Why Thank you, Anibal. Coming from someone with the humor and creativity to create that Vader/Lecter mash-up, I will take that as high praise
Here is a picture of it (although I'm embarrased to have to show you all this unworthy offering. In FACT, after hearing from all of you, I'm now thinking of trying to turn it into some sort of surf/skateboard, or perhaps a key-chain holder/spare change bowl, or MAYBE a even a mailbox!).
And BEFORE anyone chimes in, let me nip it ALL in the bud and say that "YES, I know that------------",
1) a) Spider-Man does not ACTUALLY need a support pole in his back in order to stand. b) As far as I'm aware, it's not "cannon" that Spider-man ever played pin-ball. c) The original comic version would not have had "internal" web-shooters. d) The Green-Goblin's "ray" in the Alex Ross/ Stan Lee signed lithograph is WAY too "sparkley". In FACT, it probably should be a "pumpkin bomb". e) Spidey's webbing was more of a "graphite grey" with darker sides. f) Spidey's Lens are not the appropriate shade of silver-white. g) The "hexagonal" pattern sublimated onto Spidey's costume should have more muscle shading. h) Ben Reilly was actually NOT the "real" Spider-Man. He was the CLONE
(He did make an AWESOME "Scarlet-Spidey" though.)
2) a) The Flash probably would not pose in such a "fruity" way. b) his arm and waist "lightning bolts" are from the older Barry Allen costume while the main body of the suit is from Wally West. c) Flash did NOT have white "eye-shields" (although he probably should have. Can you IMAGINE a june-bug in the eye at 900 mph?) d) He MIGHT need to be slightly blurry around the edges in order to really be true to cannon.
3) a) Darth Vader did not really stand that way. b) Those three characters would not have ever existed in the same room unless it was some sort of crazy Marvel/D.C./Lucas cross-over. c) Vaders belt didn't pull to the left like that in the "accurate" version. d) The REAL Vader was a size 34 waist, and 38 inseam, not 36 waist, 34 inseam. e) David Prowse was 6' 6.5" in costume and the statue is 7'h with a 6" base which would make it .5" too short. f) Some think that Prowse ALSO played the part of the "Tuscan Raider" but if you analyze the film footage, that actor is no more then 6'2". k) Han shot FIRST!
4) a) The Oscar-Meyer "weiner-mobile" is not actually shaped like that. The real or "accurate" one curves up more in front and is made of fiber-glass (not cloth). b) Romulan "D'deridex class" warships did not really blow up like that. c) Technically in space, an explosion would not look that way due to the vacuum. d) When I say vacuum, I realize that space is considered a PARTIAL vacuum (although it's really a "mostly" vacuum). e) Worf was right handed. f) He preferred a "bat'leth" to a phaser. g) Pinballs do not (as far as I'm aware) fly through space leaving contrails behind them. h) I should have probably gone with a different color for the curtains. i) John Luc is considered by some females to be "much sexier" on the show then how he is portrayed on the back-glass. j) Contrary to popular belief, the visible spectrum of light in the human eye consists of the primary colors red, blue, GREEN! Not red, blue, yellow (It's true. Look it up.)
Wheww, I THINK that covers most of it. If not, I'm SURE that someone will let me know.
