Replica Props |
Screen Used Props |
Replica Costumes |
Sculpture and Makeup |
General Modeling |
Studio Scale Models |
Movie Discussion |
| Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models. |
Discussion on Nike McFly to 2011 Nike MAG (My Conversion) within the Replica Movie Props forum, part of the PROPS category; Nike McFly to 2011 Ni ke MAG Want to get
LinkBack | Thread Tools |
#1 |
![]() Want to get it? Check it at my junkyard link below, S02Customs 2nd RUN: Nike MAG Ok I know there has been many conversion style on these 'markpoon's nike mcfly' But I like to share my nearly 4 weeks of NIGHTMARE with the conversions!!! Quick story I could have completed it in 2weeks.. but lets just say there was a few loose ends and I needed to COMPLETELY remove the inner workings out again and start on improvising the circuit. As of what your going to see is my Mag Circuit (Mark 3). Circuit is design to be completely wireless "hidden wires" both internally and externally and resembles as closely as possible to Nike's 2011 Mag!!! I try to make it as easy to understand and trust me I did not know what I was gonna go through, never worked on shoes, work with paints but not on shoes and I have not been in-touch with my electronics side for years..... ENJOY!!! ITEMS: 1 - 8 Red Leds 1-2v 2 - 8 Yellow Leds 1-2v 3 - 8 Green Leds 1-2v 4 - 8 Blue Leds 3v 5 - Battery 9v 6 - Inverter 7 - LOTS of resistors 8 - Battery Holder 9 - 3m wires 10 - 1m wire shrink (1mm, 2.5mm 3mm) 11 - ON/OFF Switch 12 - PCB (Circuit Board) 13 - Blue/Green Paint 14 - Soldering Iron 15 - Solder Wire 16 - Hot Glue 17 - Hot Glue Sticks 18 - Super Glue 19 - Duct Tape 20 - News Paper 21 - EL Panel was included by Markpoon for the Nike Logo 1 - Paint Job ![]() Covering the shoe with newspaper and duct tape for edges and holding the whole covers together! I've used a Auto Paint and use a fork to splat out the paint nicely and evenly throughout the entire sole as designed. RESULT: AWESOME!!!! 2 - Circuit (Mark 1) Design Philosophy: A circuit to match the 2011 Nike Mag!!! 1 - 1 Battery 2 - 1 Switch to ON everything! 3 - SMALL 4 - Flexible & Durable 5 - Comfort 6 - Design to replicate 2011 Nike Mag 7 - Easy battery access/replacement 8 - AWESOME!!! Looks easy and basic, I could not get hold of any EL Paper/Panel for the shoe sole, my best bet was EL Wire. BUT its not as bright as I thought it would have been... RESULT: SAD... ![]() 12 Leds for the side lighting!!! ![]() (Mark 2) Still with the basic design but with added wires as to power the leds for the sole, the bright level was great!! However the circuit was not tough to carry the weight and 'wear & tear' so its not durable and wires starts to break!!! RESULTS: ARRGGGHH!! ![]() (Mark 3) Same principle with basic design to its "simplicity" and added rubber shrink for water proofing and durability!!! As you can see the picture below is where the wire will run in around the shoe and where the hidden ON/OFF switch will be located!!! RESULTS: HELL YEA!!!! ![]() 3 - Installation Removed the sole pads and the hard wood sole (hard wood was a b**** to remove but i got that thang removed!!!) 1 - Sanding down on the inner sole to fit the inverter and battery compartment 2 - Drilling some holes in soles for wires in the sole 3 - Drill a hole & enlarge the side panel for the side lighting 4 - Cut a tiny hole at the back of the upper back of the shoe for the wire to run through the strap for the NIKE logo 5 - Loosing the inner sleeves of the shoe to run wire into the shoe RESULTS: GAGAGAGAGA...... Clean and welcoming for the feet!!! ![]() Under the hood where the MAGIC happens!!! (STILL CLEAN for Battery Replacement) ![]() ![]() Side Leds in all its GLORY!!!! ![]() 4 - Applying all the details (THE FUN PART as its the EASIEST!!) ![]() 5 - RESULTS: McFly to Nike MAG!!! 1 - Leather PVC for the Strap 2 - Leather PVC for the Nike Tick logo 3 - Back Strap holder pads is glued with Velcro each side to hold in place (Removable) 4 - Battery last up to 4-5Hrs (Replace battery no charging required) 5 - Switch ON/OFF is hidden and easy access 6 - Took me forever but its worth it, its COMPLETE! ![]() Conclusion I guess this is what I am capable of doing AT ITS MAXIMUM it was really tiring doing or even thinking about it... from the tiny tiny details to the big ones... but I'm satisfied!! I wish I can EL Panels to improve on it especially for the sole then it will be the closest to the Nike Mag as of now I'm sticking to to this.. but my Circuit (Mark 1) with the improvements on (Mark 3) will be able to do the job for that conversion for anyone for wishes to apply it. For any questions please feel free to comment on this thread or PM me! FYI - I will be supplying the complete 'MAG Lighting System Kit" for anyone who is interested pls check under junkyard soon! UPDATE: 23rd Nov Proper 4 strap seam at the front.. ![]() 4 band strap ridges at at the sides going all the way round.. ![]() Best of all its wearable, wireless & battery access! ![]() DAY & NIGHT LOOK! ![]() UPDATE: 11th Dec Toe Correction!! ![]() UPDATE: 19th Dec Ribs and Swoosh Improvements ![]() ![]() UPDATE: Overall Look after Upgrades ![]() ![]() ![]() LATEST UPDATE: 23rd Dec EL IMPLEMENTATION!!!! ![]() ![]() Let there be light!!! For our MAG soles!!! ![]() ![]() ![]() UPDATE: 27th Dec Tongue Upgrade!! This makes the tongue whiter and less easily stained ![]() ![]() THANKS FOR VIEWING!!! ![]() S02Customs 2nd RUN: Nike MAG Last edited by S02; 05-12-2012 at 11:43 PM. Reason: Latest Upgrades!! |
RPF Sponsors
#2 |
Formerly dobbyisfree
Re: Nike McFly to 2011 Nike MAG (My Conversion)
All I can say is wow. Fantastic job!
#3 |
"Genital Cuff" creator
I LOVE THE 4 LED's per color!!!! The Hot Glue is a brilliant idea. I would love a detailed diagram of your LED/EL sheet installation.
Very cool! |
#4 |
Really really impressive dude! The first pic I saw of these was the final one you posted in another thread, and I did a double-take because I thought they were the real mags for a second. Besides the 4 LEDs for the side "battery indicator," it's amazing the psychological effect of raising the strap higher than the Markpoons originally have it. And of course the longer swoosh helps too. I'll keep an eye out for your lighting kit. Definitely interested in that.
#5 |
BWAH!
Those look awesome! Great job!
#6 |
Thanks!! I really wanted the MAG but just couldn't for now... thus the motivation and will went into the creation of these...! I'm Happy
![]() Glad yall happy too and thanks for the complements and viewing!! |
#7 |
My Nike Mag on feet!!
#8 |
Wow. Again, fantastic job!
#9 |
#10 |
Hi S02,
Great job on the conversion! Looks great! |
#11 |
Thanks guys... but the surprise does not stop there... there is more improvements I've made... both functional and cosmetic changes.... will keep you guys posted..
#12 |
I need el panel for this to be accurate!
#13 |
Are you going to be doing any conversions??? PLEASE SAY YES!!!!!!!
#14 |
yup I will.. just that.. I'm working on a finish shoe right now... what ur seeing is ard 90%..
once its completed your check out junkyard
#15 |
Excellent job so far, keep it going! That paint job on the sole is almost perfect, and the one thing that makes a difference here over Marks amazing first effort, is that the strap is in the correct place. If you could rework the shoe like Brads with the less shiny and sponge-like silver material and have a more accurate clear rubber over the LEDs, it's there!!
#16 |
#17 |
an updated version is coming
![]() I got 2 more mission to do and TADA!!! Wish me luck! |
#18 |
#19 |
LOL.... i heard that quote before!!! hhmmm from which movie...
#20 |
#21 |
hey SO2
bro if i buy 1 pair can u help me do the conversion? |
#22 |
Good work. I love the BTTF movies.
#23 |
Updated cosmetics for a customer!!
#24 |
amazing,just amazing.
pm sent mate. i was sent here by mark poon. |
#25 |
PMed & Updated!!!
Want to get it? Check it at my junkyard link below, http://www.therpf.com/f13/nike-mcfly...0/#post2026675 |
