1. PTK is offline
    PTK
    Join Date
    Dec 2007
    Message Count
    104
    Dec 15, 2007 - 50 cal. Machine gun....not a movie prop, but a prop none-the-less #1
    welp, obviously this wasn't in any movie or anything. Just a prop i built back in college. Let me know what you think
    It's a 5'4", 50 pound, shoulder-slung 50 caliber machine gun. When you pull the trigger it really ejects 50 caliber shells out the side, and has CO2 powered blowback action for the cocking handle (yeah i know real 50s don't have blowback like that but i thought it looked cool) the blowback is so powerful . It has a weight on an offset cam that shakes the gun when fired and it has the option of propane adapter instead of co2 and the exhaust ports of the valve run down to the barrel with an electronic grill lighter.....but i've never had the balls to try it with propane, in fear of dying or burning my beloved 50
    It obviously isn't supposed to be based on a real M2 or anything, i was going mor for a post apocalyptic Mad Max type of feel........like it was ripped off of a jep and modified and pieced together.
    Here's a pic:
    and my girlfriend is a photographer so we did a few photoshoots with some friends of ours..
    here's a pic of the guts:
    and here's a slideshow/videos:
    PTK's 50 cal
    Last edited by PTK; Dec 16, 2007 at 6:04 AM. Reason: some of the pictures stopped showing up
  2. KevVader's Avatar
    Join Date
    Apr 2005
    Location
    Ottawuh, Canaduh!
    Message Count
    3,698
    Dec 15, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #2
    I like big guns!
  3. Banned
    Join Date
    Feb 2001
    Location
    Edmonton, AB
    Message Count
    2,359
    Dec 15, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #3
    That is awesome! Very good work! What's it powered by?
  4. Gojira61's Avatar
    Join Date
    Mar 2000
    Message Count
    1,579
    Dec 15, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #4
    Very cool, nice work.
  5. PTK is offline
    PTK
    Join Date
    Dec 2007
    Message Count
    104
    Dec 15, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #5
    KingNothing said: View Post
    the shell ejection is powered by a cordless drill motor and some rechargable batteries, and attatched to the chamber that ejects the shell is a gear with a tooth for every shell chamber, so every time a shell is ejected, the gear teeth tap a momentary contact switch that goes to a solenoid valve that reverses the direction of the CO2 (form a 9oz paintball co2 tank) which activates the slide causing the blowback action
  6. DavidS's Avatar
    Join Date
    Apr 2005
    Location
    South East
    Message Count
    1,768
    Dec 15, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #6
    can i have her number?
    oh yeh... nice gun!
  7. PTK is offline
    PTK
    Join Date
    Dec 2007
    Message Count
    104
    Dec 15, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #7
    oh, and as for materials:
    main barrel is gas pipe
    flash hider is a straight gas pipe connector and part of a beer keg tap
    barrel shroud is abs pipe with acrylic spacers inside
    main body is wood, with black acrylic cover panels
    ammo door is aluminum
    front sight, clean internal ejection gears are laser cut acrylic
    main bullet chamber is pvc pipe
    cocking handle is aluminum,
    cocking handle slide is a drawer pull/slider
    bullet shells are real 50 cal brass
    bullet tips are cnc lathed aluminum (i wanted bigger, longer, pointier bullets than real 50 cal ammo)
    and a bunch of misc hardware, bolts, handles, screws, switches, pneumatic cylinder, batteries, etc
  8. PTK is offline
    PTK
    Join Date
    Dec 2007
    Message Count
    104
    Dec 15, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #8
    David Stokes said: View Post
    oh yeh... nice gun!
    maybe we could work something out.......what props do you have to trade?
  9. jcoffman99's Avatar
    Join Date
    Jun 2006
    Location
    Western Maryland
    Message Count
    2,034
    Dec 15, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #9
    KevVader said: View Post
    I like big guns!
    ..and I can not lie. You other brothers can't deny...
  10. sctcarts's Avatar
    Join Date
    Jul 2006
    Location
    Pueblo, CO
    Message Count
    327
    Dec 16, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #10
    That's just damn incredible...and beautifully planned and built! Well done!
    -sctcarts
  11. PTK is offline
    PTK
    Join Date
    Dec 2007
    Message Count
    104
    Dec 16, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #11
    sctcarts said: View Post
    -sctcarts
    thanks sctcarts!......bt beautifully planned? certainly not! i would do it 100% differently if i had to redo it, (especially a welded steel frame and aluminum panels instead of the thick wood and acrylic i used)....very little planning involved, i was just really excited and motivated, i built the mechanisms first and once i had all of those working, i built the frame to accommodate that......pretty bass ackwards design but thanks very much for the kind words!
  12. DavidS's Avatar
    Join Date
    Apr 2005
    Location
    South East
    Message Count
    1,768
    Dec 16, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #12
    PTK said: View Post
    dood, take my whole collection, its be an even trade!
  13. High Flyer Darth Mawr's Avatar
    Join Date
    Apr 2005
    Location
    Birmingham, AL
    Message Count
    970
    Dec 16, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #13
    Now, THAT is a BFG! Great Job!
  14. Aluke123's Avatar
    Join Date
    Dec 2007
    Location
    Washington State
    Message Count
    52
    Dec 18, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #14
    That thing is sweet. Get a video of firing it with propane
  15. JoblessPunk's Avatar
    Join Date
    Mar 2007
    Location
    Rohnert Park, CA
    Message Count
    278
    Dec 19, 2007 - Re: 50 cal. Machine gun....not a movie prop, but a prop none-the-less #15
    PTK said: View Post
    lololol
    that a pretty sweet prop, nice pix!
Similar Threads
  1. M93R prop movie gun collection
    bothanspy, Replica Movie Props
    Last Post: Feb 12, 2013, 7:07 PM
  2. Replies: 231
    Last Post: Dec 20, 2012, 10:45 PM
  3. Replies: 21
    Last Post: May 2, 2012, 9:21 PM
  4. Prop machine gun help
    Mr. Nagata, Replica Movie Props
    Last Post: May 14, 2009, 5:39 AM
1 2 3 4 5 6 7 8 9 10 11
