Page 3 of 21 FirstFirst 1234567813 ... LastLast
  1. Don't ask me. Use Google. STEALTH's Avatar
    Join Date
    Jan 2010
    Location
    Canada
    Message Count
    2,421
    Feb 28, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #51
    Zabana said: View Post
    put the hinge on top of the head, but the problem there is to move with a servo the faceplate. If the helmet is bigger enough can be put on top and the servo´s arm will move directly the plate. But I don´t know how much free space are in your helmets in this area...
    this was my idea as well
    and it works.
  2. Join Date
    Jun 2009
    Message Count
    396
    Feb 28, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #52
    STEALTH said: View Post
    and it works.
    Wow, that´s pretty good! Have you got any pic of that to see in a real case how it works?
  3. Don't ask me. Use Google. STEALTH's Avatar
    Join Date
    Jan 2010
    Location
    Canada
    Message Count
    2,421
    Feb 28, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #53
    I'm going to make a tutorial to show everyone once its finalized.
  4. Starx's Avatar
    Join Date
    Nov 2009
    Message Count
    109
    Feb 28, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #54
    stealth...tisk tisk..been keeping things from me? lol
  5. Don't ask me. Use Google. STEALTH's Avatar
    Join Date
    Jan 2010
    Location
    Canada
    Message Count
    2,421
    Feb 28, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #55
    Not really. Just not done.
    I'd also would rather share it with everyone on my own personal build than privately with a select few.
  6. Join Date
    Jun 2009
    Message Count
    396
    Feb 28, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #56
    These are very good news for all of us that are working in the proyect
  7. Starx's Avatar
    Join Date
    Nov 2009
    Message Count
    109
    Feb 28, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #57
    I understand. Well if you need help with anything you know im here to help.
  8. Join Date
    Jun 2009
    Message Count
    396
    Mar 7, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #58
    Not a real update but something to show. I was playing with rhino and this was what come out :
    I need to finish for pepakura
  9. jaymay023's Avatar
    Join Date
    Nov 2009
    Location
    Nor Cal, USA
    Message Count
    224
    Mar 8, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #59
    The best way to make the center hinge system work would be to use a reduction gear set. Gearing would be the only way to make this work, especially if you use a servo. With enough gears in it you could make it thin enough to fit in the helmet. Also the arms would have to pivot horizontally to facilitate smoother movement.
    Otherwise a normal motor would work with switches on the top and bottom to make the motor stop at each end. I'll draw up some concepts that I've been thinking about for a few months now and try and post tomorrow.
  10. Don't ask me. Use Google. STEALTH's Avatar
    Join Date
    Jan 2010
    Location
    Canada
    Message Count
    2,421
    Mar 9, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #60
    jaymay023 said: View Post
    Gearing would be the only way to make this work, especially if you use a servo..
    I've been working on the entire servo system for every moving part of my suit that I have chosen to actually move for the past month now (this includes the helmet) and...
    I kindly disagree with you.
    I've tested everything now with scratch built test parts and the results were more than satisfactory
  11. Join Date
    May 2010
    Message Count
    2
    May 3, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #61
    @ zabana
    Looks real (!) smooth, wich pep files did u use?
    @ the hinge postings
    Couldn't a cd-bracket motor + gearings work nice?
  12. Join Date
    Jun 2009
    Message Count
    396
    May 3, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #62
    Hanzsel said: View Post
    @ zabana
    I use my own pep ones in this pieces
    I don´t think so, this kind of gears aren´t strong enough
  13. Join Date
    May 2010
    Message Count
    3
    May 3, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #63
    HiTec makes a mini servo (33mm x 18mm x 33mm) that'll put out 55 (at 4.8v) - 67 (at 6v) oz/in of torque, which should be enough to lift any face plate from the center. The depth may be close in your helmet, but if the face plate weighs less, you could even manage a smaller, weaker (less torque) servo, micro servers go down to 1cm in width or less.
    Building your own gearing system is just asking for trouble, there are servos out there small enough and strong enough for almost any application.
  14. Join Date
    Apr 2010
    Message Count
    3
    May 3, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #64
    hola Zabana como te va, primero que todo felicitarte por tu magnifico trabajo .
    me gustaria saber si puedes ayudarme con algunas preguntas
    intente de hacer mi casco ironman pero tengo un problema con la medida para que entre en mi cabeza con el pepakura, y que si lo puedo hacer a mi escala que no quede tan deforme de acuerdo a mi cuerpo, cual fue la medida que utilizaste tu en tu casco?, y que modelo de casco por que he encontrado un monton y quiero hacer ese modelo que tu hiciste, disculpa si fueron tantas preguntas pero la verdad es que es la primera persona que hace esto y habla espanhol
    saludos
    felicitaciones pro el magnifico trabajo
  15. Join Date
    Apr 2010
    Message Count
    3
    May 3, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #65
    robersox@gmail.com mi msn por si te es mas fácil responderme
    saludos de nuevo
  16. Join Date
    Jun 2009
    Message Count
    396
    May 3, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #66
    robersox said: View Post
    saludos
    Hi!!!
    Thanks!
    Some members requested to me to not speak in spanish, so I´ll answer you the same by PM just in case...
    My helmet it´s not pepakura´s one, it´s modeled in clay over a base of my head.
    For your helmet, two ways I use. Trial and error or export the model, open it with any 3d/cad program and take measurements and calculate new scale.
    Good luck!!!
  17. Graphic Jordan's Avatar
    Join Date
    Jan 2010
    Location
    St. Pete, FL
    Message Count
    1,408
    May 4, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #67
    I love the way the chin system works on the helmet.
  18. Join Date
    Jun 2009
    Message Count
    396
    May 4, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #68
    saludos
    Dark Nerd said: View Post
    Thanks!!! Me too hehehe
  19. Join Date
    Apr 2010
    Message Count
    3
    May 4, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #69
    muchas gracias zabana te pasaste
    thanks
  20. Join Date
    Apr 2010
    Message Count
    9
    May 10, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #70
    What kind of servos did you use? In other words, what was their lift capacity?
  21. Join Date
    Jun 2009
    Message Count
    396
    May 10, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #71
    Samuray said: View Post
    I was using two futaba s148 (3 kilos) but I´m trying now a Hextronic HX12K (10 kilos) I hope it would be enough...
  22. Join Date
    Jun 2009
    Message Count
    396
    May 23, 2010 - Re: Spanish Iron Man costume WIP - New hynge system for pepakura helmet and torso upd #72
    HI!!!
    Long time since last update
    I was pretty busy at work and I´ve got problems with my back so I couldn´t do a lot...
    But now I´m proud to tell that I´ve finish my voice recognition system to manage the suit once it´s done, now I´ve got working the faceplate opening and lightning up the eyes. I´ve remodeled again the opening system to be easier for the servos and change them to a 10Kilos new ones
    I was working also in the legs. I take Dancin_fool´s thigh and I´ve modified to have a hinge system like I did with the arm. Also I´ve designed a calf and a complete boot.
    There also good news for you. After thinking a lot I´ve decided to freely release all my pep files for one reason over all of them, if I´m using another people file all of you must have the chance to use mines.
    Without delay I´m proud to show you my last progress:
    Old hinge system
    New system
    All armor pieces together:
    Helmet comparison:
    And my seven month assistant
    Vids about new arm, eyes and helmet:
    http://www.youtube.com/watch?v=rWzC8ZTuss4
    http://www.youtube.com/watch?v=QNqMW8nirbw
    http://www.youtube.com/watch?v=ATkCIR_62b8
    http://www.youtube.com/watch?v=67biXF-dFwc
    My PDO files for download:
    antebrazo bajo.pdo
    antebrazo superior.pdo
    brazo.pdo
    cubre mano.pdo
    embellecedor brazo.pdo
    embellecedor hombro.pdo
    nueva pierna muslo derecho.pdo
    nueva pierna muslo tapas derecho.pdo
    nueva pierna pantorrilla tapas.pdo
    nueva pierna pantorrilla.pdo
    parte externa hombro.pdo
    parte interna hombro.pdo
    pie completo.pdo
    torso escalado grande con tapas.pdo
    calf end pieces.pdo
    Hope all of you like my work
    Please tell what you think
  23. Join Date
    May 2010
    Location
    Australia, Victoria, Geelong
    Message Count
    6
    May 23, 2010 - Re: Spanish Iron Man costume WIP - Voice recognition system for suit control works!!! #73
    Nice job carnt wait to see the final product
  24. Join Date
    May 2010
    Message Count
    13
    May 23, 2010 - Re: Spanish Iron Man costume WIP - Voice recognition system for suit control works!!! #74
    Just Incredible!!!!! I would really love to hear more about your voice activation system, I have wanted to do something like that for a long time but have basic knowledge of this kind of thing at best.
  25. jaymay023's Avatar
    Join Date
    Nov 2009
    Location
    Nor Cal, USA
    Message Count
    224
    May 23, 2010 - Re: Spanish Iron Man costume WIP - Voice recognition system for suit control works!!! #75
    good idea about voice control; cheaper then my idea of using a emotiv headset. Nice job on the pep. Keep up the great work.
Similar Threads
  1. MattCorneIM's Finished Foam Iron Man Suit! {Page 3} WOO!
    MattCorneIM, Replica Movie Costumes
    Last Post: 2 Weeks Ago, 5:27 PM
  2. Replies: 155
    Last Post: Feb 27, 2013, 1:29 PM
  3. Replies: 11
    Last Post: Sep 8, 2012, 6:19 AM
  4. Iron Man Mark 6 build WIP...updated pics on page 2
    jrhaake, Replica Movie Costumes
    Last Post: May 16, 2012, 2:52 PM
  5. Replies: 21
    Last Post: Apr 25, 2008, 6:11 AM
1 2 3 4 5 6 7 8 9 10 11
