Page 2 of 5 FirstFirst 12345 LastLast
  1. RPF Premium Member Beechy McFly's Avatar
    Join Date
    Jan 2010
    Location
    Sydney, Australia
    Message Count
    1,540
    Jan 19, 2010 - Re: Hovering / Floating Globe #26
    Yeah.. I can see some Star Wars, even BttF Hoverboard mods happening..
  2. RPF Premium Member
    Join Date
    Nov 2009
    Location
    Medway , Kent
    Message Count
    406
    Jan 19, 2010 - Re: Hovering / Floating Globe #27
    Or as another idea would his method work for the floating ore from Avatar ?
  3. 137th Gebirg's Avatar
    Join Date
    Nov 2006
    Message Count
    197
    Jan 22, 2010 - Re: Hovering / Floating Globe #28
    Or a cenobite puzzle box...
  4. I be got no weapon! Clutch's Avatar
    Join Date
    Jun 2005
    Location
    The Basement
    Message Count
    7,067
    Jan 22, 2010 - Re: Hovering / Floating Globe #29
    Or a rock.
  5. parabellum's Avatar
    Join Date
    Jan 2010
    Message Count
    61
    Mar 23, 2010 - Re: Hovering / Floating Globe #30
    http://www.innovatoys.com/p/REV2
    Levitron just released there 12 oz model. its less than 100$
    it can levitate objects side ways too.
    http://www.youtube.com/watch?v=NgbsgiS5kB8
    and Crealev came up with 1 kilogram lifter. amazing.
    http://www.youtube.com/watch?v=jxkpp1ypgbQ
  6. MooCriket's Avatar
    Join Date
    Jan 2009
    Location
    Baltimore MD
    Message Count
    6,851
    Mar 23, 2010 - Re: Hovering / Floating Globe #31
    Nice find, Parabellum
  7. subxinu's Avatar
    Join Date
    Jun 2009
    Location
    Guadalajara, Jalisco, Mexico
    Message Count
    118
    Mar 23, 2010 - Re: Hovering / Floating Globe #32
    Very cool stuff! Could possibly make a nice emotion chip display!
  8. Join Date
    Jan 2010
    Location
    Midwestern Enclaves
    Message Count
    91
    Mar 24, 2010 - Re: Hovering / Floating Globe #33
    I'm wondering why use a resin cast sphere when lightweight styrene plastic vending capsules might be an alternative ?
    http://www.wholesalevendingproducts....sules_s/27.htm
  9. fabrik's Avatar
    Join Date
    Nov 2009
    Location
    Sunny Wigan UK
    Message Count
    78
    Mar 25, 2010 - Re: Hovering / Floating Globe #34
    has anyone thought of using a paper craft remote, that'd be pretty light to start off with?
  10. Replicant's Avatar
    Join Date
    Jan 2009
    Message Count
    158
    Mar 25, 2010 - Re: Hovering / Floating Globe #35
    I think the most practical use for this is the Phantasm Sphere.
    I think an open hand for the base would be cool, or incorperate it into a lifesize Tall Man sculpt.
  11. RPF Premium Member Trooper_trent's Avatar
    Join Date
    Sep 2000
    Location
    Fort Worth TX
    Message Count
    1,719
    Nov 4, 2010 - Re: Hovering / Floating Globe #36
    I know it has been years since I created this thread. But I'm just now starting to make some progress on this thing.
    I've had this floating globe sitting in my office for a couple of years now and every once in a while, I'll get the urge to convert it. Well, Finally a couple of days ago, I just took the plunge and ripped off the printed globe covering, leaving just the plastic ball.
    So I'm off!
    Started with this
    The covering was thicker than I thought, which lightened it up quite a bit. I made sure it still floated without the extra weight and it did.
    With the extra weight gone, I have a little more wiggle room for adding the pieces.
    First, I marked off some lines for placement, then I weighed it using a food scale that is very sensitive.
    I then made a few TEST pieces and made my first cut into the ball to insert the "wheel" piece.
    Keep in mind that this will not be quite full sized. My globe is only 5" in diameter so I'm going to have to custom make each piece rather use get castings of the model parts. So this will definitely not be 100% accurate. Having said that, I always thought the original prop seemed bigger in real life than it appeared on screen, proportionately. That may be due to the fact that it was shot separately on green screen and then super-imposed, possibly at a different distance. This globe APPEARS (at least to me anyway) to be about the right size compared to my graflex as the movie remote appears to Luke's Graflex in ANH. That's my justification for making it smaller anyway.
    After fitting the test pieces, I weighed it again. Due to removing the bit of plastic for the hole to allow the Wheel piece to fit, and due to the light weight materials I'm using, I netted 0 extra weight!!
    This means theoretically, I can repeat this process for each "wheel" piece and not gain any extra weight. I estimate that the other pieces (once I find out how to make them) and paint will gain just about the same as the weight of the globe cover so I should still be well withing my tolerances. I also tested before hand, putting pennies inside to see how heavy I could get it and have it still float without straining the base.
    Anyway, Here's a quick teaser. Remember, these are just test pieces so they arent as clean as they will be when I make the final ones.
    YouTube - TrAining remote test
    Looks like I'm off to a good start! More progress to follow shortly!
  12. Banned
    Join Date
    Mar 2004
    Location
    Sunny Socal, Lancaster to be exact
    Message Count
    3,936
    Nov 4, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #37
    convert it to a Deathstar and be done with it. LOL
    looks good man, keep it up (pun intended)
  13. RPF Premium Member Trooper_trent's Avatar
    Join Date
    Sep 2000
    Location
    Fort Worth TX
    Message Count
    1,719
    Nov 5, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #38
    slave1pilot said: View Post
    My 4 year old came in while I was working on it last night and said, "Daddy, is that a Death Star?"
    At least I know I'm teaching him well.
  14. Join Date
    Oct 2010
    Message Count
    63
    Nov 5, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #39
    This is really cool. What are you using to create the add on pieces?
  15. RPF Premium Member Trooper_trent's Avatar
    Join Date
    Sep 2000
    Location
    Fort Worth TX
    Message Count
    1,719
    Nov 5, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #40
    Haven't figure it all out yet, but so far, the square/rectangle pieces and the outer rings for the lasers are just made of craft foam and the "wheel" parts are just smal canister caps. I'll probably end up using styrene or something similar for these parts if I can keep the weight down.
  16. DarthLuumzl's Avatar
    Join Date
    Apr 2010
    Location
    Germany
    Message Count
    303
    Nov 5, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #41
    Oh, that looks fine to me!
    I'm sure you're on a good way!!!
  17. Nothing but the rain.... Pete SSS's Avatar
    Join Date
    Nov 2009
    Location
    UK
    Message Count
    410
    Nov 5, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #42
    This is pretty exciting, I'm loving your determiniation! Keep going!
  18. Join Date
    Aug 2007
    Message Count
    132
    Nov 5, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #43
    I've done some work with these before, the size doesn't matter as long as the weight and magnet placement are the same.
    I saw a floating Delorean on a website not to long ago that was made for Universal.
    Dex
    Edit: This is the one I was talking about. Pretty neat, I'd like to know what he did to the model to get it to work.
    http://www.lucasfrancisstudio.com/LF...gDelorean.html
  19. RPF Premium Member Trooper_trent's Avatar
    Join Date
    Sep 2000
    Location
    Fort Worth TX
    Message Count
    1,719
    Nov 6, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #44
    update. Added some more pieces.
    Still floats! :-)
    YouTube - TrAining remote test 2
  20. RPF Premium Member Trooper_trent's Avatar
    Join Date
    Sep 2000
    Location
    Fort Worth TX
    Message Count
    1,719
    Nov 6, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #45
    Today I finished adding the rest of the pieces.
    She STILL Floats!. I even placed several sheets of paper on top of it to simulate extra weight from the paint. No Problems! This may actually happen!.
    progress
    more progress
    and done. All thats left is clean up and details.
    and a new video.
    YouTube - TrAining remote test 3
  21. Bondo Fett's Avatar
    Join Date
    Nov 2009
    Location
    PDX, OR, USA
    Message Count
    141
    Nov 6, 2010 - Re: Real Hovering Jedi Training Remote: Update! Progress Finally! #46
    That is totally awesome! Your determination really paid off.
  22. RPF Premium Member Trooper_trent's Avatar
    Join Date
    Sep 2000
    Location
    Fort Worth TX
    Message Count
    1,719
    Nov 6, 2010 - Re: Truly Hovering Training Remote: Update! Progress Finally! #47
    After three coats of Ivory ( and a puppy photo bomb)
  23. lesternessman's Avatar
    Join Date
    Apr 2005
    Location
    Atlanta, Georgia
    Message Count
    804
    Nov 6, 2010 - Re: Real Hovering Jedi Training Remote: Update! Progress Finally! #48
    Now that's cool.
  24. RPF Premium Member Trooper_trent's Avatar
    Join Date
    Sep 2000
    Location
    Fort Worth TX
    Message Count
    1,719
    Nov 6, 2010 - Re: Real Hovering Jedi Training Remote: Update! Progress Finally! #49
    And it's finished! Not bad for a little weekend project.
    Again, I'm fully aware that it's not screen accurate. I had to use very light weight materials in order for it to float. I'll make a formal video of it tomorrow, but for now, here's a few pics and a youtube clip of it in action.
    YouTube - Real hovering training remote
  25. Reversing The Polarity Organic Mechanic's Avatar
    Join Date
    Jun 2010
    Message Count
    1,191
    Nov 6, 2010 - Re: Real Hovering Jedi Training Remote: Update! Progress Finally! #50
    Dude! That really turned out well. Great job.
    Two questions, is the rotation a feature of the levitation unit, or do you just start it spinning before taping, and is it overly easy to accidentally knock it off of the levitation unit?
Similar Threads
  1. Jedi Training Remote
    Luke0312, Replica Movie Props
    Last Post: Mar 23, 2013, 5:19 PM
  2. Finished: Jedi Training Seeker/Remote
    vistaVision, Studio Scale Models
    Last Post: Aug 22, 2012, 9:01 AM
  3. Almost truly hovering Training Remote
    Gigatron, Replica Movie Props
    Last Post: Dec 6, 2006, 12:07 PM
  4. Truly hovering Jedi Training Remote
    Last Post: May 18, 2006, 9:13 AM
  5. Jedi training remote....parts!
    Coinprop, Studio Scale Models
    Last Post: Nov 11, 2004, 7:13 PM
1 2 3 4 5 6 7 8 9 10 11
