Subscribe
  1. Member Since
    Dec 2011
    Messages
    78
    Jan 20, 2013, 8:33 AM - Judge Dredd Pads( HELP ) Shoulder Pads Mounting Techniques #1
    Hey guys! Im almost finishing assembling the two parts of my Dredd shoulder pads. Im looking for idea, and sugestions for the mounting on the jacket! I downloaded a pic just to give you an idea on what i want. Please any help would very welcome!
    Thanks Judges!
  2. tango'd fett's Avatar
    Member Since
    Feb 2004
    From
    London UK
    Messages
    427
    Jan 20, 2013, 10:21 AM - Re: Judge Dredd Pads( HELP ) Shoulder Pads Mounting Techniques #2
    What's the shoulder pad made of and how heavy is it ?
    If its very light you could use Velcro stitched to the jacket and glued to the armour .
    On my comic version I did a few years back it was pretty heavy so I had to bolt it through the leather and have a plate inside the jacket .
  3. Member Since
    Dec 2011
    Messages
    78
    Jan 20, 2013, 10:29 AM - Re: Judge Dredd Pads( HELP ) Shoulder Pads Mounting Techniques #3
    Velcro its good. The piece will be ligth, i will put the resin with 3 coats inside and outside. It wont be heavy this i know. Actually i was thinking on some technique to move my arms freely. But i guess velcro is my first option.
  4. Member Since
    Dec 2011
    Messages
    78
    Jan 21, 2013, 2:02 PM - Re: Judge Dredd( HELP ) Painting techniques!!! #4
    This is my last update, i finished assembling the parts of the left and rigth armor of my comic version Dredd. Still a few parts are left to touch! But the atention is now on the paint job. I dont know wether paint them YELLOW or GOLD. But since in the comics the armor is just yellow ill be going in that direction. If anyone has a sugestion on doing a good paint job on this it will be most welcome!
  5. baron von blondle's Avatar
    Member Since
    Jun 2008
    From
    In Trouble
    Messages
    436
    Jan 21, 2013, 2:03 PM - Re: Judge Dredd Pads( HELP ) Shoulder Pads Mounting Techniques #5
    GOLD!!!
  6. tango'd fett's Avatar
    Member Since
    Feb 2004
    From
    London UK
    Messages
    427
    Jan 21, 2013, 4:31 PM - Re: Judge Dredd Pads( HELP ) Shoulder Pads Mounting Techniques #6
    Yep definately gold , have seen a yellow one done and it doesn't look right in the real world.
    Get them prepped and sanded and just use automotive car paints , grey primer and then gold. You could even clear laquer them after depending on how deep a shine your looking to achieve .
  7. Dargas's Avatar
    Member Since
    Sep 2010
    Messages
    86
    Jan 22, 2013, 2:45 PM - Re: Judge Dredd Pads( HELP ) Shoulder Pads Mounting Techniques #7
    Be careful with the clear lacquer though... some may "plastify" the metallic shine on most metal paints. Bright Aluminum for example turns to a sickly plastic silver when clear lacquered over.
  8. Member Since
    Dec 2011
    Messages
    78
    Jan 29, 2013, 5:23 PM - Re: Judge Dredd COSPLAY Progress( HELP ) VISOR! MORE PICS OF MY PROGRESS! #8
    Here is my last progress on my cosplay! I need help on where can i get a visor for my helmet! Thanks! Sugestions are very welcome!
  9. Dargas's Avatar
    Member Since
    Sep 2010
    Messages
    86
    Jan 31, 2013, 11:10 AM - Re: Judge Dredd Pads( HELP ) Shoulder Pads Mounting Techniques #9
    well.. you're doing the comic version... you could try and replicate the way I did my own visor.
    I bought a face shield, one of those cheap one's in home depot. I cut it in 2 (the 2 the same length but one is less wider than the other) and removed the plastic coverings (the greenish flimsy and the clear flimsy) that the main shield comes with
    I glued the main (bigger one) one to the helmet and the smaller one what I did was to stretch a pantyhose over it to the very limits of it's stretching capabilities and then I added glue (superbonder-flex) to the borders. Once dry I cut around the borders where I had glued the fabric to the plastic and removed the extra fabric. I only allowed one side with the fabric. I then glued this back visor behind the main one making sure I left a line of main visor untouched on the low end for the comic trasparent line where you can see the judge's nose.
    hope that helps
Similar Threads
  1. DREDD 3D:  Dredd Costume Help! - Armour & Shoulder Pads
    dannycronin, Judge Dredd Costumes and Props
    Last Post: Jul 13, 2015, 5:30 AM
  2. Cloud strife shoulder pads
    jackopalkia, Replica Props
    Last Post: Mar 6, 2015, 1:08 PM
  3. MK - Scorpions Mask and Shoulder Pads
    Twisted6, Replica Props
    Last Post: Oct 29, 2012, 11:59 AM
  4. Replies: 5
    Last Post: Sep 24, 2012, 1:38 PM
  5. Tron Shoulder Pads
    MrSinistar, Production Made Costumes and Props
    Last Post: Jun 1, 2010, 3:23 AM
