1. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    May 29, 2012 - Sandman Gun (Working Kit build-out) manual. Ton-o-pics #1
    A little something for the guys in our working DS gun build-out (kit) group.
    I figured while I'm doing some build-ups, I'd chronicle one, here. In fact, this will give you some idea how quickly one of these can be assembled once the machine work has been completed. That said, it takes about a year to get all the parts together (for a small run) to get to this point.
    There are no found parts on this outside of the toggle switch, battery harness and glowplug. People e-mail all the time asking where I get the valves from. The valve is 100% custom and took about a year to get it to where we wanted it. It was originally set-up with a vertical pull, but I preferred the seal we got with a horizontal rig.
    1) Here's a pic of DS gun all laid out after the machine work has been completed, grips poured and valve & filter tank assembled:
    2) Here's everything looking a bit more manageable. This is what the kit looks like when the guys in our build group get theirs. Everything has been tested, all machine work has been completed, all holes are drilled and tapped. You are ready to attach the front fin and grips, wire the prop up and paint.
    (More soon)
  2. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    May 30, 2012 - Re: Sandman Gun:Working Kit build-out manual w/pics #2
    3) I like to use JB Quick for the front fin and grips. Score the underside of the fin and barrel with a blade, apply JB quick and allow to set up. Repeat for the grips.
  3. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    May 30, 2012 - Re: Sandman Gun:Working Kit build-out pics #3
    4) Moving on to the wiring. The frame of the gun serves as the ground so the black wire from the battery harness is bolted to the frame.
    The positive (red lead) from the battery pack goes to the first prong on the toggle switch where it is soldered in place. The second prong is also wired up at this point. It will be connected to the glowplug later.
    5) At this portion of the build, the glowplug wire is pulled through a small hole in the front of the flash cage. The top portion of the gun is then slid into place where it will be bolted down.
    6) Here's how everything looks just before the glowplug is wired.
  4. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    May 30, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #4
    7) The glowplug lead is run down the fin and soldered to the tip of the glowplug
    NOTE: I've seen screen used guns with the glowplug wire running under the fin and seated on the side of the fin. I suspect this is for the very reason I prefer it as seen. Should you have to replace the glowplug the last thing you want to do is have to pull that fin off and rewire and then repaint the entire gun. I imagine this only had to happen once to the original propmaker before he opted for seating on the side of the fin. When running the lead down the fin, you can leave a little slack tucked inside the gun and simply pull some extra through should you need to rewire down the road.
  5. RPF Premium Member
    Join Date
    Aug 2002
    Message Count
    16,147
    May 30, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #5
    Awesome thread!!!!
    Mick aint got nothin on you!
  6. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    May 31, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #6
    Thanks. I figured it might save me a couple e-mails.
  7. boodha's Avatar
    Join Date
    Nov 2006
    Location
    NYC
    Message Count
    336
    May 31, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #7
    This is a great info resource for a wonderful prop. Gosh, I never get tired of this particular piece. Thanks Rylo!
  8. Blackbirdcd's Avatar
    Join Date
    Nov 2003
    Location
    Bothell, Washington
    Message Count
    191
    May 31, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #8
    This is a very cool effort. Looking forward to seeing how it turns out.
    My favorite video demonstrating the first test-fire of a Sandman working pistol - I forget who posted the story, but after a long series of "this is how it works" it ends with the test-firing... by the builder's wife.
    "Honey, can you hold this and pull the trigger for my video?"
  9. RPF Premium Member
    Join Date
    Aug 2002
    Message Count
    16,147
    May 31, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #9
    It will turn out like all the other Guns Ry has made.
    there is no other DS Gun that will surpass it.
    His are the best ever made
    Blackbirdcd said: View Post
  10. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    May 31, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #10
    Thanks, man. Yeah, I've built one or two of these over the years.
  11. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    May 31, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #11
    Too kind. Thank you. You should come over this weekend and I'll put ya to work!
    -Rylo
    apollo said: View Post
  12. RPF Premium Member
    Join Date
    Aug 2002
    Message Count
    16,147
    Jun 1, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #12
    Nothing like the smell of Calcium carbide in the morning!
    Rylo said: View Post
    -Rylo
  13. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    Jun 1, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #13
    Come get some...and bring tacos!
  14. Prefect42's Avatar
    Join Date
    Apr 2005
    Location
    At home.
    Message Count
    493
    Jun 2, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #14
    I was just firing mine last night. First time with our new dog and new neighbors next door. No police sirens or knocks on the door asking "What the hell was that?". But man, these make the coolest sound.
    Ted.
  15. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    Jun 5, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #15
    It's always good to break the new neighbors in as soon as possible.
    I just got some new CC in and it's a got an insane yield to it. Crazy loud!
    Prefect42 said: View Post
    Ted.
  16. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    Jun 11, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #16
    Speaking of CaC2. I just got a couple pounds in and damn is it kickin! Had to really dial back my ratio. I'm getting 9 and 10 good shots off 4 or 5 pebbles!
    -Rylo
  17. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    Jul 10, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #17
    Back to the top with this one. There's a new batch of kits hitting this week.
    -Rylo
  18. RPF Premium Member Rylo's Avatar
    Join Date
    Apr 2000
    Location
    USA
    Message Count
    6,806
    Jul 22, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #18
    Leaving these pics up for a couple more days. Save 'em if you want 'em!
    -Rylo
  19. Stansfield's Avatar
    Join Date
    Dec 2001
    Location
    Wooster, Ohio, United States
    Message Count
    446
    Jul 22, 2012 - Re: Sandman Gun (Working Kit build-out) manual. Ton-o-pics #19
    Damn that pic is so sexy!!!
Similar Threads
  1. My Sandman costume and working flame gun!
    Bryancd, Replica Movie Costumes
    Last Post: Sep 1, 2012, 9:37 PM
  2. Rylo Working Sandman Gun has arrived!
    Bryancd, Replica Movie Props
    Last Post: Mar 17, 2012, 6:38 PM
  3. Replies: 13
    Last Post: Feb 20, 2012, 8:21 PM
  4. Replies: 3
    Last Post: Dec 11, 2011, 1:06 PM
  5. Replies: 99
    Last Post: Jun 10, 2009, 9:19 PM
1 2 3 4 5 6 7 8 9 10 11
