Page 1 of 2 12 LastLast
Subscribe
  1. mpick67's Avatar
    Member Since
    Jul 2011
    Messages
    91
    Aug 15, 2012, 9:52 PM - Silhouette CAMEO Problem... #1
    I'm hoping someone here will be able to help me. I'm using Pepakura Viewer 3 for the Silhouette CAMEO and I'm having problems getting accurate cuts.
    I've played around with the "Distance Between Registration Marks" and I've gotten considerably more accurate cuts, but I'm still having trouble getting it to cut right. Also, I can't seem to get the
    Silhouette CAMEO to cut on the dashed lines. I went through a ton of cardstock just to get this far. If anyone has some pointers on how to fix these problems I would really appreciate it!
    I've included some pictures of my setting and the results I'm getting from them.
  2. Surreal Studios is offline Surreal Studios
    Aug 15, 2012, 10:37 PM - Re: Silhouette CAMEO Problem... #2
    I turn that feature off, I find that even when it cuts the fold lines you still have to score them with a exacto knife to get a clean fold and on the small parts with fold lines it ends up cutting them to bits. I have a Silhouette SD so I am not sure how to turn it off and on with the cameo as the set up looks alot different, but what i think it is looking for are the coloured lines for the folds and if the pep file is not set with a different colour line for the folds (in program) it wont recognize them, does it give you the option to change it to ----- and -.-.-.- for the fold lines instead of looking for coloured lines in the pep, if not try changing the colour of the fold lines in the pep designer itself.
  3. mpick67's Avatar
    Member Since
    Jul 2011
    Messages
    91
    Aug 16, 2012, 8:46 AM - Re: Silhouette CAMEO Problem... #3
    I have an option for "dashed cuts" and "solid cut line" for my CAMEO. But if you say I'm better off hand scoring them, I'll just do that. I still can't seem to get the accuracy of my cuts right. I'll try a few more things today.
  4. mpick67's Avatar
    Member Since
    Jul 2011
    Messages
    91
    Aug 16, 2012, 12:42 PM - Re: Silhouette CAMEO Problem... #4
    I've played around with the "Distance Between Registration Marks" some more. My new settings are: 195 and 251.5
    The weird thing is that the left and right cuts are dead on, but for the pieces near the top of the paper it's cutting slightly high. The middle piece is cut perfect, while the piece near the bottom is cut a little low. Any ideas?
  5. mpick67's Avatar
    Member Since
    Jul 2011
    Messages
    91
    Aug 16, 2012, 9:35 PM - Re: Silhouette CAMEO Problem... #5
    repost
  6. Dark Matter Props RPF Premium Member darkside501st's Avatar
    Member Since
    Apr 2010
    From
    Houston, TX
    Messages
    1,352
    Sep 19, 2012, 3:24 PM - Re: Silhouette CAMEO Problem... #6
    Like Surreal Studios, I too have the mountain and valley cuts disabled on mine as well. I like scoring the line instead. There is a setting to do this in the pep viewer program. Go to File > Cut Developments then click the Details button.
    I set my registration marks to 10mm margins and I think the program originally told me to set my registration marks at 195mm and 259mm but I found that adjusting mine to 195.5 and 260mm worked better for me. Now my cuts are pretty much spot on. Now the program is telling me to set my marks to 190mm and 277mm so the next time I cut I may have to adjust again... not sure why it changed... maybe an update to the program... idk.
    The distance between the registration marks is the key. The two numbers determine what 'scale' the parts cut at. So if your cuts are coming out bigger than the printout then you need to tell the machine that the distance between the registration marks is bigger and that will make the part that gets cut smaller. If your cuts are smaller than the printout then you need to tell the Cameo that the distance is smaller and this will make the cutout bigger. If you have adjusted the width so that the cuts match up but the length is still off then you only need to adjust the second number. You can try and measure the distance between the cut and the print line and then adjust the length by that amount. That will get you pretty close. Then you will need to do some good old trial and error.
    Try reading through some of the posts here:
    Complete Pepakura Viewer for CraftROBO guide/FAQ
  7. RPF Premium Member Bigturc's Avatar
    Member Since
    Dec 2007
    Messages
    1,740
    Sep 20, 2012, 5:57 PM - Re: Silhouette CAMEO Problem... #7
    Damn!!!
    Thanks to this thread, I thought it was just my SD cutting slightly off as I go higher on the page!!!
    Not that I use it anymore a lot, but I'll remind that!!! Thanks guys!!! Much appreciated!
  8. Kormier's Avatar
    Member Since
    Sep 2011
    From
    Ontario, Canada
    Messages
    181
    Dec 15, 2012, 5:14 PM - Re: Silhouette CAMEO Problem... #8
    I find that if you set the cutline settings for Cutline Segment and Uncut line segment to 0.5 mm you get pretty good puncture along the fold lines.
  9. mecha2040's Avatar
    Member Since
    Jan 2013
    From
    The city of winds if you catch my drift
    Messages
    63
    Jan 18, 2013, 11:33 PM - Re: Silhouette CAMEO Problem... #9
    I'm having this exact same problem with my recently purchased Cameo, cuts are off at the top of the page but dead on at the bottom, I follow darkside501st recommendation on setting the registrations to 195.5 and 260.0 and somewhat worked for me, but still not dead center, don't know maybe they are not supposed to be, as the silhouette cameo might not be that exact. anyways if there are any other recommendations please let us know!!!
  10. Dark Matter Props RPF Premium Member darkside501st's Avatar
    Member Since
    Apr 2010
    From
    Houston, TX
    Messages
    1,352
    Jan 19, 2013, 11:34 AM - Re: Silhouette CAMEO Problem... #10
    mecha2040 said: View Post
    Those settings are what worked for me... the discrepancies between different people could be due to the different printers being used. You may have to play with it a little more to get the settings right for you.
  11. mecha2040's Avatar
    Member Since
    Jan 2013
    From
    Messages
    63
    Jan 19, 2013, 11:58 AM - Re: Silhouette CAMEO Problem... #11
    darkside501st said: View Post
    Don't know how but after I apply your settings to mine after a few sheets the cuts began to be spot on and finished cutting with flying colors, thanks for the help man !
  12. mecha2040's Avatar
    Member Since
    Jan 2013
    From
    Messages
    63
    Jan 19, 2013, 12:00 PM - Re: Silhouette CAMEO Problem... #12
    Also not sure why but my viewer for cameo cutting settings are in Japanese not sure why they're not in English, any idea on how I can change the language ?
  13. Dark Matter Props RPF Premium Member darkside501st's Avatar
    Member Since
    Apr 2010
    From
    Houston, TX
    Messages
    1,352
    Jan 19, 2013, 12:09 PM - Re: Silhouette CAMEO Problem... #13
    That's great! I am glad it worked for you. I am not sure about the language... it has been a long time since I installed the program. Most programs will have you choose the language when you install them.
  14. mecha2040's Avatar
    Member Since
    Jan 2013
    From
    Messages
    63
    Mar 12, 2013, 9:56 PM - Re: Silhouette CAMEO Problem... #14
    HELP ! ! ! !
    I'm having a big problem, Silhouette Cameo not reading registration marks, everything was working just fine until today, it just won't read the registration marks, any ideas of why this might be happening and how to fix???
  15. Dark Matter Props RPF Premium Member darkside501st's Avatar
    Member Since
    Apr 2010
    From
    Houston, TX
    Messages
    1,352
    Mar 13, 2013, 9:02 AM - Re: Silhouette CAMEO Problem... #15
    HELP ! ! ! !
    The only time I had that problem was when I had mistakenly put the page on the cutting mat in the incorrect orientation.
    If that is not your problem then I would try to uninstall Pep Viewer for Cameo and the controller then reinstall both again.
  16. Member Since
    Feb 2011
    From
    Langley B.C.
    Messages
    108
    Mar 13, 2013, 4:18 PM - Re: Silhouette CAMEO Problem... #16
    Another option to try would be to clean the optical sensor, just shoot a little "Dust off" or something like it around by the blade. That is where the sensor hides. Good luck.
  17. mecha2040's Avatar
    Member Since
    Jan 2013
    From
    Messages
    63
    Mar 13, 2013, 10:07 PM - Re: Silhouette CAMEO Problem... #17
    Thanks for the Help guys, I actually had to uninstall Pepakura Viewer for Cameo, just before the current job I did a 8 page landscape cut, and it must have got stuck in the program don't really know why, but after I re-installed viewer everything works just fine, like new.
    Again thank you, and hope this helps someone else if anything!
  18. Kormier's Avatar
    Member Since
    Sep 2011
    From
    Ontario, Canada
    Messages
    181
    Mar 14, 2013, 12:08 PM - Silhouette CAMEO Problem... #18
    The thing is, even if your cuts are now 100% aligned with your printed shape, the overall end product will still be the right size. In the end it may just mean that your folds may be a bit off from the printed fold lines.
  19. Dark Matter Props RPF Premium Member darkside501st's Avatar
    Member Since
    Apr 2010
    From
    Houston, TX
    Messages
    1,352
    Mar 15, 2013, 10:10 AM - Re: Silhouette CAMEO Problem... #19
    Kormier said: View Post
    I think you meant to say even if they are NOT 100% aligned... However this is not necessarily true. In some cases the cuts will start out right on target and then diagonally across the page they will be off the line. This means that the cuts are becoming distorted... this small distortion can add up as you start gluing the parts together and it can either cause problems aligning the tabs or it could cause an end result that can be distorted ever so slightly. It will definitely be worth while to try and get the cuts as close to the printed lines as possible.
  20. Kormier's Avatar
    Member Since
    Sep 2011
    From
    Ontario, Canada
    Messages
    181
    Mar 15, 2013, 11:32 AM - Silhouette CAMEO Problem... #20
    Yes. I meant NOT aligned.
  21. typewriter is offline typewriter
    May 14, 2013, 7:47 AM - Re: Silhouette CAMEO Problem... #21
    Hi everyone! I just received my Silhouette Cameo today and I've done some experimenting on it. The first problem was: I couldnt get it to read my registration marks.. So after 2 hours of failed trials, I finally came across a thread in the 405th as mentioned by darkside and it turns out that there was too much light in my room. So I closed the lid of the cameo and the registration mark read 1st time around. Now 2nd problem : after it read the makrs, I proceeded to cut developments on the cameo viewer and naturally being excited, I was disappointed to see that only ONE part got cut. and the cuts weren't even close to the lines. (1-2mm off) I know its been asked, but I really dont know what to do. If someone could lend a helping hand, it would be awesome, because currently I am building Darkside's Markvii (thanks darkside). Thanks!
  22. Dark Matter Props RPF Premium Member darkside501st's Avatar
    Member Since
    Apr 2010
    From
    Houston, TX
    Messages
    1,352
    May 14, 2013, 9:56 AM - Re: Silhouette CAMEO Problem... #22
    typewriter said: View Post
    check this out:
    http://www.therpf.com/f24/silhouette...3/#post2481753
    Let me know if you have any questions.
  23. typewriter is offline typewriter
    May 15, 2013, 12:48 AM - Re: Silhouette CAMEO Problem... #23
    check this out:
    Thanks Darkside, I read that and also your tutorial on how to export DXF file and I will try both methods now.. I wasted 10 pcs of paper yesterday trying to figure this one out, will definitely give them a try, thanks again!
  24. typewriter is offline typewriter
    May 15, 2013, 1:18 AM - Re: Silhouette CAMEO Problem... #24
    Hi again everyone, I read through Darkside's tutorial found here : http://www.tamasoft.co.jp/pepakura-e...ameo_users.pdf on exporting DXF files, sure it doesnt have the numbers on the edge but it cuts PERFECTLY, so I want to thank darkside for teaching me this! I am using A4 sized paper, and i will experiment with this technique!
  25. RPF Premium Member Bigturc's Avatar
    Member Since
    Dec 2007
    Messages
    1,740
    May 27, 2013, 2:05 PM - Re: Silhouette CAMEO Problem... #25
    You didn't waste 10 pages .. you experimented on 10 pages. Trust me, trying stuff if the way to go. Some people won't even do it and go straight to asking questions!
    Keep at it! Those cutters are what everyone should have at home!
Similar Threads
  1. Replies: 8
    Last Post: Jan 23, 2015, 3:51 PM
  2. Pepakura viewer for cameo silhouette
    Juicebox, Replica Costumes
    Last Post: Apr 28, 2013, 4:07 PM
  3. Silhouette cameo problem
    Benf, Replica Costumes
    Last Post: Mar 12, 2013, 6:18 PM
  4. Replies: 2
    Last Post: Jan 26, 2013, 8:49 PM
  5. Silhouette Cameo
    THE DARK KN1GHT, Replica Costumes
    Last Post: Jul 18, 2012, 4:57 PM
