Page 1 of 5 12345 LastLast
  1. Hamsterstyle's Avatar
    Join Date
    Jun 2009
    Location
    Seattle, WA
    Message Count
    285
    May 13, 2010 - Witch-king of Angmar (Finished) With Templates (12/29/2012) #1
    Update 3/3/2011: on Page 2
    Update 12/29/2012: Bottom of this post has the Helmet Template.
    Last year I started out making a General Kael mask, then I started making pvc chainmaile, before I knew it I was working on the entire costume. For some reason I find myself doing a very small project, then quickly evolves into something larger.
    So about two weeks ago I decided to take a break from another WIP to play around with styrene(Or what I'm pretty sure is Styrene) and rivets. I've never played with these materials, but seeing what people have done with these materials on this site, I figured it would be fun to learn it.
    I've had Kropserkel under my favorites for quite some time and have from time to time checked out their website and the crazy cool replicas that they make. Inspired by that, and all the great Iron Man armor on here, I started off making a set of Naz'gul gauntlets.
    My reference for this was a few frames from the movie, and all of the various replicas that I found online(Of course kropserkel). In addition to the licensed statues.
    The biggest struggle I had with this was getting the knuckleguard correct(or whatever it is called). Since I don't own a vacuform table, I made due with a heat gun and lots of trial and error. I arrived at this:
    It's not very accurate, but it works for now.
    The picture above is half weathered as a quick test.
    Getting to that point, I then realized that I needed to do a little of the forearm armor, then I did the shoulder armor, and tonight I did a version of the helmet. This is why I don't buy pies, because I start off eating one piece, and before I know it I've eaten an entire pie and a galleon of whip-cream. Yes, I can eat an entire spanish trading ship filled with whip-cream.
    I didn't want to do a WIP thread for this, as it is just my personal insanity, but since I've worked on it I've had some questions and issues pop up, and since there is no better group of people to ask (Unless you work for WETA or Sauron), I come here with my questions.
    1st: I need a pair of cheap leather or leather-ish gloves for the gauntlets. It's summer time, and noone carries them anymore. I don't need a perfect set, just anything black and leatherish would be fine. I'm hoping to spend less than 30 bucks for the pair. Where online should I check? My plan is to ruin them by directly riveting the finger plates into the gloves. So I may pick up 2-3 pair. Plus having a good set of mideval gloves around for costumes would avoid my General Kael problem. Namely having cheap plastic gloves that after 8 hours feel like wearing wet salty socks on your hands.
    2nd: Anyone know the dimensions of the helm? From what little I've read online It seems the helm is around 30in tall. I plan to wear it a little high on my head so that I'm looking out the 'mouth', if it ever goes to a full costume.
    3rd: Fabric, what kind of fabric to give that ugly, falling apart look that the ringwraiths have. I've been to alleycatscratch and gone through what they have written, but second opinions are always welcome. I do wonder why the Naz'gul couldn't afford nice things. You would think that nine of the most powerful warriors in Middle-earth working for a great evil eye could afford a new set of robes every hundred years or so. They must not have unionized.
    4th: What is a good filler for styrene? There will be a few cracks between plates, and my current plan is just a little hot glue for that welded look.
    5th: How toxic is styrene? I hope this doesn't make me sound like an idiot, which as anyone can attest, I usually do. But right now I'm just heating the styrene pieces with a heat gun until they are soft and then molding them over whatever will give me the shapes I need. I'm not melting them, just softening them. I do this in my apartment. Am I ruining my lungs, should I be coughing up blood? Or should I just hope that one day I can buy new lungs?
    So yeah, I don't have a girlfriend so this is my project in the meantime. If it goes well this 'pilot' may go to series and I may make 8 Naz'gul costumes for friends and fall on a convention together. Help me RPF you're my only hope.
    Template Update:
    Helmet:
    Full Size
  2. JediFran's Avatar
    Join Date
    May 2010
    Message Count
    39
    May 13, 2010 - Re: WIP: Witch-king of Angmar #2
    hiya!
    can i just say first off: MASSIVE AMAZINGNESS on the armour build very very nice.
    I am assuming Styrene is the same as Plasticard (which is what I use to build props for the RepCom guys) and if it is then Car Body filler works a treat to fill in and then sand-down gaps to give a smooth finish. Just do it in a WELL VENTILATED area as the stuff is NOT good for you. You may also want to invest in a facemask for that tbh.
    As for the fabric, you'd want something in a heavy weave which takes well to weathering. Depends how much you want to spend as well
    I would imagine they used some sort of heavy wool or cotton for the films.
    I am very bad at naming fabrics though, am only any good at picking them out from a given selection.
    Good luck!! and well done again! amazing!!
  3. unheard's Avatar
    Join Date
    Apr 2010
    Message Count
    202
    May 13, 2010 - Re: WIP: Witch-king of Angmar #3
  4. DarkHeart Armoury's Avatar
    Join Date
    Dec 2007
    Location
    Boise, ID
    Message Count
    44
    May 13, 2010 - Re: WIP: Witch-king of Angmar #4
    Hamsterstyle said: View Post
    Check Ebay for unlined motorcycle gauntlets. Should be just what you need.
    NIce work, btw.
  5. Guri's Avatar
    Join Date
    May 2002
    Message Count
    2,500
    May 13, 2010 - Re: WIP: Witch-king of Angmar #5
    Looks great!!!
  6. WebChief's Avatar
    Join Date
    Jan 2002
    Location
    MA
    Message Count
    1,531
    May 13, 2010 - Re: WIP: Witch-king of Angmar #6
    That's looking incredible!
  7. Join Date
    Mar 2007
    Message Count
    40
    May 13, 2010 - Re: WIP: Witch-king of Angmar #7
    Great work on the gauntlets. Cant wait to see the helmet finished.
    I saw some gauntlets on here the other day and was wondering if there is a pattern for all of the pieces.
  8. Hamsterstyle's Avatar
    Join Date
    Jun 2009
    Location
    Seattle, WA
    Message Count
    285
    May 13, 2010 - Re: WIP: Witch-king of Angmar #8
    idonutn0 said: View Post
    I saw that too when I did a search.
    I would love a pattern for all the pieces, an accurate pattern at least. If this whole thing works out I may post my version of the pattern, so other people can use it as a starting off point. I've learned alot so far doing these verson1s, so if I do a verson 2 it should be more accurate.
    And thanks for the advice on motorcycle gauntlet gloves, they are exactly what I'm looking for. Found some dirt cheap ones that should be good enough to test on.
  9. Hamsterstyle's Avatar
    Join Date
    Jun 2009
    Location
    Seattle, WA
    Message Count
    285
    May 17, 2010 - Re: WIP: Witch-king of Angmar #9
    Bought some cheap leather motorcycle gloves on 'teh internet' and after getting them I noticed that they were way to big. So after removing all the padding inside I modified them down about 2 sizes.
    This is the final left glove before any weathering. The plates are riveted directly into the glove, which I found to be better than sewing them on.
    I'm still not really happy with them, and I know I'll revisit these in a few months and redo them to be more accurate, but for now they fall into 'good enough', I guess.
    Finally, the current status of the helm and other pieces layed out next to it. I did quite a bit of reshaping to it, and then used a dremel and knife to add some scrapes, chips and holes to give it a more worn out look. I'm going to dremel it even more in the next few days and hopefully paint it this weekend.
  10. Yodajammies's Avatar
    Join Date
    Jun 2008
    Location
    NashVille, TN
    Message Count
    403
    May 17, 2010 - Re: WIP: Witch-king of Angmar #10
    Wow, fantastic work. How did you form those grooves in the top part of the gauntlet?
    I did a wraith costume a couple years back and for the cloak I used a heavy knit fabric off the bargain bin wall at WalMart. Cuts, burns, running over it with your car, etc. Weathering the fabric is awfully fun, but I wouldn't suggest using a bleach solution to discolor it.
  11. tictoc's Avatar
    Join Date
    Aug 2007
    Location
    Seattle, WA
    Message Count
    293
    May 17, 2010 - Re: WIP: Witch-king of Angmar #11
    I kept thinking of the phrase "the pie king of Angmar" from your quote!
    Your project looks great! Looking forward to your progress on the helm. I love LOTR.
    By the way, where did you get your styrene? I get it from Calsak Plastics in Kent.
  12. Miana's Avatar
    Join Date
    Dec 2007
    Location
    San Diego, CA
    Message Count
    113
    May 17, 2010 - Re: WIP: Witch-king of Angmar #12
    This looks awesome! Great job!
  13. obiwan2's Avatar
    Join Date
    Jul 1999
    Location
    Illinois
    Message Count
    1,614
    May 17, 2010 - Re: WIP: Witch-king of Angmar #13
    Holy Crap!! Nice work
  14. Hamsterstyle's Avatar
    Join Date
    Jun 2009
    Location
    Seattle, WA
    Message Count
    285
    May 17, 2010 - Re: WIP: Witch-king of Angmar #14
    Yodajammies said: View Post
    I'm looking forward to weathering it. I'm planning on slowly picking up cheap fabric over the next few months and ruining it.
    I have some thick wire that I lay down on a hard surface, then heat up the styrene until it is soft, then I just press it down onto the wire. It leaves a nice line on the surface after it cools. For a curve i just curve the wire.
    Any thoughts on how to discolor black fabric. I may just run it through a hot wash a few times to slightly grey it.
    tictoc said: View Post
    That might be a better costume. Just like eventually I want to make a fully armored 'Master Chef' costume. Or Spidermandalorian.
    So, I'm pretty sure it's styrene, like 90% sure. I bought it at TAP Plastics in Belleview. It's very cheap.
  15. G17RDY's Avatar
    Join Date
    Dec 2007
    Location
    Scotland
    Message Count
    738
    May 19, 2010 - Re: WIP: Witch-king of Angmar #15
    H, your gauntlets are fantastic, well done.
    As for some of your earlier Q's - I have the UC WitchKing Helm, which i have measured out at a whopping 31" from the base to the top of the spike - see pics
    Also, i have the Topps WitchKing costume card, which contains a piece of the same fabric used for the movie costume, The fabric is quite a heavy weave almost like a woolen fabric. The texture is fairly rough due to the weave - almost bobbly.
    Hopefully these pics will help you out...
  16. Hamsterstyle's Avatar
    Join Date
    Jun 2009
    Location
    Seattle, WA
    Message Count
    285
    May 19, 2010 - Re: WIP: Witch-king of Angmar #16
    G17RDY said: View Post
    I think my helm is about 29-30in long. I found some good pics online to get a rough estimate as to the scale of all the pieces.
    I'm pretty sure the UC helm is based off the official helm. If you ever got bored making a template off of that helm would be rad. I don't know what the 'policy' of it is on here.
    I do like how grooved the helm is, I've already gone crazy with my dremel, I need to do another 3 hours of it tonight. Just so that my neighbors will love me even more.
    I've been looking for a good wool substitute. I don't want to overheat under 3 layers of this stuff.
  17. Hamsterstyle's Avatar
    Join Date
    Jun 2009
    Location
    Seattle, WA
    Message Count
    285
    May 25, 2010 - Re: WIP: Witch-king of Angmar #17
    While watching the final episode of Lost, and the second to last episode of Legend of the Seeker. I finished up the Witch King Helm.
    The spikes are made out of carved wooden dowels. Screwed and glued them into place. Then spraypainted the entire thing with Hammered Steel Spraypaint, with some dark grey smudges to weather it.
    From tip to tip the helm is a little under 32 inches, which makes it just about the right height.
  18. Siyoum3434's Avatar
    Join Date
    May 2010
    Location
    Seattle
    Message Count
    60
    Jun 1, 2010 - Re: WIP: Witch-king of Angmar #18
    This is looking really good man, now when do I get to come over and play?.
    Also, if you're gonna remake the gloves eight more times, and I know for a fact you will, what are you gonna do with the others? Just don't throw them away.
    cheers!
  19. Banned
    Join Date
    Apr 2010
    Message Count
    276
    Jun 1, 2010 - Re: WIP: Witch-king of Angmar #19
    Dude, want paint did you use for your arms and gloves? can you tell me the color and make of the paint? thanks!! that WIP is soooooooooooooo PIMP!
  20. Allaerra's Avatar
    Join Date
    Nov 2009
    Location
    Rhode Island
    Message Count
    22
    Jun 1, 2010 - Re: WIP: Witch-king of Angmar #20
    That is looking really awesome so far! Nice work!
  21. Hamsterstyle's Avatar
    Join Date
    Jun 2009
    Location
    Seattle, WA
    Message Count
    285
    Jun 1, 2010 - Re: WIP: Witch-king of Angmar #21
    Siyoum3434 said: View Post
    cheers!
    Well Siyoum, I think the end goal is to make the Nine and decend on a convention in mass, thus needing eight more gloves.
    PAULFIERCE said: View Post
    It's Rustoleum Hammered Metal Spraypaint. Then I use acrylic grey's, blacks, and browns for the weathering.
  22. Hamsterstyle's Avatar
    Join Date
    Jun 2009
    Location
    Seattle, WA
    Message Count
    285
    Jun 2, 2010 - Re: WIP: Witch-king of Angmar #22
    I'm double replying to my own thread, how sad is that. Here are some more updates for the curious. This is one of those costumes, where all I see is how not accurate it is, but It is still turning out pretty well, and I know I've learned alot in the process.
    All the pieces I have cut out and molded, except for the helm.
    A quick 'myspace pic' showing the movement of the wrist. The arm is pretty comfortable. I sacrificed some authenticity for comfort... which on here I think is a crime.
    Finally a closeup of the shoulder so far, the weathering I did to the plastic is a bit rough, but it gives it a little bit of texture.
    It's all held together by rivets, and bits of thick leather, which is considerably stronger than the plastic.
    So that is my current progress, next is the boots and legs, then making the cloak and robe. I'm looking at using black gauze cloth, as it is cheap, lightweight, rough looking, and comfortable to wear. Any suggestions on how to fade it out?
  23. Siyoum3434's Avatar
    Join Date
    May 2010
    Location
    Seattle
    Message Count
    60
    Jun 2, 2010 - Re: WIP: Witch-king of Angmar #23
    You're right, it is a crime, a crime of passion.
    Further, I knew the nine people plan, What I'm saying is that you will remake everyone's gloves 9 time's.
    not that that's a crime of course.
    cheers
  24. Miana's Avatar
    Join Date
    Dec 2007
    Location
    San Diego, CA
    Message Count
    113
    Jun 8, 2010 - Re: WIP: Witch-king of Angmar #24
    That looks awesome!
  25. Banned
    Join Date
    Sep 2002
    Location
    California
    Message Count
    2,593
    Jun 8, 2010 - Re: WIP: Witch-king of Angmar #25
    Amazing would be an understatement>>>>>!
Similar Threads
  1. Witch King of Angmar
    elric2112, Replica Movie Costumes
    Last Post: Mar 11, 2013, 5:37 PM
  2. Witch King - L.O.T.R
    LadyMuck, Costume and Cosplay Showcase
    Last Post: Dec 12, 2012, 10:22 PM
  3. first ever build - witch king
    razorskub, Replica Movie Costumes
    Last Post: Nov 2, 2012, 12:46 PM
  4. Witch King Costume
    kolder, Replica Movie Costumes
    Last Post: Sep 25, 2012, 3:36 PM
  5. Witch King of Angmar build- My first!
    MULDIVEN, Replica Movie Costumes
    Last Post: May 18, 2011, 3:19 PM
1 2 3 4 5 6 7 8 9 10 11
