1. Join Date
    Apr 2012
    Location
    Ireland
    Message Count
    46
    Jul 11, 2012 - Help with casting a cowl. #1
    Hi all,
    I have just finished sculpting my Batman cowl I have just made a silicone and bandage mold of the sculpt, as you can imagine I'm quite excited and can't wait to make my cowl I need a few questions answered though.
    How do I actually go about making a wearable cowl? Are there any full tutorials I should read? What should it be made of? I've seen different threads saying latex, urethane rubber( 40, 60 as in stiffness I think?). And how do I go about actually cast it, I've heard a "Slush Cast" and a "Dwell Cast" thrown around on many threads.
    Every single answer will be very much appreciated!
    TheCaptain96
  2. Moonwildflower's Avatar
    Join Date
    Aug 2011
    Location
    Texas
    Message Count
    33
    Jul 19, 2012 - Re: Help with casting a cowl. #2
    I know that Monstermakers.com has a slip latex that is specific for the Batman cowl/costume. Mask Making Latex - Bat Black - Quarts and Gallons - Latex Compounds - Casting Compounds - Flexible - CASTING AND PAINTING - The Monster Makers
    As for slush casting, you pour in the component and slush it around, making sure the liquid coats everything important. When you have the desired thickness built up, you can prop the mold up and allow the excess to run out.
    Hope this helps. I've only been doing this for a few years.
  3. Join Date
    Apr 2012
    Location
    Ireland
    Message Count
    46
    Jul 19, 2012 - Re: Help with casting a cowl. #3
    Many thanks MoonFlower I wish someone had a detailed cowl making video :P
  4. Join Date
    Jul 2012
    Location
    Iowa
    Message Count
    91
    Jul 20, 2012 - Re: Help with casting a cowl. #4
    Moonwildflower said: View Post
    This info helps me too! Ive been looking for info on slush casting. im very new and have alot to learn. Thanks Moonwildflower!
  5. Join Date
    Jun 2012
    Message Count
    1
    Jul 20, 2012 - Re: Help with casting a cowl. #5
    Casting and skinning Flex Foam - YouTube This video seems handy for what you're looking for
    Minus the foam step of course, and with different materials.
  6. Moonwildflower's Avatar
    Join Date
    Aug 2011
    Location
    Texas
    Message Count
    33
    Jul 23, 2012 - Re: Help with casting a cowl. #6
    So glad I could help! I actually learned how to slush cast working with hard props and smooth cast.
  7. Looch's Avatar
    Join Date
    Aug 2011
    Location
    vancouver, BC, Canada
    Message Count
    455
    Aug 2, 2012 - Re: Help with casting a cowl. #7
    Just a note: I like to fill my neg to the top with latex-leaving it for about 20 minutes, so the plaster can soak up some of the liquid, THEN pour it off(Monstermakers should have a pic of the rig to build for tipping it back out). Just a thought
  8. Join Date
    Apr 2012
    Location
    Ireland
    Message Count
    46
    Aug 8, 2012 - Re: Help with casting a cowl. #8
    Thanks all
  9. Join Date
    Apr 2012
    Location
    Ireland
    Message Count
    46
    Aug 8, 2012 - Re: Help with casting a cowl. #9
    Moonflower, Looch,
    Thanks for the info, havent been here for a while so i havent been ignoring you
    Every little helps on my quest
  10. Join Date
    Aug 2012
    Message Count
    24
    Aug 16, 2012 - Re: Help with casting a cowl. #10
    I'm glad I found this thread..I've been wondering the same thing, myself.
  11. Join Date
    Apr 2012
    Location
    Ireland
    Message Count
    46
    Aug 17, 2012 - Re: Help with casting a cowl. #11
    Yea i couldnt have been the only one who wamted/needed to know this :P
  12. Join Date
    Jan 2013
    Location
    monaghan
    Message Count
    42
    Feb 26, 2013 - Re: Help with casting a cowl. #12
    hello there did you have any luck casting your cowl,what method did you use in the end
  13. grinty33's Avatar
    Join Date
    May 2012
    Location
    UK
    Message Count
    65
    Feb 26, 2013 - Re: Help with casting a cowl. #13
    Let it die man, let it die.
Similar Threads
  1. Replies: 62
    Last Post: Feb 4, 2013, 2:24 AM
  2. TDK cowl CASTING - NEED HELP & SUGGESTIONS!
    Bane 187, Replica Movie Costumes
    Last Post: Oct 1, 2012, 5:29 AM
  3. Pfeiffer Catwoman cowl sculpt** finished casting**
    reevz666, Sculpture and Makeup Effects
    Last Post: Apr 19, 2012, 10:28 AM
  4. Help needed... batman cowl sculpt casting help.
    Nyne, Sculpture and Makeup Effects
    Last Post: Jan 15, 2012, 10:54 PM
  5. Help casting a batman cowl
    batgrayson, Replica Movie Costumes
    Last Post: Oct 9, 2011, 5:51 AM
1 2 3 4 5 6 7 8 9 10 11
