Subscribe
  1. Manix's Avatar
    Member Since
    Dec 2010
    From
    LA, CA
    Messages
    33
    Mar 18, 2011, 4:55 AM - TrIr0n Man Build - 1st Build (Early Build Stage) #1
    I've had this idea to build an Iron Man armor based on the Marvel crossover promotion with Tron (this picture) since last November and I'm finally going forward with trying to assemble this myself. I have been looking for someone to commission the armor out of a durable/flexible material like plastic, but have not had such luck within the price I'm willing to currently pay for the outside work. I've gotten a lot of advice to build my armor from pep models, but the look I'm after is not the traditional detailed Mk. 3 through 6 everyone else is doing and that the pep models depict. I believe I'm going to attempt this using the trashcan method similar to chimmera30's great armors, though with as clean a look as possible to better represent a Tron look.
    Further differing my build plans from others, I'm going to be focusing primarily on functionality and ease of wearing rather than movie/comic look accuracy. It is also going to have cooling fans and lights. Unlike the image linked above, the colors I'm planning to go with are a black armor akin to the color of the vehicles in Tron Legacy with white power lights (repulsors and reactor) and blue piping lights via EL wire. I'm still debating on an accent color for the armor as the image is somewhat unclear about there even being another color on the armor. But this being a fan rendition it doesn't need to be exact.
    Overall, it's going to be fairly ambitious for a first project. I've got an Iron Man 2 toy helmet that I'm going to mod and paint for use with this project. Already have it taken apart to set up a fan or two inside and rewire the lights to stay on with the switch. I'm also retrofitting a Tron Deluxe disc via one of Soulinertia's great Full Retrofit Kits. I can't promise regular updates on this, but it will somehow come to fruition over time. Ideally in time for AX in July and hopefully in time for Halloween and beyond.
    Also, I hope that this will not be confused as being related to MasterLe's current work on a similar hybrid. Though seeing the "distaste" for his work through various threads, that probably won't be an issue. Any and all advice is welcome throughout this build.
  2. PirateDude's Avatar
    Member Since
    Apr 2010
    Messages
    64
    Mar 18, 2011, 5:04 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #2
    I'm looking forward to this.Good Luck.
  3. MykiiAmore's Avatar
    Member Since
    Jan 2011
    From
    United Kingdom
    Messages
    388
    Mar 18, 2011, 6:41 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #3
    I would have to say you would probably be better off the PEPing the thing and modifying it when needs arise. It woildnt be very hard at all to just modify when you come to the filler stage. The orange Tr0n lines could be done by just using a dremel
  4. chimmera30's Avatar
    Member Since
    Jan 2011
    From
    Newfoundland,Canada
    Messages
    629
    Mar 18, 2011, 8:19 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #4
    So great to see this as your choice,a tron/ironman !!!
    Gonna be amazin!
  5. Member Since
    Jul 2010
    Messages
    357
    Mar 18, 2011, 9:13 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #5
    If you're building the entire thing from scratch, I would recommend doing the helmet too. The toy helmet's eyes are too big and the ears stick out too much. Too bug looking in my opinion. If you really want to make this look as cool as the picture you posted, I would ditch the toy helmet.
  6. OmanTortuga's Avatar
    Member Since
    Oct 2010
    From
    Orchard Park, NY
    Messages
    93
    Mar 18, 2011, 10:03 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #6
    I am 100% in agreeance with Havok69
  7. Manix's Avatar
    Member Since
    Dec 2010
    From
    LA, CA
    Messages
    33
    Mar 18, 2011, 6:25 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #7
    I figured people would be against the toy helmet. Although I'm starting with it, I may move into a "regular" sized helmet after the the initial build so I have an option of what to wear. Gotta say though that I like having the visibility of the bug eyes opposed to looking through slits.
    I should mention that I intend this to be a long-term project without any end goal unless I manage to eventually build a working Iron Man armor made from actual metal that flies and shoots lasers. Of course that's the dream end, but basically I'll be updating it over time and maybe over Mk. versions of the suit. This will be Mk.1 Ver.1.
    @MykiiAmore: The main issue I have with pepping is that I don't want to work with resins and fiberglass. Without those, the paper wouldn't be strong enough to withstand wear. Also, I'm concerned with flexibility of the pieces and the ability to cut through sections for fan access, etc. Though I had considered the idea initially, I moved away from it since.
  8. phaeren86's Avatar
    Member Since
    Sep 2010
    From
    Sugar Land, Tx
    Messages
    201
    Mar 19, 2011, 3:38 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #8
    i was thinking of doing this same thing, just taking the pep route after getting through with my first suit as practice. can't wait to see how this turns out
  9. Bloop's Avatar
    Member Since
    Dec 2010
    Messages
    166
    Mar 19, 2011, 4:21 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #9
    Even though you said you're not going for complete accuracy, that image you're basing this on looks a little more like the War Machine armor in that it seems a little bulkier and more angular. So maybe there's some War Machine builds you can check out as a starting point? Just a suggestion. Though if you're looking for it to be easier to wear, I suppose you may want to go less bulky anyway.
  10. chimmera30's Avatar
    Member Since
    Jan 2011
    From
    Newfoundland,Canada
    Messages
    629
    Mar 23, 2011, 12:34 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #10
    Any updates?
  11. MykiiAmore's Avatar
    Member Since
    Jan 2011
    From
    United Kingdom
    Messages
    388
    Mar 23, 2011, 4:37 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #11
    I see what you are saying.
    Although, personally, I think one of the easiest way to do this would be by personalizing a pep or foam route.
  12. MykiiAmore's Avatar
    Member Since
    Jan 2011
    From
    United Kingdom
    Messages
    388
    Mar 23, 2011, 4:41 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #12
  13. Manix's Avatar
    Member Since
    Dec 2010
    From
    LA, CA
    Messages
    33
    Mar 28, 2011, 3:33 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #13
    Small update: Started on the Tron ID disc since I have a guide thanks to Soulinertia's kit. Made all the necessary cuts to my Tron disc and installed bevels and magnets. I accidentally drilled too large a hole for one of the bevels so it got a little ugly there.
    To add some customization, I'm gonna try to put LEDs into the bevels while trying to keep the disc to a 2-switch minimum (since I want the bevels to be able to light independent of the inner/outer rings. I'm also gonna try to set both battery holders by the compartment door.
    Once I'm finished with the disc I'll move to the helmet. I hope to rewire the existing switch to give constant light to the eyes and power a small fan I'm going to place where the speaker for the SFX is. If I can think of a way to automatize the face mask I'll implement it. I've seen some of the hing setups for "regular" helmets, but it shouldn't need something that complex since it already has it's own hinges on the sides. After that comes the real challenge of starting the entire body of the armor. Honestly, I'm a bit worried since I have no artistic ability creating things from scratch, but I'll do my best.
  14. Manix's Avatar
    Member Since
    Dec 2010
    From
    LA, CA
    Messages
    33
    Apr 18, 2011, 3:11 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #14
    So, progress has been very slow. So slow in fact, that I had no time for this in a couple of weeks. Finally got a few more hours in the other day and accidentally warped the top half of my Tron Disc and managed to take a couple of unsightly chunks out during the inner C-Ring cutting part. I've had it screwed back together for over a day so that it may retain it's shape when I get back to it tomorrow. I've ordered a few more if I can't salvage the top piece from the Disney store for a nice cheap $9.99.
    In other news, I figured I should probably paint my helmet while it's in pieces before modding it, rather than paint over the goodies once installed. Which brings me to ask how to interpret the color scheme for the overall costume. I've been thinking a mildly glossy black to mimic the Tron Legacy vehicles as the main color. Referring to the picture in my first post though, I'm not sure what to do for the secondary color. I can't really tell from the photo if it's two-toned or just "lighting" reflecting off a single colored armor. Any thoughts or ideas as to the color scheme I should go with? Considering that the EL detailing will be blue, it'd probably be fine being all one color, but what do you guys think?
  15. chimmera30's Avatar
    Member Since
    Jan 2011
    From
    Newfoundland,Canada
    Messages
    629
    Apr 18, 2011, 3:24 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #15
    Man I'm so happy to see this update ,I thought that you dropped this build!!!
    Pumped your building !!!
  16. HUFN8R's Avatar
    Member Since
    Mar 2011
    From
    Australia
    Messages
    47
    Apr 18, 2011, 4:05 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #16
    perhaps a semi gloss black all over but with a gun metal grey for the face plate just to break it up a little . either way its gona be an awesome build .
  17. Manix's Avatar
    Member Since
    Dec 2010
    From
    LA, CA
    Messages
    33
    Apr 18, 2011, 4:12 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #17
    Thanks chim! Yeah, not abandoning this project; gonna see it through to the bitter end. Just gonna be slow and steady. Since my optimum deadline is July, I'll probably be updating more frequently around late May-June to try and cram it to finish. My younger bro might be able to help me with the armor crafting around that time too since he's become a handy theater set craftsman in college.
    @ HUFN8R: Not a bad idea for the faceplate. Since I'm going for black, I especially wanna try to avoid it looking too much like a War Machine armor (just for clarity in case I decide to make a cross with him in the future). So I don't want any silver or light grays to two-tone with the black. However, Gun Metal might be enough to avoid misconception.
  18. HUFN8R's Avatar
    Member Since
    Mar 2011
    From
    Australia
    Messages
    47
    Apr 19, 2011, 6:55 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #18
    yeah because gunmetal grey is a lot darker than silvers or most greys. it might look alright just a thought since the pic you have looks a little 2 toned it might be enough to give it a subtle break up in tone.
  19. RPF Premium Member jaymay023's Avatar
    Member Since
    Nov 2009
    From
    Nor Cal, USA
    Messages
    224
    Apr 19, 2011, 9:17 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #19
    MOAR PIX! Lol. Would love to see your idenity disc
  20. Manix's Avatar
    Member Since
    Dec 2010
    From
    LA, CA
    Messages
    33
    Apr 19, 2011, 10:22 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #20
    jaymay023 said: View Post
    You're in luck! I just pseudo-finished it today. Again, the top half is messed up so I'll be replacing it once I get in my new disc. I figured I'd show off the blemishes as an example of what not to do to your disc. The LEDs in the bezels are the ones originally included with the disc, arranged in series, connected to the battery for the outer ring and controlled by a 3-position switch. I believe the "projection" LEDs were never on at the same time as the outer "blade" ring so I wired it up to be either/or those. The inner ring is independent of either the other LEDs.
    Also, still trying to figure out the overall color scheme. Sure it's my choice what colors I eventually use, but I appreciate the suggestions - it helps me narrow down my decision.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	51070   Click image for larger version.
ID:	51071   Click image for larger version.
ID:	51073   Click image for larger version.
ID:	51074   Click image for larger version.
  21. RPF Premium Member Soulinertia's Avatar
    Member Since
    Jan 2010
    From
    Colorado
    Messages
    1,767
    Apr 20, 2011, 12:47 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #21
    I like your LED bezel upgrade Manix.
  22. Nonsonic's Avatar
    Member Since
    Mar 2011
    From
    Canada
    Messages
    38
    Apr 20, 2011, 1:20 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #22
    very nice !
  23. Manix's Avatar
    Member Since
    Dec 2010
    From
    LA, CA
    Messages
    33
    Apr 28, 2011, 9:21 PM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #23
    Update: My bro's in town this week so we got to work with some design sketching and cast my Duct Tape Mannequin yesterday via the 405th tutorial thread linked by STEALTH not too long ago. I'll have a couple pics up later tonight. Still need to figure out a cheap stuffing material. I got some old shirts I was gonna throw out that I can use, otherwise I'm not sure what to stuff with. I was thinking some of the polyester stuffing bricks available at my local Joann's (at least it says so online). Any suggestions?
    Also, got my extra discs and started work on redoing my top half. The bevels are done and no mistakes this time. Just need to finish cutting out the inner C-Ring holder slowly this time and gluing in the new C-Ring to have that finished.
    Lastly, I gutted my toy helmet and have it ready for painting. Just need to get some good spray paints. Again, any suggestions? I've heard various things about painting to toy/garbage can plastic and not sure if just any spray will do or if I need a special "paint to plastic" kind. I've seen some people on here denouncing Krylon paints, so I guess I'll try to avoid that unless someone can attest on its behalf.
    Gonna be a busy weekend for me so I may not get around to this stuff 'til Monday after tonight. It's coming along though, and if we can power through at the rate we did yesterday in June then I should be done by my AX deadline.
  24. Manix's Avatar
    Member Since
    Dec 2010
    From
    LA, CA
    Messages
    33
    May 2, 2011, 2:28 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #24
    Sorry for the late pics of the mannequin. I'm currently thinking of going with a polyester fill for the dummy unless someone has a better idea. Also, still not sure what paint brand to go with.
Name:	Duct Tape 1.jpg
ID:	52168   Click image for larger version.
Name:	Duct Tape 2.jpg
  25. chimmera30's Avatar
    Member Since
    Jan 2011
    From
    Newfoundland,Canada
    Messages
    629
    May 2, 2011, 3:35 AM - Re: TrIr0n Man Build - 1st Build (Early Build Stage) #25
    sweet mannequin!
    now get some armor on his sweet bod!!!
Similar Threads
  1. IRON MAN MARK VI BUILD ... my 1st one ever
    3illa, Marvel Costumes and Props
    Last Post: May 16, 2014, 3:56 PM
  2. My 1st Iron Man and Thor Build for my kids
    bryanjas, Marvel Costumes and Props
    Last Post: Nov 4, 2013, 9:56 PM
  3. portal gun build 1ST BUILD EVA!!!!
    DoctorDork, Replica Props
    Last Post: Apr 26, 2013, 7:47 PM
  4. My 1st Build Iron Man Mark 47 XLVII Foam Armor
    Pepakuraprep, Marvel Costumes and Props
    Last Post: Apr 21, 2013, 4:23 PM
  5. Iron Man foam build - 1st attempt
    Manni, Marvel Costumes and Props
    Last Post: Sep 4, 2012, 5:19 AM
Tags
