Page 6 of 7 FirstFirst 1234567 LastLast
  1. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    May 23, 2012 - Re: Death Star door control panel #126
    I was able to find 2 3/8 inch DoRay lenses. Part # 2029
    http://www.taillightking.com/misc_lights_Red_Round.htm
    I'm searching the site to see if they're available in other colors. I've also been in contact with "The Taillight King" and I've asked what is available. I should here something soon
  2. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    May 27, 2012 - Re: Death Star door control panel #127
    Hey Gang... A temporary solution...
    So... what happens when you take a simple door stop and combine it with a set of simple reflectors?
    The reflectors fit NEAR perfectly! There is a tiny bit of play but nothing that cant be fixed with a good adhesive (or you could cut the rubber stopper to fit and press against the reflector - that would minimize the amount of the light). There is sticky tape attached to the backside but can be easily removed and then shine a light through?
  3. Rebelscum's Avatar
    Join Date
    Apr 2007
    Location
    Dallas / Fort Worth, Texas
    Message Count
    1,110
    May 27, 2012 - Re: Death Star door control panel #128
    Looks like a very acceptable found part stand-in for the real lights.
  4. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    May 27, 2012 - Re: Death Star door control panel #129
    Various images of the panel light in action!
    Profile
  5. Rebelscum's Avatar
    Join Date
    Apr 2007
    Location
    Message Count
    1,110
    May 27, 2012 - Re: Death Star door control panel #130
    Looks good. I think they only issue is they are larger than the ones used, which I believe were about 2" diameter.
  6. Skaught's Avatar
    Join Date
    Feb 2002
    Location
    St. Pete
    Message Count
    3,269
    May 27, 2012 - Re: Death Star door control panel #131
    I may go that route for my CVI set. Thanks!
  7. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    May 27, 2012 - Re: Death Star door control panel #132
    Skaught said: View Post
    You're very welcome!!! I would suggest going to Home Depot for the stoppers. Lowes did not have a very good selection.
    I found the reflectors at Lowes so I'm not sure if the Depot has them.
    Here they are in various colors
    Good luck!
  8. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    May 27, 2012 - Re: Death Star door control panel #133
    Rebelscum said: View Post
    Good news! They are 2 1/4" wide so they are VERY close. And if Canobi can replicate a dome style lens...
  9. Wavey's Avatar
    Join Date
    Dec 2011
    Message Count
    125
    Jun 1, 2012 - Re: Death Star door control panel #134
    I was hoping to of found the 'WB furnace' lens parts by now but just missed an auction for one before seeing this thread a while back (doh!). So, I've widened the search a little and, well, the Space 1999 variation reminded me of these two from Goldfinger...
    Also, on the inside of the nook device are a few more different sized types. Ok the lenses are different but you can see the key to finding the real parts is in the bezel with that under-cut - must be from the same company.
    WHAT!?!1!
    Oh! Then there's this shot from Goldfinger (I don't have the BluRay to hand), behind Q on the panel you see the same lenses affixed in a very similar way to the rear side of the Millenium Falcon's center console.
    I'm guessing these parts date back to around 1963-64 in this particular form and size, although they do seem to be ever so slightly larger. Would be nice to find them and get them used in these latest projects!
  10. MFP 2020's Avatar
    Join Date
    Nov 2009
    Location
    Surf City, USA
    Message Count
    671
    Jun 1, 2012 - Re: Death Star door control panel #135
    Just poking my head in over here. I haven't seen it mentioned (too obvious?), and I don't know if it's even helpful, but that's a fresnel lens. I guess if no one advertises it as such, then it's moot. So anyway...
    Taillight King looks like an awesome source. I did a quick look-around on eBay UK and came up with a possible:
    Ignition Red Panel warning lamp replaceable 12v bulb 18677 18678 18672 18674 186 | eBay
    (Looks too flat, though.)
    There's also this, but the lip on the lens, if it's exposed, is wrong.
    FIVE Panel Indicator Lamp Neon Red/Green/Amber 110V/240V/230V. UK SELLER | eBay
    Carry on!
  11. MFP 2020's Avatar
    Join Date
    Nov 2009
    Location
    Surf City, USA
    Message Count
    671
    Jun 1, 2012 - Re: Death Star door control panel #136
    OK, one more thing:
    Panel Warning Light | Auto Electrical Supplies
    I keep thinking it's from an industrial machinery panel. Surplus aircraft parts?
  12. deadbolt's Avatar
    Join Date
    Jun 2006
    Location
    Virginia
    Message Count
    609
    Jun 1, 2012 - Re: Death Star door control panel #137
    Wavey said: View Post
    WHAT!?!1!
    Hmm...although they look smaller, those do look very similar. That looks like it might be one of the more probable roads to check down now since we know aircraft parts were used in SW. Nice find!
    -Carson
  13. giric thren's Avatar
    Join Date
    Dec 2007
    Location
    Dallas, Texas
    Message Count
    110
    Jun 13, 2012 - Re: Death Star door control panel #138
    I work in a distribution office, and have to deal with semi trucks a lot. When I see those light caps it makes me think of Running Light covers.
    I took a picture of one, and even though this isnt the one, Im thinking that it was a vintage version of these
    It would make sense that they are running light covers because the bulb is on the trailer and not part of the cover, and since they get broken alot, they would be really cheap and easy to come by.
  14. TK5455's Avatar
    Join Date
    Apr 2010
    Location
    North York, Ontario, Canada
    Message Count
    45
    Jun 15, 2012 - Re: Death Star door control panel #139
    I'm kind of partial to these Arcade style buttons.
    http://www.ultimarc.com/ultralux.html
    But (if you had patience) you might find a larger and closer to correct item here.
    Switches, industrial switches, 8mm 16mm 22mm 30mm switches, pushbuttons, emergency stops, rotary and selector switches, indicators, sub-miniature, key-lock switches, rugged keyboards, PIN-entry keypads
    Their catalogue dosen't seem to have actual pictures but graphic representations.
  15. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    Jun 15, 2012 - Re: Death Star door control panel #140
    WOW - Those button from EAO are very close!
  16. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    Jun 15, 2012 - Re: Death Star door control panel #141
    Canobi is working on creating a dome lens to fit the door stoppers. I can't wait to see them! It will certainly bring these door stoppers to life!
  17. wannab's Avatar
    Join Date
    Mar 2007
    Location
    Anchorage, Alaska
    Message Count
    1,262
    Jun 15, 2012 - Re: Death Star door control panel #142
    robstyle said: View Post
    Wannab, the Peterbilt truck indicator lenses are too flat if I recall. The reason I bought a cache of the items in question was for a work project unrelated to this topic. Truck and emergency indicators were my second go after basic video game/pinball versions but lacked the height of vintage indicator lenses.
    My garage is jam packed and the weather isnt forgiving enough to tear things out to get to the area I think these are stored in.
    Okay robstyle, it's nice weather now. Get to digging!
    Doug
  18. Wavey's Avatar
    Join Date
    Dec 2011
    Message Count
    125
    Jun 15, 2012 - Re: Death Star door control panel #143
    Good work on modding the doorstops SofaKing01, best way to go at the mo and works great in the MF. I'm now plagued with these lamp lenses lol (they are reaching iconic status in their own light) - Two films watched today and guess what...
    Fahrenheit 451
    Journey To The Far Side Of The Sun
    Though the Far Side shows as slightly recessed bezel and all props where reused for UFO, could still be a lead. Hopefully something will jog someones memory at some point.
  19. Wavey's Avatar
    Join Date
    Dec 2011
    Message Count
    125
    Aug 8, 2012 - Re: Death Star door control panel #144
    Would appear that two years later the Daleks pinched Q's console for 'robotising' ops.
  20. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    Aug 8, 2012 - Re: Death Star door control panel #145
    The question I have... how come NOBODY can find these? There has to be some still laying around somewhere?
  21. Wavey's Avatar
    Join Date
    Dec 2011
    Message Count
    125
    Aug 8, 2012 - Re: Death Star door control panel #146
    I'm still on the lookout, just missed another possible sale of this - which is still about the closest available to my eyes.
    I will be mailing some peoples/companies in the next few days about these exact lens pieces - probably end up with a furnace lol.
  22. thd9791's Avatar
    Join Date
    Jul 2011
    Message Count
    1,011
    Aug 8, 2012 - Re: Death Star door control panel #147
    This is awesome, great job guys. With all the variations, IMO the Fahrenheit 451 lights are the closest to good Ol' star wars (from the pictures on here) - Now I see them everywhere haha Can't wait to see what you guys dig up, loving this thread
  23. SofaKing01's Avatar
    Join Date
    Apr 2010
    Location
    Huntsville, AL
    Message Count
    2,373
    Aug 8, 2012 - Re: Death Star door control panel #148
    I'm still on the lookout... I will be mailing some peoples/companies in the next few days about these exact lens pieces - probably end up with a furnace lol.
    Hi Wavey,
    I spent several months calling and emailing nearly 100 companies from the US to the UK to Australia with ZERO luck... Nobody could identify them at all. I hope you have better luck than I did. I've got my pompoms at the ready!
  24. ShogunLogan's Avatar
    Join Date
    May 2012
    Location
    Washington, DC
    Message Count
    12
    Aug 8, 2012 - Re: Death Star door control panel #149
    Hi all,
    Thought i would jump in and try and help locate these mystery parts.
    To me, they look a lot like indicator lights on a B-24 bomber from WWII. Because of the time and what Lucas had available to him, wouldnt suprise me if he had a stock of these things lying around.
    The buttons on the panel in yellow is a C-1 autopilot panel and the green is just a set of random indicator lights found scattered across the plane.
    Id say someone go to a local airshow and take a picture of the light with them...."Excuse me sir, those planes are cool n' all, but have you see this indicator light?" almost positive you would find a match
  25. thd9791's Avatar
    Join Date
    Jul 2011
    Message Count
    1,011
    Aug 8, 2012 - Re: Death Star door control panel #150
    oh fudge, that is soo plausible I'm at a loss for words. Not sarcasm either, I'm impressed
Similar Threads
  1. Replies: 82
    Last Post: Mar 27, 2013, 12:13 PM
  2. Luthor's control Panel....from Death Star?!
    hankey01, Screen-Used Movie Props and Wardrobe
    Last Post: Apr 18, 2012, 4:57 PM
  3. Is this worth $200? (Death Star Control Panel)
    Skaught, Replica Movie Props
    Last Post: Feb 29, 2012, 7:58 AM
  4. Star Trek door chime (replica door control panel)
    Mara Jade's Father, Replica Movie Props
    Last Post: Feb 8, 2012, 11:08 AM
  5. Death Star Control Panel FOUND!
    Dewback_Rider, Replica Movie Props
    Last Post: Jul 6, 2009, 10:21 AM
1 2 3 4 5 6 7 8 9 10 11
