the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > PROPS > Replica Movie Props
Any advice on a small project?
Discussion on Any advice on a small project? within the Replica Movie Props forum, part of the PROPS category; Hello! I'm working on getting a pair of these finished
Reply
LinkBack Thread Tools
Old 12-19-2011, 07:58 PM   #1
Rusty85's Avatar
Rusty85 has a reputation level greater than 10!
Hello! I'm working on getting a pair of these finished and would like to replicate this stand. I made one before using a cake pan as the base. I used poster board to cut out the rest the pieces and a dowel for the long pole part where the ear stems go. While it was nice it just wasn't all that sturdy and I'd like to make something a little more solid this time around. While the ideal route would be metal that's just impossible at this time.
The only tools I have are hand saws, a drill, and a few other select items. I have no access to any large saws to cut wood with. Just thought I'd throw that out there to tell you what I'm working with.
Here's a few photos, advice is appreciated.
Rusty85 is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 12-20-2011, 12:14 AM   #2
Rusty85's Avatar
Re: Any advice on a small project?
Anyone?
Old 12-20-2011, 12:54 AM   #3
Maelstrom's Avatar
Maelstrom has a reputation level greater than 100!Maelstrom has a reputation level greater than 100!
Which part are you concerned about replicating the base, the stand, or the entire thing?
Maelstrom is offline   Reply With Quote
Old 12-20-2011, 01:05 AM   #4
Rusty85's Avatar
Probably just being able to cut the X out of something hard without any large saws. Seems like it'll be the trickiest part because its rounded.
Old 12-20-2011, 01:17 AM   #5
Shylaah's Avatar
Shylaah has a reputation level greater than 100!Shylaah has a reputation level greater than 100!
Well, I'm just going to sling some ideas around......
I know the feeling when you don't have the tools, and in my
case I don't want or have space for such tools and wouldn't
use them that often otherwise. But I digress......
I am guessing this is about 10 to 12 inches in diameter....
I think the black bottom part you might could use a terracotta
dish garden container or pot saucer, flipped over and painted.
They come in a variety of sizes and in clay or plastic.
Might also find something suitable in the kitchen wares,
a round casserole or baking dish, maybe even a plastic
serving dish.....another metal cake pan.....
As for the silver part and the vertical piece, what I would use
would be some balsa wood. All you need is an Xacto knife and
some sandpaper!
What is that about 3/8 inch thick?
Use the 1/8 inch thickness and cut out and glue together
three layers to make a laminate thick enough, or whatever
thicknesses of the balsa to make three layers to equal the
thickness you need.
Sand and use wood filler and sand till all is smooth and paint it.
It would be sturdy and not subject to "sudden crimp" like cardboard.
Or you might be able to use some kind of plastic that you could cut
and glue together--again would just need and Xacto knife and some
sandpaper....not sure what kind of plastic or how sturdy it would be??
Shylaah
Shylaah is offline   Reply With Quote
Old 12-20-2011, 01:20 AM   #6
robstyle's Avatar
robstyle has a reputation level greater than 200!robstyle has a reputation level greater than 200!robstyle has a reputation level greater than 200!
If you have already made a master (your first incarnation) all you really have to do is mold and cast it. If thats too expensive or out of your abilities, do a scale print out and take it to a metal fabrication/welding shop and get some quotes. You can cut it out of plastic as well.
robstyle is offline   Reply With Quote
Old 12-20-2011, 01:32 AM   #7
Maelstrom's Avatar
The X I would do in some kind of plastic. In my case the preferable one would probably be Sintra. This way it can be cut with a utility knife, edges cab be easily smoothed with sandpaper and there is no wood grain to deal with.
I like the idea on the planter bottom, but maybe see if you can find one in plastic at someplace like Wal-mart or Garden Ridge. The terracotta one may be too fragile at some point when you need it to be strong (like an accident)
May be hard right now though with planter stuff being out of season.
Old 12-20-2011, 01:34 AM   #8
Rusty85's Avatar
Great thank you guys for the ideas! I think I might end up going with the plastic route, not quite as expensive as metal and a little more sturdy than Balsa wood. That was what I was thinking before but in the end I'd just rather not have to worry about it getting broken easily.
Old 02-20-2012, 04:48 PM   #9
thesyfyguy's Avatar
thesyfyguy has a reputation level greater than 10!
Your Props
or you could mold it out of clay and make a rubber cast out of it. then pour a plastic cast yourself. its not that hard to do.
thesyfyguy is offline   Reply With Quote
Old 02-20-2012, 10:22 PM   #10
cjvince's Avatar
cjvince has a reputation level greater than 10!
some sandpaper!
thickness you need.
Shylaah
I'm kinda in the same boat tool/skill wise as you are and Shylaah pretty much laid out how I'd do it.
Good Luck
Chuck
cjvince is offline   Reply With Quote
Old 02-20-2012, 10:57 PM   #11
zenix's Avatar
zenix has a reputation level greater than 10!
seems like a perfect piece to use a lasercutter for...
zenix is offline   Reply With Quote
Old 02-20-2012, 11:37 PM   #12
Insert Title Here
Wolfie's Avatar
Wolfie has a reputation level greater than 200!Wolfie has a reputation level greater than 200!Wolfie has a reputation level greater than 200!
the bottom part reminds me of those Tupperware burger stackers
Wolfie is offline   Reply With Quote
Old 03-29-2012, 09:44 AM   #13
thesyfyguy's Avatar
Your Props
well you could mold it out of clay, then make a silicone mold of it. and pour a plastic mold out of it.
Old 04-05-2012, 01:38 PM   #14
thesyfyguy's Avatar
Your Props
here is a photo of that base I was talking about. Just need to mold the lens support arm and cut the notch for it the base. Then I will ready to make the silicone molds for pouring. What do you think?
Old 04-22-2012, 06:37 AM   #15
thesyfyguy's Avatar
Your Props
here are some pics of the molds and one of the support arm. soon as I get the base mold fixedI will be ready to pour it. Will keep you updated.
Old 04-23-2012, 12:06 PM   #16
Rusty85's Avatar
Looks pretty good so far, can't wait to see how it turns out.
Old 04-23-2012, 05:28 PM   #17
thesyfyguy's Avatar
Your Props
Here is my first attempt at the base. I think I will have to remold it. The plaster of paris did not work the way I hoped it would.
Old 04-23-2012, 08:10 PM   #18
Rusty85's Avatar
Looks pretty good, just needs a little clean up.
Old 04-28-2012, 07:01 PM   #19
thesyfyguy's Avatar
Your Props
This one would take a lot of clean up. maybe this week or next when I can afford some rubber mold compound and liquid plastic. I will remake the mold in a two piece. It will take less plastic to make it and there will be a lot less clean up. Then I can go from mold to sand to paint a lot sooner. Will let you know when the materials come in for the next pour.
Old 05-10-2012, 08:38 PM   #20
thesyfyguy's Avatar
Your Props
here is the photos I told you about. As you see it takes a bit of work to create the base. But when it is molded out of plastic. this is what it will look like.
bulsa-platform.jpg   clay-cutout-top.jpg   cutout-top-ofplatform-x3.jpg   x-template-clay-top.jpg   x-cutout-clay.jpg
Old 05-10-2012, 08:49 PM   #21
Rusty85's Avatar
Funny how something so simple can be such an undertaking. Looking great can't wait to see it finished!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bungled Aluminum machining - advice needed for Amiga Lamp Project! lucifred General Modeling 9 12-29-2010 12:06 PM
Huge project...but want to start small neojacksparrow Replica Movie Props 15 03-29-2010 11:58 AM
Painting and project advice needed. Cthulhu Embryo hydin Replica Movie Props 4 07-06-2008 12:09 AM
Fencing lightsaber project-need foam/resin advice Jumpin Jax Replica Movie Props 0 08-18-2007 04:36 PM
Need Help - Small Custom Project Box Darth_Nickel Replica Movie Costumes 1 04-10-2007 08:17 PM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
