
  12. Join Date
    Dec 2007
    Message Count
    30
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #12
    Good point, I hadn't considered that...
    Mark in Okinawa
  13. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #13
    Yeah it kinda hit me too
    Does anyone know if there is any real reason not to use scissor jacks? What's bad about them?
  14. Ruskin's Avatar
    Join Date
    Feb 2011
    Location
    Message Count
    29
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #14
    This is the problem with the 3 part blade, getting it all the way out. I've seen plenty of stock and blade designs ( 2 part ) which are fine, but don't extend very far unless the housing goes back past your elbow to fit the blade in!
    My design will have a decent closed length and the blade will extend just past my outstreched fingers - whether the mechanism will work properly still remains to be seen!
  15. Ruskin's Avatar
    Join Date
    Feb 2011
    Location
    Message Count
    29
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #15
    Yeah... the scissor jack thing... to me it seems like alot of work. Remember that in the closed state, the width of the pieces can't be wider than the blade itself. This in turn means that you have to have thin pieces and that you will need much more of them to get the blade out to where you want it. All this will need to be handled by the coil spring and it may come out a little slower than you'de like. That being said, you'de also have to have exact timing to release the bell crank section, because if the second stopper on the crank misses it, it will simply go back in again, which could be a bit anti-climatic!
  16. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #16
    yeah those are the same problems I figured :\ if at the very least it could be a spring assisted modle. If it doesn't come out fully, a little jerk and it will. A flick of my finger or lifting my arm up could help get it back in, but it will lose a lot of it's "pizazz."
    I think my best bet is to wind it up tightly or make sure I get a good strong spring.
  17. Join Date
    Dec 2007
    Message Count
    30
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #17
    Idle,
    Giving the rack and pinion further thought, you could still use it if you attached the rack to the cam and used it to drive a small gear. I'm envisioning a system where you use a double gear and you drive it with the rack attached to the cam, with the larger diameter gear driving another rack attached to your blade. This would allow you to amplify the movement of the cam using the gears, getting you more extension than you would get if you just pushed the blade out with a piston attached to the cam...
    Mark in Okinawa
  18. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #18
    took me like 3 reads to understand it but I like it! getting full extension is a big deal but.. there's still the problem of retracting. I might make this as a second hidden blade anyway just because of the extension.
  19. Join Date
    Dec 2007
    Message Count
    30
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #19
    Actually, retracting is allowed for - I wish I could do a quick diagram but imagine one end of one rack attached to a point on the cam so it oscilates back and forth when the cam turns like this. This advances and retracts the rack, making the gear travel in either direction and thus extending or retracting the blade attached to the second rack.
    Mark in Okinawa
  20. Formerly cobalt crimson Wes R's Avatar
    Join Date
    Jan 2010
    Location
    Western PA
    Message Count
    8,089
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #20
    This could be handy for a zip gun for a gun prop so it slides into your palm
  21. Join Date
    Dec 2007
    Message Count
    30
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #21
    Wes,
    That was my thought as well, and the clockwork askpect of it gives it a cool steampunk vibe. I'd been looking for a way to do this but Idle's clock-spring approach hadn't occured to me, so I'm glad he posted about it!
    Mark in Okinawa
  22. mbwelder's Avatar
    Join Date
    Jan 2011
    Location
    Prince George, BC
    Message Count
    5
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #22
    I would be worried about the legality of a spring loaded wrist blade myself!
  23. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #23
    Flying,
    I thought about what you were trying to explain for 10 minutes but I finally got it hahah. I was stuck on there being only one rack and the cam being the gear. now I see that the cam has a piston that is actually a rack, turning a small pinion that has a larger pinion on top of it pushing the rack that has the blade attached to it. And you're right that would definitely work!
    Now I need to hit up the flea-market and dollar stores for parts.
    Oh, since your interested in the steampunk aspect of it. you could probably make this so the spring is on the outside part of the device, not against your forearm, with a plexiglass window to see the spring operating. definitely would give it some flair.
    and I dont know if this will help you or anyone else but I found this on deviantart by a man named Kudrik.
    Hidden Blade by ~Kudrik on deviantART
    It is a housing for the hidden blade and he includes a tutorial for how he made it here
    hidden blade blueprint by ~Kudrik on deviantART
    and here
    hidden blade blueprint part 2 by ~Kudrik on deviantART
    I don't know if you know how to work with metal but I'm not that great. So I thought this was good help for starting out.
  24. Join Date
    Feb 2011
    Location
    Message Count
    34
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #24
    mbwelder said: View Post
    Well any spring loaded knife isn't allowed where I live, only spring assisted. As well as any personal carried knife over 4 inches I believe. So this with an actual blade would be illegal, but I plan on just having a prop knife for safety.
    But if you plan on making and using this as a weapon I think legality would be the least of your worries.
  25. Ruskin's Avatar
    Join Date
    Feb 2011
    Location
    Message Count
    29
    Mar 3, 2011 - Re: Spiral spring - Hidden blade #25
    You can find the video for Kudrik's blade here -
    YouTube - Hidden blade
Similar Threads
  1. hidden blade
    emufire, Replica Movie Props
    Last Post: Dec 27, 2012, 6:03 PM
  2. Original AC Hidden Blade
    Ruskin, Replica Movie Costumes
    Last Post: Jun 4, 2012, 6:33 PM
  3. Hidden Blade's
    HeraldofNurgle, Replica Movie Props
    Last Post: Jul 19, 2011, 10:11 AM
  4. hidden blade help
    lukel4, Replica Movie Props
    Last Post: Feb 11, 2011, 8:32 PM
  5. Assassin΄s Creed: Hidden Blade - Need help
    ToNIC, Replica Movie Props
    Last Post: Mar 2, 2010, 7:48 AM
1 2 3 4 5 6 7 8 9 10 11
