1. andy19422's Avatar
    Join Date
    Jan 2009
    Message Count
    282
    Mar 4, 2012 - SGU Destiny wall light sconce WIP #1
    I managed to buy a Destiny wall light sconce cheaply from a member here and decided to have a go at making some vacuum formed replicas. Originals have made over $800 This is my first project so I was going to get these professionally vacuum formed but decided to build my own former instead. I used Smooth-On Rebound 25 for the mold then Plasti-paste for the support and Task-18 for the resin. Unfortunately the resin was too heavy for the shell and when I went to demold it I found the cast was bowed I then decided to use plaster, 25 kilos of the stuff in fact. I thought it would be easier to get the pour level if the mold was the size of a huge brick.
    By andy19422 at 2012-03-04
    I used Polycraft SG2000 liquid plastic this time, the casts came out really nice. While I was making the mold I was also building a vacuum former after looking at the X robots video on you tube. After the first pull I realised the plastic wasn't getting pulled in to the recesses enough so I made another cast but this had a core of pink foam which I removed when the cast was set. This made the cast hollow so that I could drill holes in the recessed areas of the mold so that the plastic would be pulled down.
    I was hoping to make these in one piece but the painting would have been a nightmare and I wasn't happy about what it looked like so I made an inner shell by lining the mold with clay 2mm thick except for the lighted areas. This is the cast you can see in the first photo just taken from the mold.
  2. andy19422's Avatar
    Join Date
    Jan 2009
    Message Count
    282
    Mar 4, 2012 - Re: SGU Destiny wall light sconce WIP #2
    This is a pic of the outer shell trimmed with a coat of black plastic primer with the inner next to it.
    and put together with the original which is on the right.
    and here are both with some LED lighting placed inside
    Tomorrow I am going to practice the paint and order some more plastic to try some different thickness's.
    When I am happy with the result I will put an interest thread in the junk yard.
  3. The avalanche has started FuseNova's Avatar
    Join Date
    Nov 2009
    Location
    Maryland
    Message Count
    432
    Mar 4, 2012 - Re: SGU Destiny wall light sconce WIP #3
    Really glad you didn't cast this as one piece. I wasn't looking forward to getting the painting right.
    BTW: I'm sure there a better ways but I start with a layer of patina and paint over it.
    Looking forward to seeing this in the JY!
  4. andy19422's Avatar
    Join Date
    Jan 2009
    Message Count
    282
    Mar 5, 2012 - Re: SGU Destiny wall light sconce WIP #4
    I ordered some more plastic today and got a quote to get the backing plate CNC routed out of the correct 6mm plywood. I also painted the outer shell today, for my first ever prop painting attempt I am very happy with it. I used Plasti-kote fast dry enamel paints painted on to the matt black plastic paint. I first painted night blue with a 10mm brush, making sure the paintbrush was very lightly loaded and using random splodges and streaks. The next coat was copper but this time I used a small piece of sponge to dab it on, again only a very light coat. I painted a bit of cardboard then coated the sponge then dabbed it on a bit of paper until I got the right amount of paint. If you use a sponge make sure there are no straight edges or you will get lines on the piece your painting. The last coat was sky blue, again using the sponge but after a couple of minutes use a clean sponge to soften it. The last thing to do is use a very watery sky blue paint and apply in streaks and splodges to simulate water damage to the copper. I think I will add some dark Gray after the black coat next time. I also managed to make the back plate and painted it the same. Here are a few pics, the original is on the right.
    By andy19422 at 2012-03-05
  5. Contec's Avatar
    Join Date
    Jun 2008
    Location
    Sweden
    Message Count
    3,727
    Mar 5, 2012 - Re: SGU Destiny wall light sconce WIP #5
    andy19422 said: View Post
    Do you have permission from the member to make copy's from the one he sold you?
  6. andy19422's Avatar
    Join Date
    Jan 2009
    Message Count
    282
    Mar 5, 2012 - Re: SGU Destiny wall light sconce WIP #6
    Contec said: View Post
    This is an original prop not made by the member I got it from.
  7. USS Endeav's Avatar
    Join Date
    Nov 2009
    Message Count
    163
    Mar 5, 2012 - Re: SGU Destiny wall light sconce WIP #7
    I'll be keeping an eye out for your interest thread!
Similar Threads
  1. SGU Stargate Universe Destiny table lamps
    stefanchik, Screen-Used Movie Props and Wardrobe
    Last Post: Mar 27, 2013, 7:08 PM
  2. Where is the wall sconce seen in SG1?
    FuseNova, Screen-Used Movie Props and Wardrobe
    Last Post: Dec 15, 2012, 8:26 PM
  3. Stargate Chevron light/sconce
    FuseNova, Replica Movie Props
    Last Post: Sep 12, 2011, 11:35 PM
  4. SG Chevron Wall Sconce Build Thread
    Draphin, Replica Movie Props
    Last Post: Sep 2, 2011, 8:45 AM
  5. Predator 1 wall sconce
    xdmray, Replica Movie Props
    Last Post: Jul 21, 2011, 9:59 PM
1 2 3 4 5 6 7 8 9 10 11
