1. Warlord of Barsoom SurferGeek's Avatar
    Join Date
    Feb 2002
    Location
    Helium of Mars
    Message Count
    5,869
    Oct 19, 2008 - Help finding correct part... #1
    I'm looking for a specific type of nut for a project. It's a brass acorn nut, sometimes also referred to as a cap or dome nut. I've been able to find a wide variety of nuts but none with the specific details I'm looking for.
    The "dome" portion of the nut needs to have ribbing or fluting. I've even looked for lamp finials but that produced little help.
    Here's a picture of a basic acorn nut.
    Google "acorn nut" and brass to see more examples. As for the detail I'm looking for is fluting on the dome section. Looking down on the nut the fluting would radiate out from the center like the hands of a clock... does that make sense?
  2. Join Date
    Nov 2000
    Location
    Earth
    Message Count
    5,866
    Oct 19, 2008 - Re: Help finding correct part... #2
    Makes perfect sense to me.
    I would keep looking at lamp hardware or electrical hardware.
    I go to work at Lowes today, and I will keep an eye out for you.
  3. gunnerk19's Avatar
    Join Date
    Jan 2004
    Location
    Northfield, Vermont
    Message Count
    1,705
    Oct 21, 2008 - Re: Help finding correct part... #3
    Fluting that looks kind of like the crimping on a .22 blank round? I know what you're talking about, but danged if I can remember where I've seen them used...
    Come to think of it, I believe the ones I remember seeing weren't 100% brass, but maybe a Delrin or Nylon nut with a thin, brass plate covering that may have been "fluted" (as it were) to allow for the material underneath to expand with pressure from the bolt?
  4. Warlord of Barsoom SurferGeek's Avatar
    Join Date
    Feb 2002
    Location
    Helium of Mars
    Message Count
    5,869
    Oct 23, 2008 - Re: Help finding correct part... #4
    gunnerk19 said: View Post
    Closer to the first description. Definitely not a hollow variety, at least not from what I can tell from the small image I have of it.
    Here's the best image of the type of acorn nut I'm looking for...
  5. tango'd fett's Avatar
    Join Date
    Feb 2004
    Location
    London UK
    Message Count
    426
    Oct 23, 2008 - Re: Help finding correct part... #5
    These sort of nuts are used on the back of letterboxes that fit on entrance doors so you may have some luck trying door hardware suppliers or manufacturers.
Similar Threads
  1. Replies: 25
    Last Post: Nov 6, 2011, 5:37 PM
  2. Need Help Finding Larger Quantity 2 Part Epoxy
    Graphic Jordan, Replica Movie Costumes
    Last Post: Aug 7, 2011, 8:10 PM
  3. Help Needed in Finding Last Part for Prop
    bobatrek, Replica Movie Props
    Last Post: May 22, 2011, 12:00 AM
  4. Replies: 16
    Last Post: May 7, 2011, 11:36 PM
  5. Correct resin?
    deathscythe, Replica Movie Props
    Last Post: Nov 11, 2006, 6:13 PM
1 2 3 4 5 6 7 8 9 10 11
