Thanks guy's
Yeah, I'm looking forward to running a cast, I might see if I can pop one out today.
Couple of things might hinder running a cast ATM though, I've just washed the moulds so there'll be water in some of the detail & its 27 degrees here today & the resin I have will set in 2.5-3 minutes! So I may have to try to just cast the face end of the head, at least if it comes out OK I can use it for sculpting the lip's & tendons onto, so it wont go to waste.
Having managed to wash all the old paint off successfully I've noticed a few (only a few) bubbles but not on the moulds inner surface! The bubbles have formed between the thixo coat & the detail coats. If I'd put only one skin or detail coat on, I'd be having problems! The surface of the bubble would be very thin & likely to break easily, leaving a hole in the mould surface... not good!
However I applied two detail coats & as a result the surface of the bubble is quite thick & less likely to break... Result!!
Still, I'm thinking about injecting a little non-thixo silicone into the bubbles using a syringe :unsure
Fred, I'd love to own a copy of that book but its just too expensive at £80-£100! & as much as £200!!!! :eek I just cant warrant spending that much on a book ATM
