the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > PROPS > Replica Movie Props
"Return of the Living Dead 2" Zombie Barrel Build (UPDATE 11-28-10) w/ VIDEO
Discussion on "Return of the Living Dead 2" Zombie Barrel Build (UPDATE 11-28-10) w/ VIDEO within the Replica Movie Props forum, part of the PROPS category; A few more...
Reply
LinkBack Thread Tools
Old 08-31-2010, 08:49 PM   #26
Rusty85's Avatar
Rusty85 has a reputation level greater than 10!
Re: Return of the Living Dead Zombie Barrel Build
A few more...
vlcsnap-2010-08-31-17h27m29s80.png   vlcsnap-2010-08-31-17h31m25s59.png   vlcsnap-2010-08-31-17h33m56s108.png   vlcsnap-2010-08-31-17h36m04s108.png   vlcsnap-2010-08-31-17h36m35s102.png
vlcsnap-2010-08-31-17h36m58s4.png   vlcsnap-2010-08-31-17h44m34s66.png   vlcsnap-2010-08-31-17h45m54s114.png   vlcsnap-2010-08-31-17h48m53s250.png
Rusty85 is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 08-31-2010, 09:32 PM   #27
darthgordon's Avatar
darthgordon has a reputation level greater than 50!
Excellent. I think the drum you started with will be perfect. The placement of the bungs and outside wall of the drum is pretty spot on. Hopefully you kept at least one of the lids.
Not sure what that dome top is.
The keypad is interesting. It only has 6 numbers on it and some sort of blue and red triangle... which may correspond the red and blue lights.
The paint-up is really going to be what sells it.
darthgordon is offline   Reply With Quote
Old 08-31-2010, 09:41 PM   #28
"Roy-al with Chesse!"
jasonw2112's Avatar
jasonw2112 has a reputation level greater than 100!jasonw2112 has a reputation level greater than 100!
O.k., I know this may not be much help, but I'm a huge Return of the living Dead Fan! I was able to go to Monsterpalooza in Burbank in April, and I meet the whole cast, but James Karen, and Clu Gulager. I later meet James Karen at Wonderfest. Anyways, When I was at Monsterpalooza, a vender was selling "Tarman" Half head sculpt's for $100.00. I was so consumed with everything going on that I did'nt think to buy one. I have looked far and wide since then to get one, but I have been unable to find out who cast them. I'm still kicking myself in the a## for not getting it when I was there, but I'm going to look through the program from the show. I might be able too find out the vendor who made them. Here's a pick of me with "chuck" holding a sculpt he purchased for himself!
jasonw2112 is offline   Reply With Quote
Old 08-31-2010, 09:43 PM   #29
Rusty85's Avatar
Yeah true. A guy that did one gave me some tips on the paint, but I'm always listening if anyone's got any good advice on the painting. Colors, technique or anything really. He recommended using Krylon Fushion Hunter Green as a base (after the layers of primer). And then said to use a bunch of nasty colored oil-based paints and mix them together and spray them from a spray bottle at the top, letting it drip down the sides.
It looks like the top sticker says:
ENTER ACCESS MEMBER CODE
ENTER COLOR CODE
ACTIVATE __________ ___________
Old 08-31-2010, 09:46 PM   #30
Rusty85's Avatar
Quote:
Nice!!! Never seen one that's the melted version
Old 08-31-2010, 10:30 PM   #31
jasonw2112's Avatar
Oh, before you go cakeing paint on the barrel, you may want to do some paint preping! First you need to clean the outside with warm soapy ( no aloe! ) water to remove any contaminants from the surface. Than get some red scotch brite pads and scuff it down real good. This will let the paint grab into the plastic better. Then clean the plastic again to remove what you scuffed. When you get it nice and clean, and ready to paint, go to your local auto paint supply shop, and get some plastic adhesion promoter. They have it in spray cans, a good brand is "bulldog adhesion promoter". This helps make paint stick, to all sorts of plastics. You just need to apply 1 good coat to the whole canister,then let it set for about 15 minutes. After that, apply your first overall color! This may sound like a pain, but if you want the paint to stick the best it can stick, follow these rules! As far as the fusion paint goes,I have yet to see it really make a difference in adhesion. The other factor that causes the paint to come off is bending, or flexing the plastic. This is where adhesion promoter comes in. In the end there is still a chance for the paint to scratch, and chip off, but this will really help out in the long run.
Old 08-31-2010, 11:03 PM   #32
Rusty85's Avatar
Thanks for the tips! I've been sanding for a while now, so that should help the adhesion.
Old 09-01-2010, 02:01 AM   #33
Howlrunner's Avatar
Howlrunner has a reputation level greater than 10!
Your Props
Quote:
The melted version was made by the same guy I bought the pre-melt version from. I remember he had the melted version up on eBay a while after I bought the pre-melt version. Both were done from original molds.
Howlrunner is online now   Reply With Quote
Old 09-01-2010, 02:28 AM   #34
Bilious's Avatar
Bilious has not been awarded enough reputation to matter.
Omg this was one of the first zombie movies (among a million) I was exposed to to desensitize me to horror films and so holds a very special place in my heart. I can't wait to see how this build goes! And taking notes in case I ever have a need to decorate... >:3
Bilious is offline   Reply With Quote
Old 09-01-2010, 03:47 AM   #35
Jet Beetle's Avatar
Jet Beetle has a reputation level greater than 50!
They may not discuss the barrels in the commentary but they do talk about how things were done on the cheap. There's a scene they point out where the General who has been searching for the barrels gets on the phone and takes notes - if the look at the phone cord it's coming unglued from the counter. It's pretty funy
Jet Beetle is offline   Reply With Quote
Old 09-01-2010, 04:41 AM   #36
mrsmartypants has a reputation level greater than 10!
ENTER COLOR CODE
The top says ACCESS INSTRUCTIONS
I think the first line actually says ENTER ACCESS NUMBER CODE
Also, it looks like the last line says ACTIVATE RELEASE _________
Perhaps HANDLE is the final word?
Thoughts?
mrsmartypants is offline   Reply With Quote
Old 09-01-2010, 04:52 AM   #37
Hey Rusty, have you seen this? Zombie Barrel Prop
There are some nice photos that might help you in assembling your barrel.
I'm watching this thread with much interest!
Old 09-01-2010, 09:29 AM   #38
Rusty85's Avatar
Thoughts?
Hey, yeah I think you're right. It didn't sound like Member Code made much sense, lol. I'm betting you're right on the third one too. I didn't even notice the top part of the sticker.
I saw that link, that's actually the same guy that gave me the instructions on the painting. He did a great job on it, although I don't care much for the wires coming out the front. We exchanged a few messages but he never really told me why he didn't make the dome top to it. My guess is he made so many it would have been even more time consuming to make the lids for them all, I think he said he made 12 or something along those lines.
He says he sold one to a store in Pittsburgh in the Monroeville Mall over there. I'm assuming that it was Time and Space Toys. He says its still on display there today. Pretty cool!
Old 09-01-2010, 09:46 AM   #39
kdawg1's Avatar
kdawg1 has a reputation level greater than 10!
Man I've wanted to do one of these for years just never had the room! This is looking great......I be watching this one!
kdawg1 is offline   Reply With Quote
Old 09-01-2010, 03:17 PM   #40
Yeah, he seems to have made an idealized version rather than a movie accurate version, though his do look very cool! I noticed he didn't have the keypad on his and the phone number to call was an 800 number instead of 311. But, they still are cool nonetheless.
I'm definitely looking forward to how yours turns out!
Old 09-01-2010, 04:58 PM   #41
smells of resin
Knightjar's Avatar
Knightjar has a reputation level greater than 10!
Well, this thread inspired me to dig out and photograph my sculpt. I really need to get this finished some time.
Knightjar is offline   Reply With Quote
Old 09-01-2010, 05:04 PM   #42
tk1055's Avatar
tk1055 has a reputation level greater than 10!
Ok that is just creepy. I mean did you have to use flesh colored clay...... LOL Just kidding!! That looks fantastic, the details on the hands is amazing. The hands are absolutely beautiful. The joints in the fingers, the melting/rotting flesh, the eyelids, hell everything! Great job, You really need to finish that sculpt!
tk1055 is offline   Reply With Quote
Old 09-01-2010, 06:08 PM   #43
Rusty85's Avatar
Awesome work! Looks great!
Old 09-02-2010, 02:04 AM   #44
Howlrunner's Avatar
Your Props
Looks great Knightjar! If you want more pics of my head cast for detailing, etc then just shoot me a PM. I'd love a cast of the hands you've done to go with my head.
Old 09-02-2010, 09:54 AM   #45
Rusty85's Avatar
Anyone know where to buy the Scotch Brite Red Pads? Looked at Wal-mart but they didn't have them. Wouldn't sand paper get the job done?
Old 09-02-2010, 09:58 AM   #46
MooCriket's Avatar
MooCriket has a reputation level greater than 300!MooCriket has a reputation level greater than 300!MooCriket has a reputation level greater than 300!MooCriket has a reputation level greater than 300!MooCriket has a reputation level greater than 300!
Loved this movie, can't wait to see this completed
MooCriket is offline   Reply With Quote
Old 09-02-2010, 11:18 AM   #47
How about a hardware store or a home improvement store like Home Depot?
Old 09-02-2010, 12:04 PM   #48
I'm pretty sure anything used to score the surface will work.
Old 09-02-2010, 12:32 PM   #49
Rusty85's Avatar
That's what I was thinking. I've already sanded about 60% of the outside of it. Got some strong sandpaper too, so the surface should be pretty well scuffed up by the time I'm done.
Gonna snap a pic later with the ring on it.
Old 09-02-2010, 12:54 PM   #50
jasonw2112's Avatar
Just check with an automotive paint supply store, they should have them! For sandpaper try to get around 320 grit. If you get too course like 180, 80 grit, you may endup having sand scratches show through the paint.Then again that could be a good thing!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
My "What If.." Night of the Living Dead newspaper TylerHam Replica Movie Props 8 11-20-2011 10:50 PM
"Walking Dead" Zombie Makeup ChickenHaunt Replica Movie Costumes 27 11-11-2011 04:33 PM
Return of the Living Dead Tarman costume! patsmear Replica Movie Costumes 15 11-01-2011 07:34 AM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
