1. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 17, 2011 - Portal Gun from scratch! First build! #1
    Hey everyone!
    I just registered, so I figure I'd throw up the pics of my first build happening now!
    An 'Aperture Science Handheld Portal Device'. Comments and questions welcome! (More about me later...)
  2. PrimoOptimoso's Avatar
    Join Date
    Aug 2011
    Message Count
    430
    Aug 17, 2011 - Re: Portal Gun from scratch! First build! #2
    Good so far! Looks like you're following the Volpin method =0)
    One thing I will say: I used the 4" PVC part as a base measurement (4.5" outer diameter) and printed it out 1:1 scale (life size), and discovered that 2" PVC, offset toward the top a little bit (rather than centered within the 4"), is a much closer size for the front barrel than 3" PVC would be.
    Good luck - this is a great project and people will love it.
  3. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 18, 2011 - Re: Portal Gun from scratch! First build! #3
    Hey PrimoOptimoso! Thanks for the tip!
    I'm gonna stick with what a have for now, I kinda like the huge 'barrel' out front
    Made a few changes today, most involving removing length from the back-end of the barrel. But more on that later...
    Here are a few shots I took of my work area.
    My messy workroom!
    My tiny work desk! (It's not that bad actually)
    And my greatest (and newest) toy - the Dremel 4000!!!! *Cue Applause* - Best... Tool... Ever... - You can also see the Florists Foam I'm planning to use for the outer shells.
    Pics of the build in my next post!
    Tas.
  4. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 18, 2011 - Re: Portal Gun from scratch! First build! #4
    Ok, now the good stuff!
    So after some guesses and dodgy measuring, I cut down both sections of the barrel by about 60mm (I'm Australian, so you'll get all Metric measurements from me, sorry!) so they would sit against the pipe stops in the main body section.
    I put new supports for the back of the inside-barrel section to rest on, and made a hole in the middle for wiring.
    More news as it comes to hand! I have a LAN this weekend, so probably not much work getting done... Oh well...
    Tas.
  5. Join Date
    Dec 2010
    Message Count
    966
    Aug 18, 2011 - Re: Portal Gun from scratch! First build! #5
    That's a great looking gun.
    Some of it's going to use all of your sculpting skills.
    Ps did you see the RPF Utube Star Wars Chick interview with the MIB3 gun makers. Nice organic sculpted guns on that as well.
    http://www.youtube.com/watch?v=sFdnKCJsPZA
  6. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 18, 2011 - Re: Portal Gun from scratch! First build! #6
    No I didn't... I'm literally brand-new on the scene! Haven't had time to scan the forums yet either, but it's on top of my internet to-do list.
    Anyway, here is a couple of shots with my girlfriend holding the gun as it is now. I think I can see it complete a lot more clearly in my head now...
    Tas.
  7. Join Date
    Jun 2011
    Message Count
    42
    Aug 18, 2011 - Re: Portal Gun from scratch! First build! #7
    excellent so far, looking good. What are you planning to make the spindly arms out of?
  8. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 18, 2011 - Re: Portal Gun from scratch! First build! #8
    I was thinking to cut them out of some plastic storage containers I have here, but I was given some clear acrylic sheet plastic the other day, so I might layer it up and use that...
  9. punky859's Avatar
    Join Date
    Apr 2010
    Location
    Ireland
    Message Count
    100
    Aug 20, 2011 - Re: Portal Gun from scratch! First build! #9
    nice build ^^especially for a first.... i may try the same method you're using as i've just finished the game and want EVERYTHING from it.... even the psychotic killer robot
    ill be eagerly watching this thread :3
  10. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 22, 2011 - Re: Portal Gun from scratch! First build! #10
    Hey everyone!
    I was off crook from work today, musta ate something bad over the weekend... At least I managed to crawl out of bed and get something done!
    Latest part fabrication: A round... disk, umm, bit...
    This part is designed to sit inside the chassis, providing a solid 'wall' for the barrel to attach to. I haven't quite figured out how I'm going to attach it, maybe someone has an idea? Any input would be appreciated! I was thinking about gluing in a cut wood or metal block to screw into from behind the wall (where the battery and electronics will sit once everything is fitted). I want to be able to at least break it in half for repair access and transport safety...
    Anyway, here's a few quick shots I took after making the disk. Quite pleased with how it turned out!
    The Disk Itself!
    How I set up my Dremel and workbench to cut the disk...
    ... and how the disk sat in the 'apparatus'
    So now, here is how it sits inside the chassis...
    With the barrel inserted from the back...
    ... and with the barrel in from the front(ish)... This shot has the mockup rear casing on it! (Just for something to judge with - nowhere near the final version)...
    Here's a side shot for length comparisons...
    - Tas
  11. Join Date
    Aug 2011
    Message Count
    21
    Aug 22, 2011 - Re: Portal Gun from scratch! First build! #11
    Wow, this is looking really good! I'll definitely be keeping an eye on this - can't wait to see the finished product XD
  12. Join Date
    Jun 2011
    Location
    France
    Message Count
    20
    Aug 22, 2011 - Re: Portal Gun from scratch! First build! #12
    Pretty neat
  13. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 22, 2011 - #13
    So hopefully today I can get my containment tube cut to size and the floral foam glued into a block ready to mark up and cut down for the rear cover... Crossing my fingers anyway... Does anyone have a recommendation for glues to use on the foam? I'd like to avoid ridges where the blocks of foam meet, so I am thinking spray contact adhesive?
  14. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 23, 2011 - Re: Portal Gun from scratch! First build! #14
    Late Night Update!
    While I didn't get around to cutting the tube (I want to make another disk or two before I move the rig), I did manage to get started on the florists foam block for the sculpting and the what-not...
    I ended up buying a can of this: Selley's Kwik Grip Spray Contact Adhesive. It went on very thin, but after an hour or so the bond was enough to hold them together while my efforts to prize them apart started buckling the foam!
    I'd like to point out again at this point that I live in Melbourne, Australia and brands/products can differ greatly to other countries... I'm always worried that something I try is too different to what Yank makers use!
    -Tas
  15. Join Date
    Jun 2011
    Message Count
    42
    Aug 24, 2011 - Re: Portal Gun from scratch! First build! #15
    Matthew Reilly - winnnnnn!
  16. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 26, 2011 - Re: Portal Gun from scratch! First build! #16
    A quick update! Kind of... well... a 'testing-of-stuff' update...
    So a trip to the local $2 shop found me some cheap tools and a new dust mask and safety glasses. Can't be too careful!
    Good news everyone! My eBay LEDs arrived! From China... No info on them... darn... 3mm orange and blue high brightness.
    I also bought some sandpaper from the $2 shop. Used to rough up my acrylic rod some... it works surprisingly well!
    And that shot is 1 high brightness LED on a half dead battery! I have 10 of each red and blue! Should look sweet once its sanded fully and had the ends polished!
    -Tas
    And yes.... it does look like a Lightsaber... XD
  17. PrimoOptimoso's Avatar
    Join Date
    Aug 2011
    Message Count
    430
    Aug 26, 2011 - Re: Portal Gun from scratch! First build! #17
    hey tast - you got red? should be orange. If you're running them on 9 volts I have some orange ones already wired with resistors for 9V.
    Damn, might not be cost effective to ship all the way to Aus...
  18. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 26, 2011 - Re: Portal Gun from scratch! First build! #18
    Whoops! I meant to write orange... XD
  19. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Aug 27, 2011 - Re: Portal Gun from scratch! First build! #19
    Hi all!
    So, I got some work done today, not heaps, but some...
    First, I started on some of the disks that go inside the clear pipe, with the raised pattern on it...
    Here is a shot with the clear pipe inserted into the barrel...
    ... and here's one with my holding a single 5mm led at the rear end...
    The camera makes it look brighter than it actually is, but it's still a good start! Apologies for the horrible photo quality, I will get some better shots when my partner gets home with my camera
    -Tas
  20. Join Date
    May 2010
    Message Count
    89
    Aug 27, 2011 - Re: Portal Gun from scratch! First build! #20
    Very cool stuff! Keep it up!
  21. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Sep 2, 2011 - Re: Portal Gun from scratch! First build! #21
    Quick Update!
    Electronics! I love electronics! XD *squee!*
    Recieved some "piranha" style LEDs in the maill today fresh from eBay. I went for a drive after work to my local Jaycar Electronics store to purchase some resistors.
    Did I mention I love electronics? So cool...
    The orange ones are a bit duller that the blue, but still plenty bright enough considering how many there are...
    I've got a deadline I'd like to meet now, Armageddon in Melbourne on October 22nd, so I can take it along for a bit of cosplay
    Plenty planned to do over the weekend, let's see how much I can accomplish in 2 days, yes? XD
    - Tas
  22. tastgr's Avatar
    Join Date
    Aug 2011
    Message Count
    15
    Sep 3, 2011 - Re: Portal Gun from scratch! First build! #22
    24 Hours Later Update!
    So, day 1 of the weekend has passed... Did I make any progress? YES! w00t!
    So today I finished off the barrel-end piece of lighting circuitry. It's very bright on blue and quite bright on orange, so I'm happy with it for now...
    This is the finished board (not pretty, I know but it works...) with the switch temporarily hooked up to check wiring is correct.
    I also got some fairly important stuff done on the barrel itself, chiefly putting in the air-dry modelling clay for the barrel sides and front... It looks like it will work fine! I built most of it up a little for sanding and finishing when dry...
    So, there's the update for today, tune in tomorrow night to see if I managed to finish anything else!
    - Tas
  23. bak9799's Avatar
    Join Date
    May 2010
    Location
    Pittsburgh/Philadelphia PA
    Message Count
    263
    Sep 3, 2011 - Re: Portal Gun from scratch! First build! #23
    Looking good, I've wanted to do a Portal Gun for a long time. looking forward to the finished piece!!!!
Similar Threads
  1. My Portal Gun Build
    IronCostumer, Replica Movie Props
    Last Post: Apr 26, 2013, 6:56 PM
  2. Portal gun build (with pictures)
    giedrius, Replica Movie Props
    Last Post: Feb 5, 2012, 9:08 AM
  3. Portal Gun Build
    Dainbramage546, Replica Movie Props
    Last Post: Jan 6, 2012, 12:17 PM
  4. Portal Gun - scratch build finished
    christ, Replica Movie Props
    Last Post: Oct 11, 2011, 11:21 PM
  5. My Portal Gun Build
    jeremiahjw, Replica Movie Props
    Last Post: Sep 12, 2011, 9:26 PM
Tags for this Thread
1 2 3 4 5 6 7 8 9 10 11
