So I've been lusting after one of these babies ever since I found out that they existed; I entertained the thought of getting an eFX reveal since they were a less expensive option and because of the light-up feature, but ultimately all of you on here who own one swayed my decision with all of your rave reviews about the quality and craftsmanship of the Rylo.
Fast forward to a few weeks ago... Eureka! I managed to pick one up in the Junkyard... and an AP to boot!
BUT (why is there always a 'but'?) it's unassembled and unpainted. Now for many of you talented folks this probably isn't that big of a deal, but for me, let's just say that the extent of my prop making skills was building old MPC X-Wing models when I was a kid and unfortunately doing a ****-poor job of them at that... and that was just the gluing them together part!
Fortunately assembling it shouldn't be too much of an issue since a lot of it is fairly self evident and even a novice like myself can probably stumble my way through it (read: idiot proof!).
But, I do have LOTS of questions and will need a fair bit of advice so I thought I'd ask the experts. Here goes....
1) Painting the 'grenade', connecting stem, activator plate, and control box buttons
3) The crystal chamber
4) The finish
I think that's it... but if I think of anything else I'll be sure to add to the list. Any help or advice that any of you can give me would be very much appreciated!
Thanks!!!
- I asked Rylo himself and he painted all of the completed sabers that he made in his run while Darth Detroit (whom I bought the saber from) said that he had his parts anodized and wet-sanded the high points for his personal reveal.
- Is one method 'better' than the other or is it just personal choice?
- Is there a way of 'selectively' anodizing sections of a piece or is it all or nothing and having to sand down the high points as Darth Detroit did with his? Is it difficult to rub/sand off anodized pieces?
- If I opt for the painting option, do I need to prime the pieces first? Do I have to wait for the paint to fully dry before I acetone off the high points, or is this an immediate thing that needs to be done?
- Connecting stem (the part that connects the grenade to the brass stem): to be prop/screen accurate, is the underside of the of the round plate completely painted, or is it just the stem and the first 'lip'? I've seen pictures of it both on the RPF and online being painted both ways.
- What's the best method of attaching the brass activation plate mount to the control box - epoxy or something else?
- What's the best method of attaching the control box buttons - again, epoxy or something else? I was also contemplating taking it to a machinist and having both the buttons and the control box drilled so that I can have the buttons mounted by a pair of small screws - would that be a viable option?
- The reveal foam "circuit board": for those of you that have a completed reveal, is this piece glued down or is it loose? Or does it secure to the control box bottom in some other way that I'm missing?
- Are there any cool or obvious simple mods that I can be made aware of to the control box; i.e. lighting the arrows (which of course would require more machining), etc.?
- How is the crystal secured in the chamber, is it glued down? Is there a more elegant method of securing the crystal?
- Are there 'better' crystals out there to use for the chamber?
4) The finish
- To polish, or not to polish, that is the question! Would a polished Luke ROTJ look 'wrong'?
- And if I do choose to polish it, what's the best method of polishing/buffing machined aluminum? I believe I read somewhere to use fine steel wool, would this be the best method?
Thanks!!!
