the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > PROPS > Sculpture and Makeup Effects
My Predator Wolf Head sculpt
Discussion on My Predator Wolf Head sculpt within the Sculpture and Makeup Effects forum, part of the PROPS category; Awesome. You should do a resin run of them!
Reply
LinkBack Thread Tools
Old 12-23-2011, 12:22 PM   #26
Slave1's Avatar
Slave1 has not been awarded enough reputation to matter.
Re: My Predator Wolf Head sculpt
Slave1 is offline   Reply With Quote
Old 12-26-2011, 09:25 AM   #27
snakes88's Avatar
snakes88 has not been awarded enough reputation to matter.
Quote:
Please to say there will be a few resins runs being made of this piece available early next year!!
snakes88 is offline   Reply With Quote
Old 12-26-2011, 12:09 PM   #28
wrcromu has not been awarded enough reputation to matter.
Quote:
That's a great news !!!!
wrcromu is offline   Reply With Quote
Old 12-26-2011, 10:06 PM   #29
Darth Pinhead's Avatar
Darth Pinhead has not been awarded enough reputation to matter.
Couple guys I know have run into problems with trying to cast latex in silicone molds that included the full mandibles. Even with a heat gun, it can be tricky getting enough air in there for the latex to cure. Better off just using fishing line to slice them off clean if you are planning on making latex in the future. How large is the sculpt, though? Is it 1:1, now or did you make it bigger with the intent of making 1:1 latex pulls? If it is 1:1, now, why not do your silicone mold and then do a three-part fiberglass mold for silicone pulls. If it is currently bigger, you could do a stone mold after for latex? Ah, stupid options...
Darth Pinhead is offline   Reply With Quote
Old 12-27-2011, 04:31 AM   #30
suckface's Avatar
suckface has a reputation level greater than 10!
I've done one of these myslef mate and I kept the 2 mandibles seperate molds cut off as close to the mouth as possible, this might also give you the option after to sculpt another set of mandibles in a closed position something I was going to do but never molded the closed versions
if this was mine and I was making the mold in silicone I would honestly remove all the teeth and the mandibles
this will give a lot less stress of the silicone when de molding and prevent and issues hopefully
will also give you the option of making the teeth molds in a translucent resin for a more life like tooth
the bonus is then keeping the mold making simple you will have very little damage to your original sculpt especially as it's in nsp chavant so you can make yourself a plaster mold for a latex head for costuming after, unless your going the full hog and doing some mouth moving mechanisim I would not bother going for a silicne version as it will be too expensive and very heavy to wear, you'll also need to consider making a wearable core then too
hope that helps looking forward to the finish
suckface is offline   Reply With Quote
Old 12-27-2011, 02:03 PM   #31
snakes88's Avatar
Quote:
I'd say it's a 1.1 maybe a bit bigger but not as big as the original from ADI.So I guess it'll be good for latex pulls aswell.
Old 12-27-2011, 02:16 PM   #32
snakes88's Avatar
Thanks,not sure as of yet to add the moving mechanism but had considered the translucent tooth look.Had some samples sent from bently chemicals.However to get the translucent tooth look do I buy a translucent resin and mix it with a colour or is there a resin available that already has that translucent off white look?
Thanks AJ
Old 12-28-2011, 12:59 PM   #33
suckface's Avatar
I'd go with the easy flow clear from mold life and add a little white and yellow pigment
another way would be to use proper dental acrylic but thats a lot more expensive
Old 12-28-2011, 01:19 PM   #34
SaintPeter has not been awarded enough reputation to matter.
That's the best Wolf sculpt I've ever seen!!!!! I'll take one once it's available!!!!
SaintPeter is offline   Reply With Quote
Old 12-28-2011, 07:03 PM   #35
snakes88's Avatar
Cheers I'll look into into!
Old 12-28-2011, 07:05 PM   #36
snakes88's Avatar
Quote:
Thanks,updates coming soon.
Old 12-28-2011, 09:20 PM   #37
cayman shen's Avatar
cayman shen has a reputation level greater than 750!cayman shen has a reputation level greater than 750!cayman shen has a reputation level greater than 750!cayman shen has a reputation level greater than 750!cayman shen has a reputation level greater than 750!cayman shen has a reputation level greater than 750!cayman shen has a reputation level greater than 750!cayman shen has a reputation level greater than 750!
Gorgeous sculpt. Wolf is the best pred ever
cayman shen is offline   Reply With Quote
Old 01-07-2012, 01:29 PM   #38
andurilmat has not been awarded enough reputation to matter.
thats an amazing sculpt mate
andurilmat is offline   Reply With Quote
Old 01-07-2012, 01:52 PM   #39
davy's Avatar
davy has not been awarded enough reputation to matter.
Holy s***
davy is online now   Reply With Quote
Old 01-08-2012, 01:54 AM   #40
RPF Premium Member
Skaar's Avatar
Skaar has a reputation level greater than 10!
That looks so wicked!
Skaar is offline   Reply With Quote
Old 01-08-2012, 10:02 AM   #41
NEMES1S's Avatar
NEMES1S has not been awarded enough reputation to matter.
Yeah, man... great work!
NEMES1S is offline   Reply With Quote
Old 01-08-2012, 10:52 AM   #42
Burnsy's Avatar
Burnsy has not been awarded enough reputation to matter.
Fantastic work.
Looking forward to seeing the finished resin version.
Burnsy is offline   Reply With Quote
Old 01-08-2012, 01:19 PM   #43
Bradleyw has not been awarded enough reputation to matter.
that is an amazing scult absolutly stunning. well done very very impressed with the detail.
Bradleyw is offline   Reply With Quote
Old 01-08-2012, 07:39 PM   #44
HorrorFan has not been awarded enough reputation to matter.
Thats pretty amazing. I wish I had that kind of talent.
HorrorFan is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Predator Head Sculpt Termokk Sculpture and Makeup Effects 128 04-05-2012 12:23 PM
Predator: P1, P2, Elder and Wolf 1:1 Heads PredatrHuntr Replica Movie Props 37 06-30-2011 03:08 AM
New Predator Wolf Suit! armandb Replica Movie Props 13 05-19-2009 10:56 AM
Wolf Predator. Usurper Replica Movie Props 9 03-17-2008 04:33 PM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
