1. Join Date
    Jul 2012
    Message Count
    165
    Jul 30, 2012 - What does everyone use to separate their Iron Man helms after fiberglass? #1
    Finished the fiberglass this weekend inside the helmet, and poured a thin coating of rondo for rigidity. I'm thinking separating the mask into its 4 pieces NOW, would be smarter than doing it after all the bondo work.
    My question is, are you guys just using regular cutting wheels for your dremels to do the surgery? Or have you found a particular bit or tool that makes it easier? Trying to minimize the gaps now, and also increase the accuracy with which I make the cuts.
    Already have the extension tool so that should help alot.
  2. Lord Magneto's Avatar
    Join Date
    Oct 2011
    Location
    Rochester, NY
    Message Count
    396
    Jul 30, 2012 - Re: What does everyone use to separate their Iron Man helms after fiberglass? #2
    I was planning on using the regular cutting wheels that work with my dremel.
  3. Join Date
    Jul 2012
    Message Count
    165
    Jul 30, 2012 - Re: What does everyone use to separate their Iron Man helms after fiberglass? #3
    Lord Magneto said: View Post
    Yeah, those tend to cut really thick, and not give very much flexibility for corners etc. Besides, they create a lot of dust, and wear down super fast.
  4. 100% Recycled Material Crank729's Avatar
    Join Date
    Oct 2011
    Location
    Canada
    Message Count
    745
    Jul 30, 2012 - Re: What does everyone use to separate their Iron Man helms after fiberglass? #4
    Try the diamond cutting wheels......but be warned, they cost 30 dollars!
  5. Join Date
    Jul 2012
    Message Count
    165
    Jul 31, 2012 - Re: What does everyone use to separate their Iron Man helms after fiberglass? #5
    I suppose a good question is, should I finish the helm with bondo and sculpting BEFORE I cut her free?
    Or cut it up, then do bondo?
    I'm concerned that I may not be able to get the curves exactly right if I cut it first.
    Thoughts?
  6. Tastyburger's Avatar
    Join Date
    Sep 2011
    Location
    Theresa, NY (WAYY North!)
    Message Count
    262
    Jul 31, 2012 - Re: What does everyone use to separate their Iron Man helms after fiberglass? #6
    I plan on seperating the jaw from my Dr. Doom after resining and light fiberglassing. That way, I can build my means of reattaching into the parts before the final fiberglassing and bondo work. Any small gaps can be addressed with bondo at that time.
    Look at it this way: You do all that work to get the curves right, then you ding them up during the cutting process. Gotta rework them now. Why not save final work for after the cuts? If the cuts are smooth, no time lost.
    My opinion, though..
  7. Join Date
    Jul 2012
    Message Count
    165
    Jul 31, 2012 - Re: What does everyone use to separate their Iron Man helms after fiberglass? #7
    Tastyburger said: View Post
    That was pretty much my reasoning behind doing the surgery now, as opposed to after I was done making her look beautiful. LOL
    Ok. You talked me into it. Surgery tonight it is!
  8. Join Date
    Jan 2010
    Location
    Worcester, Worcestershire UK
    Message Count
    281
    3 Weeks Ago - Re: What does everyone use to separate their Iron Man helms after fiberglass? #8
    Even if you detach them now you'll have to add some filler around the edges to fill out your cutting channels to ensure a close fit between edges , so I would cut, prep and finish each piece as you go , and diamond dremel is my preferred cutting tool Yes it's expensive but worth it in the long run
Similar Threads
  1. Iron man 3 Mark 8 Fiberglass / kevlar / Aluminium
    marcusleandro, Replica Movie Costumes
    Last Post: 1 Week Ago, 12:22 AM
  2. Stealth Iron Man Mk VI - Fiberglass/Foam Hybrid
    mizuno hadouken, Costume and Cosplay Showcase
    Last Post: Mar 28, 2013, 3:51 PM
  3. Resin or fiberglass over foam iron man suit?
    VegasSkywalker, Replica Movie Costumes
    Last Post: Dec 3, 2012, 10:52 AM
  4. Replies: 2
    Last Post: Jul 27, 2012, 10:29 AM
1 2 3 4 5 6 7 8 9 10 11
