1. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 1, 2012 - Noobie's crack at sculpt and cast-Many questions, advice appreciated #1
    First and foremost allow me to say that 2D is my medium of choice...and I'm green to sculpting as a whole- second and....least-most...? I Love props and have always wanted to make them from scratch rather than continue with the typical kits I usually purchase. So I recently decided to try my hand at a sculpt of one of my character's helms in the hopes of casting it in resin and getting some practice at mold making as a whole...however; my supplies were mediocre at best.
    I had a ton of sculpey and no cash to get NSP in bulk (which I would have preferred) so I used what I had....here is the very rough result…
    http://i1167.photobucket.com/albums/.../sculpt003.jpg
    http://i1167.photobucket.com/albums/.../sculpt002.jpg
    Lumpy lopsided potential, no?
    Well I thought it was lovely anyhow.
    I built up the neck a little more to give it support and it lasted about three days before it cracked and the cheeks and back fell off in a neat clump. I assumed it was dry and needed to rejuvenation so I added some softener....then the next morning it happened again...and again all week- being whole in the morning and a mess by the time I got home from work (8 hours)
    Frustrated I assumed the weight was simply too much and put in some small wood supports…yet today, once again pieces fell…I added more but I’m certain it’ll happen again.
    So! Here I am, asking for your advice RPF, I have long envied and adored your talents and can think of no better mentor (s) to teach this eager student! ….Please.
    Now I realize sculpey isn’t typically the choice clay for this but I have been reading up in these forums and other sites that Casting is doable when unbaked…hence comes my molding questions I have a small brush on starter kit from smooth-on I was planning on incorporating into this project….it provides me with the following:
    -sonite wax (wat?)
    -rebound 25 silicone rubber (brush on platinum silicone rubber- 2 lbs)
    -thi-vex II silicone thickener
    -Plasti-paste (support shell?)
    -and one small thing of 300 casting resin.
    Now…I doubt this is enough to finish a project of such size so I know I need more resin but just how much more of the silicone rubber do I need? Is 25 the right kind? And the support shell…where do I buy that stuff separately? Ugh I have so many questions…if you read this far thank you. It means a lot.
  2. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 1, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #2
    Wow! Allow me to edit...no more copy and paste for me..sorry about that folks
  3. It's from Shelley! Ozymandius's Avatar
    Join Date
    Jun 2010
    Location
    Orlando, FL
    Message Count
    622
    Jun 1, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #3
    Your pics are pretty small, so it's hard to tell much from it. That said, bravo for diving in head first and congratulations and a promising start.
    Sculpey is a perfectly fine materail to sculpt in, but it is not self-supporting at all. This is why it is cracking and falling apart on you. It's not the dryness of the clay, but rather its own weight pulling against itself that is your problem.
    Simply put, you need an armature underneath to support the clay. Even a cheap styrofoam wig head would do the trick and those can be found cheaply on Ebay or any hairdresser's supply store.
    Also, you are correct that you don't need to bake the Sculpey if you are going to mold it.
    As for molding and casting... The kit you bought should contain plenty of material for doing a mold for that piece. I do helmet molds frequently and can typically do 2 helmet molds from a kit that size. You should even be able to get about 3 or 4 helmets from the resin.
    I've found that the 2 oz Dixie drink cups found in any supermarket make the perfect measuring tools for doing helmets. Fill 1 cup each with part A and B of the silicone and then mix together in a larger cup and then apply. Let that set and repeat 3 or 4 more times until you've built up the appropriate thickness. After the last layer has set, build your mother mold with the plasti paste and you are done with the mold.
    The same cups work perfectly for measuring out the resin for casting as well. Three to 4 layers seems to give the best balance between strength and weight. I would however recommend getting a sample kit of Onyx Fast from Smooth-On, as it makes for better helmet shells since it is better suited to slush casting.
    Oz
  4. It's from Shelley! Ozymandius's Avatar
    Join Date
    Jun 2010
    Location
    Orlando, FL
    Message Count
    622
    Jun 1, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #4
    Forgot to mention, but very important. Do not use latex gloves or anything made of latex on this project. In fact, don't let latex anywhere near it. Platinum silicones will not cure if it even smells latex in the room.
  5. Join Date
    May 2011
    Location
    Sydney, Australia
    Message Count
    57
    Jun 1, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #5
    Check out the Polytek range of silicone and molding products. I use their Platsil Gel silicone and they are good at coping with latex being in the room. Polytek Development Corp.-Polyurethane & silicone mold materials and casting plastics for making rubber molds to cast concrete, plaster, wax, resins & foam from Polytek Corp.
    I use them under the Mouldlife brand.
  6. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 2, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #6
    Well if you say it's enough I belive you-Thanks guys! Sorry for the small pics- on my computer they displayed as HUGE and really jacked up the site.... Good thing you mentioned the latex- I use a lot of gloves for projects because I'm a tattoo artist part time and well...I have a lot of them- glad I didn't touch the clay with them now though XD I shall begin the search for onyx fast as well!
    Oh! It appears they're are two kinds...both fast and slow- would you recommend the faster original?
  7. It's from Shelley! Ozymandius's Avatar
    Join Date
    Jun 2010
    Location
    Orlando, FL
    Message Count
    622
    Jun 2, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #7
    You want the Onyx Fast. It sets in about 3 minutes. One of the $20 sample kits will do just fine.
    One other note on the silicone. Get you some disposable chip brushes from Harbor Freight or the like and dab the silicone to pop the bubbles.
  8. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 2, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #8
    So I was watching the how-too video that came with this kit and the guy used clay shims to seperate the support shell into three pieces...I was palnning on doing two straight in half like I usually see but...does it have to be modeling clay used to seperate it? Seems like a lot is needed.
  9. It's from Shelley! Ozymandius's Avatar
    Join Date
    Jun 2010
    Location
    Orlando, FL
    Message Count
    622
    Jun 2, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #9
    FYI, the support shell is called a "Mother Mold", and the silicone is called the "Daughter Mold". Don't want the jargon to confuse you.
    And no, you can use anything to build a separating wall for the mother mold. To save time and clay, I will often make a divider from a thin piece of MDF, or even foam board. Just cut a hole in the middle that fits your mold and fit it over the center. You can then use a small amount of clay to secure it in place and fill in the gaps.
    BTW, this is also where you will want to use the Sonite Wax. It will keep the shell material from sticking to the dividing wall, and then to itself when you lay up the other side.
  10. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 2, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #10
    Ahhhh Ok I get it...so a releasing agent isn't necessarily required..sweet! I may try to make the mold tomorrow- don't know when the onyx will arrive but I'm eager.
    EDIT: So as of right now I'm on to smoothing...Any time saving way to do this? I'm using a small tool to level it but was gonna take a brush with softener to it later...not sure of other techniques
  11. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 4, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #11
    Sorry for the double post but just as an update here's some slightly more finished (and better quality) pics...sorry for the darkness- room doesn't get much light. As for the design, it being my own I think only I will really appreciate it XD (I know it's kinda funky but a story goes with everything). It's a good size...about 28 inches around...oh and I'm not a dog murderer....You can find all sorts of things on etsy.
  12. violentevo's Avatar
    Join Date
    Apr 2012
    Location
    Kingston, NH
    Message Count
    53
    Jun 4, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #12
    since you are doing a silicone mold, single piece sleeve I'm assuming, you need to be VERY careful with that scull the silicone will lock in those holes between the nose and the inside of the mouth, which could potentially rip a section out of the mold. best bet would be to stuff clay under the skull and incorporate the fill to your sculpt.
    The silicone will flow into every nook and cranny, be very aware of this and seal off any areas that may be surrounded in silicone, you can always cut them out later once its cast. also if its a real skull you need to seal any sinus's or holes in the skull, or else the silicone may use those holes to fill the skull and lock that entire portion.
  13. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 4, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #13
    Filll the nose! Got it! Thanks, good thing you told me, I filled in the back and most of the eye cavity but totally forgot about the sinus!
  14. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 15, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #14
    Alright guys...I come to you again for guidance...as I think I dun f'd up.
    So I made the soft mold and moved onto the hard shell yesterday....except only one side of the plasti-paste cured fully- throwing a monkey wrench into my plans to cast tomorrow. It's also slightly thin on one side...Any quick solutions or perhaps alternative materials for the hardshell?
    I thought of fiberglass and resin but I was afraid it wouldn't bond well to it...I have some smooth caste 300 I also thought about perhaps with the use of some old strips of T-shirt or somthing...I dunno I'm pretty desperate.
  15. It's from Shelley! Ozymandius's Avatar
    Join Date
    Jun 2010
    Location
    Orlando, FL
    Message Count
    622
    Jun 15, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #15
    Sand the thin areas with some rough sandpaper (80 grit or similar) and the SC 300 should bond to it okay. It would also help if you thickened it up with some kind of filler.
    I use Urefil 3 as a thickener all the time, but plain old sand or talc will also work. To make a spreadable paste it usually takes about equal parts filler and resin.
  16. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 15, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #16
    then smooth cast it shall be! Thanks- now to get some sand...
  17. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 17, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #17
    Science be praised!
    Looky what I got...
    It's a disease! It's a pain! No it's...a flawless mold that I couldn't have made without the help of you guys! Checked for holes using water and there were none to be found! Yeeee! (That's a sound of shrill joy) mother mold was a pain but satisfactory...super stoked to get started but also nervous as I've never slush cast before...that's what it's called right?
    Anyhow, know-how always appreciated- might attempt to cast later today with the onyx. wish me luck and if there's anything I should know that youtube can't teach me- do be kind and tell.
    Also nervous the trial size won't be enough for four coats- I have a tiny bit of the white 300 I can maybe add to the inside if so but still...
  18. It's from Shelley! Ozymandius's Avatar
    Join Date
    Jun 2010
    Location
    Orlando, FL
    Message Count
    622
    Jun 17, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #18
    Congatulations.
    Just powder the mold with talc before casting and it should come out fine. And remember, best to use 3 or 4 thin layers than trying to 1 thick one.
  19. Thewomanwarhead's Avatar
    Join Date
    Mar 2012
    Location
    California
    Message Count
    88
    Jun 17, 2012 - Re: Noobie's crack at sculpt and cast-Many questions, advice appreciated #19
    Came out gorgeous!...well except the one huge ass dent in the side- but I'm thrilled! the detail in the skull (which was totally destroyed in the process) is amazing! Hoping I can maybe heat gun the thing out as it'll be a little while before I can cast another. Here's my boyfriend holding 'er up.
Similar Threads
  1. Replies: 26
    Last Post: 21 Hours Ago, 4:12 PM
  2. Noobie to the site looking for some advice
    MrDaddyBags, Replica Movie Costumes
    Last Post: Apr 6, 2013, 1:26 PM
  3. New Pipboy 3000! (Advice appreciated!)
    Loki1913, Replica Movie Props
    Last Post: Mar 12, 2013, 10:53 PM
  4. Replies: 1
    Last Post: Feb 1, 2013, 7:57 AM
1 2 3 4 5 6 7 8 9 10 11
