saberforge
Member
Here is my redesigned and revamped prodigal son.
It features a number of improvements over my current prodigal son.
First and foremost I was able to reduce the neck to under 3/4 of an inch, and IMPROVE combat durability. I did this by making the 3/4 neck a central strut that slides into the blade, and the shroud creates an overlap channel that the blade slide into. The central strut houses the heat sink, led, and custom optic. So the seoul p4 led is actually inside the bottom of the blade when the blade is installed. So you don't lose any lumens with a neck choke, and you don't have to sacrifice athetics for durability.
Second, I redesigned the pommel, and am now media blasting the milled surfaces to avoid any machine marks. Also, I had the fortune of sourcing a stainless tri-ring, which I think compliments the hilt very well.
Third, I designed a new activation box, and moved the switch from the pommel, to the activation box. Now the circuit card is actually the switch, pres the center of the card to turn the saber on and off. Red and green arrows and a black greebly adorn the side of the box.
Fourth, I completely redesigned the main handle portion of the hilt as well, and overall was able to reduce the length from almost 13 inches, to only 11.
Here is the video.
YouTube - Prodigal son LED saber, not MR FX LUKE LIGHTSABER
Here are some pictures.
Here is the video.
