Holy moly its been over a year since I last posted in this thread.
Time to bring things upto date.
I finally got a body cast and a full head and neck life cast done. Was a tricky one as my buddy who did it had no experience before so it was kinda like the air traffic control tower talking an airliner down with a passenger at the controls! lol
The casts are not perfect but with a bit of clean up were close enough to make use of.
Started on the sculpt for the silicone mask first. Using Plastiline 55 I sculpted something that was a bit RayPark, a bit original concept art and a bit me.
Once I was done it was straight into the mould.
While the cast was setting I sculpted up some horns and made the silicone mould for those.
I sculpted two different versions that could be used in different variations. I then cast the horns in somme cold cast resin adding some glass micro balloons to keep the weight down.
When the main mould was cleaned out I cast up a a rough latex version. I like to do this to see If there are any issues with the sculpt or mould thickness before pouring a couple of hundred Euros worth of ecoflex into it. Plus it would look good as a bust sitting in the workshop, so I back filled it with foam.
I was relatively happy with the rough so I proceeded to go for an ecoflex silicone version. First I reinforced the delicate area with power mesh and stocking material.
While the ecoflex was setting I painted the latex head up in the customary Sith tattoos.
Then added a set of horns.
Must say I was fairly happy with it but I'll wait and see how the silicone version performs first....
