Subscribe
  1. GuntahKela's Avatar
    Member Since
    Nov 2000
    From
    behind you, Ray!
    Messages
    6,019
    Jun 18, 2008, 6:14 PM - Name of green body-filler (not bondo) used for boat/car repair? #1
    After years of using the pink Bondo filler mix, I'm ready to venture into more competitive body fillers, and, vaguely, they keep recommending me the green filler. Does anyone know what's its name? I've seen it used in all of those Discovery channel garage shows.
  2. Member Since
    Jun 2001
    From
    Maine
    Messages
    980
    Jun 18, 2008, 6:34 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #2
    I've used it many times. I've never payed any attention to the name.
    Look up an auto body supply shop in the yellow pages or even a napa.
    Ask them for the green body filler. They'll hook you up.
    I wish I could get you a name, but my buddy gives it to me and by the time I get it the bottle is trashed and the label has rubbed off.
    The great thing about the green stuff is it comes in a sealed can with a squeeze top lid. It's like a soap dispenser for bondo. LOVE IT.
    GuntahKela said: View Post
  3. RPF Premium Member thorssoli's Avatar
    Member Since
    Dec 2005
    From
    Petaluma
    Messages
    1,420
    Jun 18, 2008, 6:42 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #3
    If I remember right, there is a glassfiber-reinforced body filler that comes in green.
    It is made by a company called "Bondo." Really. It's the same people. They actually make a few hundred different filler compounds used in everything you can think of.
    You should be able to find it in most automotive supply shops. It'll be next to the Bondo. It's called "Bondo-Glass." If not, go to West Marine and look for "structural filler" of "fiber reinforced" filler.
    The stuff is a bear to sand, but it's stronger in the end.
    Hopefully this will help.
  4. RPF Premium Member thorssoli's Avatar
    Member Since
    Dec 2005
    From
    Petaluma
    Messages
    1,420
    Jun 18, 2008, 6:43 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #4
    Jack Knight1979 said: View Post
    Ooh, that stuff. I forget what that one is actually called. Not what I was talking about.
  5. Ghost Host's Avatar
    Member Since
    Jul 2002
    From
    California
    Messages
    3,193
    Jun 18, 2008, 6:47 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #5
    Duraglass? It is a Bondo product and also a filler. But it usually comes in a can like regular Bondo.
  6. Goldenrod's Avatar
    Member Since
    Apr 2003
    From
    deserts of tatooine
    Messages
    2,613
    Jun 18, 2008, 7:03 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #6
    Squadrons green putty. Theres also white. Comes in a tube,get it from Hobby shops.
  7. Master_Shake's Avatar
    Member Since
    Jun 2008
    From
    Bay City, Michigan
    Messages
    20
    Jun 19, 2008, 7:38 AM - Re: Name of green body-filler (not bondo) used for boat/car repair? #7
    I used to work in a body shop and it is duraglass.
  8. kdawg1's Avatar
    Member Since
    Mar 2002
    Messages
    783
    Jun 19, 2008, 9:32 AM - Re: Name of green body-filler (not bondo) used for boat/car repair? #8
    duraglass is what you are talking about. It's more like plastic and really sheds water.
  9. GuntahKela's Avatar
    Member Since
    Nov 2000
    From
    behind you, Ray!
    Messages
    6,019
    Jun 19, 2008, 11:30 AM - Re: Name of green body-filler (not bondo) used for boat/car repair? #9
    I will check out dureglass, but this is what I was talking about:
    http://www.e-bodyshopsupplies.com/in...ROD&ProdID=404
    My helmet painter uses it for his motorcycle body work. Now, if I can find a local dealer...
  10. Java's Avatar
    Member Since
    May 2002
    From
    The Great Midwest
    Messages
    1,225
    Jun 19, 2008, 12:51 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #10
    Yep, Glazing Putty.
    You can buy it at Napa.
  11. Member Since
    Dec 2007
    Messages
    102
    Jun 19, 2008, 1:48 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #11
    if you are still looking for a good filler instead of glazing putty, i HIGHLY recommend Rage Xtreme by Evercoat (yeah, i know its a stupid name, but the product is great) better than any filler i've ever used. It feathers great, no pinholes, sands great.
  12. GuntahKela's Avatar
    Member Since
    Nov 2000
    From
    behind you, Ray!
    Messages
    6,019
    Jun 19, 2008, 4:49 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #12
    My local Napa was no help. I found a dealer that carried Split-second, but their batch is all dried-up. Will have to get Half-time tomorrow. I hear is good, too.
  13. Master_Shake's Avatar
    Member Since
    Jun 2008
    From
    Bay City, Michigan
    Messages
    20
    Jun 19, 2008, 6:48 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #13
    Glazing putty is completely different than fiberglass filler. Putty cannot be used in thicknesses greater than 1/8 in. if I recall correctly. It is used to fill in small imperfections usually after priming.
  14. JDarko's Avatar
    Member Since
    Jun 2008
    From
    sheffield, UK
    Messages
    93
    Jun 20, 2008, 12:17 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #14
    master shake is right i heard the same from a friend of mine. for my two cents, i use a green car body filler called plastic padding elastic car body filler by loctite. Sands down is smooth, no pinholes and once set can be carved with a craft knife without having to saw at it! I'm in the UK, but if you can find it over there, its well worth it
  15. GuntahKela's Avatar
    Member Since
    Nov 2000
    From
    behind you, Ray!
    Messages
    6,019
    Jun 20, 2008, 12:36 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #15
    Right, I see. I guess I was looking for a more sophisticated finisher, but I ended-up learning about other brands mentioned here. I returnded the dried-up split-second and got "half-time" instead, for my primer/paint prep stage. Thanks.
  16. micdavis is offline micdavis
    Jun 20, 2008, 12:45 PM - Re: Name of green body-filler (not bondo) used for boat/car repair? #16
    A company called Evercoat makes "higher" end finishing products. Although for the life of me I can't see why for any prop related thing anything other than standard Bondo brand body filler and glazing putty would be needed.
    The high end stuff is usually used for creating super smooth finishes that require a super glossy finish.
Similar Threads
  1. problems with bondo (automotive body filler)
    koopatroop, Marvel Costumes and Props
    Last Post: Feb 9, 2015, 6:19 AM
  2. Better Than Bondo?! (body filler) iron man helmet
    Katarnar, Marvel Costumes and Props
    Last Post: Jul 7, 2014, 5:03 PM
  3. BODY FILLER / BONDO (Drying time...)???
    bounty treasure, Replica Props
    Last Post: Feb 26, 2013, 12:22 PM
  4. Quick question on bondo/body filler
    Meathead316, Replica Props
    Last Post: Jan 29, 2013, 12:06 PM
  5. Body Filler / Bondo / Other Alternatives???
    Last Post: Aug 28, 2009, 1:55 PM
