SabrX
I've been working on a Space Marine costume using Pepakura and 6mm craft foam. I've assembled the helmet using hot glue gun and filled the seams with Silicon Acrylic filler, also known as "Caulk". After repeatedly applying multiple layers of Caulk and sanding, I thought my helmet's surface was smooth ready for plastidip. However, after a couple coats from spraying plastidip, I realize the crevices still show as seen in the following pictures:
What should I have done to prevent his from happening to other parts of my costume and what can be done to fix my helmet?
