Replica Props |
Screen Used Props |
Replica Costumes |
Sculpture and Makeup |
General Modeling |
Studio Scale Models |
Movie Discussion |
| Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models. |
Discussion on "Return of the Living Dead 2" Zombie Barrel Build (UPDATE 11-28-10) w/ VIDEO within the Replica Movie Props forum, part of the PROPS category; Delete Post
LinkBack | Thread Tools |
#151 |
Banned
Re: "Return of the Living Dead 2" Zombie Barrel Build (UPDATE 9-15-10)
Delete Post
RPF Sponsors
#152 |
Banned
Delete Post
#153 |
Well, there was a reason I mounted the glass on the bottom. I can't remember what it was though. I think that in the end I thought that it might be a little harder to do it that way, mainly because the inside of the lid is curved, and getting the glass to sit flush might be a little tricky.
That casting in there of Tarman is supposed to be cast off an original. I know someone that's got the melted and pre-melted versions. I liked the pre-melted version better. |
#154 |
Banned
OK kids, class is in. Today we are going to tackle the topic of the Trioxin barrel
from ROTLD Part 2.For the 2nd installment of the series, the director Ken Wiederhorn "for whatever reason" has a complete new design for the Trioxin canisters. Ok, that's fine...but when trying to make a replica of it, there are many differences from barrel to barrel. Obviously, they are not all the same. I personaly believe that there are at least 4 different screen used barrels. Not counting the background barrels. I'm reffering to the up front closeup and hero barrels. I hope that this thread helps you guys get the details you might have otherwise missed, and sheds a little light on the mystery that is the ever changing Trioxin Tank. First off let me start by saying that this is just a how I see it post, as I was not there and did not help build the props...so if anybody has anything to add or correct please feel free to do so. Let's start with Pic 1. http://http://i1185.photobucket.com/albums/z346/Joero6/SCREEN%20SHOTS/Barrelexam.jpgThis is a still from the back of the army truck at the start of the movie. We are going to focus on barrels 1,2,3, and 4. The rest are just background barrels that we never get a clear shot of anyway. Right away you will notice that 1 is different from the other three. This appears to be the same style barrel with un updated lid. If you look in the blue circles and compare it appears that the lids of 2 and 3 have a slight upwards curve to them. It also appears that the lids of 2 and 3 just sit down inside the lip of the barrels for this shot. I gather this from the fact that the lid of 2 is uneven by quite a bit,this could be from the jarring motion of the back of the truck during filming. Notice the lip of the lid gets wider from left to right. Next let's focus on the purple square. Barrel 1 has the original style compression ring while the rest don't. In fact, in this opening scene it almost looks like the compression part of the other barrels has been covered with some kind of tape and painted over...as there are no consistent details on it. Finally the lid. They added "metal" bands and a handle to the top. If you will direct your attention to the green square, you will see that this is not metal at all. This is most likely some kind of weather stripping or some sort of other peel and stick tape with a good thickness to it. Maybe a thin sheet of plastic that has been glued down. You can see the wrinkles in the square, so it's not anything too rigid. Hope this helps, I will be doing another post most likely later today with more details and comparisons. Joe |
#155 |
I always thought that looked like wide masking tape on the lid. I wonder what the keypad housing was made from. I never saw a clear shot of where the glass on it opens.
#156 |
Banned
I don't think it's supposed to "open", I believe it's a break glass kind of thing. Joe
#157 | |
Banned
Quote:
#158 |
I just used Super Glue Gel for my sticker. I use it for pretty much anything, it doesn't run and feels as strong as two part epoxy when its done drying.
#159 |
Banned
Is that super glue gel holding ok to the barrel's paint??? I have had mixed results depending on the type of paint. Also could you let me know which calculator had the "exact" buttons other than the arrows? I want to compare them to what I have researched so far. Thanks Joe
#160 |
The glue is holding fine on mine. It pretty much bonds to anything. The only thing I've ever had trouble with is things I probably shouldn't have tried it on, like felt, lol. I used it on a Jester head from Puppet Master. I drilled a hole through the head, poured some glue into the hole, and then put it onto the wire body and its held great. I even tried getting it apart once to repair it at one point, but it wouldn't come off.
Here's the link to the keypad I found. The four looks to be identical. Keypad - 12 Button - SparkFun Electronics |
#161 | |
Banned
Quote:
#162 |
Hmmm...I thought that it had a closed top 4. The only screen caps I got are the part when they break the glass. Can you post some screen caps?
#163 |
Banned
Here you go. As you can see the 4 is open and the 5 looks like an S. Also keep in mind that the buttons, while being square...have the round concave spot on them. So they aren't just a flat top button. You can see the shadows from the concave under the red arrows. Joe
#164 |
Banned
Delete Post
#165 |
Banned
Delete Post
#166 |
Man, you're right. I guess in the journey of searching countless pages I completely forgot what the damn thing looked like, lol.
I found a calculator that had similar buttons, although I'm sure it'd be pretty obvious they're not meant to be a used as a key-pad. |
#167 |
Banned
That's because they don't make them like that. All you are seeing is a 9 or 10 key keypad with concave numbers. The bottom part of the keypad is concealed by the facade of the control panel. The bottom row of keys is nothing more than stickers. There is a red and blue triangle to match the red and blue lights, and then a sideways rectangle in the middle. If you look close on the shot at the start of the movie "in the back of the truck before they fall" you can see the triangles aren't the same shape or size and look like a piece of blue and red painters tape. Also, the rectangle appears to be a piece of masking tape that is dirty, and is just wide enough to cover the 8. If I can track down the exact buttons, I will be making a replica of this piece which lights up in different configurations...depending on which button you push. Solid red, solid blue, blinking red, blinking blue, blinking back and forth between the two,and both on at once. Let me know if you locate them I am still looking as well. Joe
#168 |
Banned
I'm guessing a telephone, alarm style keypad, or one of the large calculators. Joe
#169 |
Banned
Delete Post
#170 |
What's the status on the lids Joe?
#171 |
Banned
#172 |
Banned
Delete Post
#173 |
I call dibs on one barrel and two lids!
#174 | |
Banned
Quote:
#175 |
Banned
Delete Post
