1. Join Date
    Dec 2010
    Location
    Monterrey, Mexico
    Message Count
    10
    Aug 3, 2011 - Half scale Lightning McQueen help #1
    Hello all!
    I made a 8.5 feet long fiberglass replica of Lightning McQueen. I intended to make it R/Ced but my current set up doesnt work properly (electtronics-wise). I need an electronics wizard to help me up with this. I will post pics and more info on my setup ASAP. Anyone???
    Thanks!
    Harley
  2. Join Date
    Dec 2010
    Location
    Monterrey, Mexico
    Message Count
    10
    Aug 3, 2011 - Re: Half scale Lightning McQueen help #2
  3. Join Date
    Dec 2010
    Location
    Monterrey, Mexico
    Message Count
    10
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #3
    BTW, with the first aniversary of my first and only child coming up, I tought this car would be the perfect gift for him, that΄s why I made it
  4. Daddy Solo's Avatar
    Join Date
    Mar 2011
    Location
    NY
    Message Count
    73
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #4
    that is amazing! can't help with the electronics , but I just wanted to say "strong work"
  5. hankey01's Avatar
    Join Date
    Jun 2006
    Location
    High River (Smallville), Alberta
    Message Count
    1,483
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #5
    Wow..thats great! I can't help but I'm impressed by your work!!!!
  6. Join Date
    Oct 2010
    Message Count
    69
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #6
    What are you currently using to try to run it, electronics wise?
  7. Join Date
    Dec 2010
    Location
    Monterrey, Mexico
    Message Count
    10
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #7
    Well, I purcgased a small RC Car, disassembled it to get the receiver board and after I located the wires with the control signals, connected them to an array of relays, to feed the main 12v motors
  8. jaybible's Avatar
    Join Date
    Jul 2011
    Location
    Perth
    Message Count
    352
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #8
    Wow thats a big R/C!!!.. what are you using to run it atm?? do u have any pics of the car without the shell on?
  9. Join Date
    Oct 2010
    Message Count
    69
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #9
    Harley5745 said: View Post
    What is the issue you are having? If it's sluggish response, it could be due to using the Relays, look into Mosfets to fix that.
    If you're getting weird things happening it could be because your motors are not shielded enough, all motors produce RF interference and several 12v ones running could do weird things to your control signal.
  10. Join Date
    Dec 2010
    Location
    Monterrey, Mexico
    Message Count
    10
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #10
    MiDri said: View Post
    Well, the thing is that everything works perfectly with the car on stands, then when I try to "drive" it on the floor, the motors work whenever they want LOL, I think it is because vibration. You see, altough I posess basic electronics knowledge (i.e. I know what + and - signs mean) I think some voltages or amperages arent right.
  11. exoray's Avatar
    Join Date
    May 2003
    Message Count
    5,847
    Aug 5, 2011 - Re: Half scale Lightning McQueen help #11
    My advice get some proper radio equipment, that is a lot of car to go shooting down the road if something goes wrong...
    May I suggest you find some RC forums and investigate what they are using for 1/4 scale models as I know there are 1/4 scale enthusiast out there so the info is out there as is the equipment... Once you get a decent 1/4 radio setup the rest should fall into place... The actual radio equipment is the same for any scale, it's just the interface to the larger control systems on the car that varies drastically between scales...
  12. Join Date
    Oct 2010
    Message Count
    69
    Aug 6, 2011 - Re: Half scale Lightning McQueen help #12
    get some pics up of your setup with out the shell, as detailed as possible so we can see the wiring and maybe we can help.
  13. Join Date
    Dec 2010
    Location
    Monterrey, Mexico
    Message Count
    10
    Aug 8, 2011 - Re: Half scale Lightning McQueen help #13
    Well guys, I have not had the time to crawl under the car to take the pics of the electronics. I΄ll try to take them tomorrow.
Similar Threads
  1. Lightning McQueen - custom
    Trek920, General Modeling
    Last Post: Mar 18, 2013, 11:39 AM
  2. IM: Mark 1 Half scale full statue WARNING IMAGE HEAVY
    sinigang, Sculpture and Makeup Effects
    Last Post: Jun 29, 2012, 6:34 AM
  3. Studio Half Scale TOS Enterprise Scratch build
    SteveNeill, Studio Scale Models
    Last Post: May 1, 2012, 10:20 PM
  4. Warmachine half scale work in progress
    sinigang, General Modeling
    Last Post: Mar 29, 2012, 11:11 PM
  5. Freddy VS Jason and Half Scale Alien
    Tandiono, Replica Movie Props
    Last Post: Apr 17, 2010, 3:04 AM
1 2 3 4 5 6 7 8 9 10 11
