1. Werstrooper's Avatar
    Join Date
    Nov 2009
    Location
    Australia NSW
    Message Count
    340
    May 8, 2012 - Some help with molding an original Sterling part #1
    Hey gang
    I'm currently molding E-11 parts to do a run of blasters for the local garrison. I have an ok understanding of single pour molds aswell as split molds but I'm a little stuck with the end cap, the one with the 'D' ring.
    How would you suggest I mold it, It basically needs to be a direct copy, so no solid center, needs to fit over the pipe I'm using.
    I'm sure there's a simple explanation but right now I'm a little lost.
  2. Werstrooper's Avatar
    Join Date
    Nov 2009
    Location
    Australia NSW
    Message Count
    340
    May 8, 2012 - Re: Some help with molding an original Sterling part #2
    Werstrooper said: View Post
    Turns out there is!
    Don't know why I didn't think of it in the first place lol
  3. pew pew Kevin Gossett's Avatar
    Join Date
    Jul 2011
    Location
    North Texas
    Message Count
    1,988
    May 8, 2012 - Re: Some help with molding an original Sterling part #3
    Perhaps you'd like to share with the rest of the class, in case someone else has the same question
  4. robstyle's Avatar
    Join Date
    Oct 2001
    Location
    SoCal
    Message Count
    12,114
    May 8, 2012 - Re: Some help with molding an original Sterling part #4
    remove the D ring, clay in the void and drill it out of the pulled part. If your sneaky you can elevate the master to get the proper lip around it and save some clean up work.
  5. Werstrooper's Avatar
    Join Date
    Nov 2009
    Location
    Australia NSW
    Message Count
    340
    May 9, 2012 - Re: Some help with molding an original Sterling part #5
    Ok I decided to try for molding it with the D ring on.
    I slightly filled in the areas around the D ring so it doesnt get molded in.
    I have used clay to make a split mold inside a large tube as the wall structure of the mold.
    Then mounted a clay pour line ontop of the small rectangle piece the D ring mount in.
    Will get some pics up soon
Similar Threads
  1. Replies: 8
    Last Post: Jan 22, 2013, 2:01 PM
  2. Sterling part kit question
    cboath, Replica Movie Props
    Last Post: Jan 28, 2011, 6:33 AM
  3. Looking for a Sterling part
    SaberFreak, Replica Movie Props
    Last Post: Jan 15, 2011, 3:39 PM
  4. Original Sterling parts build.
    giric thren, Replica Movie Props
    Last Post: Oct 11, 2010, 2:45 PM
  5. Replies: 18
    Last Post: Apr 19, 2010, 2:27 AM
1 2 3 4 5 6 7 8 9 10 11
