Hey, thanks for the reply
jessamygriffin.
My friend is making it for me and has a certificate 4 in fashion & textiles (I hope that's good
). Your blog and notes are invaluable, and since I'm at the ordering stage, I wonder at the ratios I should be getting (eg, if I get 6 metres of wool then how much interlining/interfacing will I need? Will it go under all of the coat or just parts?)
Also, my friend is going to machine-pad stitch it. Does that mean I don't need fusable interfacing, or is that a separate layer? I'm a tad confused.
I will definitely forward whatever else you have to say in regards to the making of it to my friend, since yours looks so damn good. Are there any other bits like the Back Stay that I should be aware of?
I think I'm going to go with the cosplaysky wool (no idea what their weight is), although I'm also curious to see how the magnoli one turns out and what it costs per metre. The swatch seems good.
For such a rubbish posting I did on the coat, not to mention the pattern sketches, I am always happy and yet amazed that it's ended up being such a resource. Tell your friend to be aware I got the collar band wrong - wasn't aware until S2 and I found Ray's coat pics. Made me gnash my teeth. The post
here hasn't been edited but a person did come back in the comments to discuss and also put up some pics of how it should look, which is awesome. Check the comments down a bit.
Here you can see the guts inside, including, yes, a backstay, and shoulder reinforcement. You can see that the interfacing doesn't mean the entire coat - the wool I used was about a med weight and draped heavy and smooth and didn't need a full interlining. You'll definitely need it in the front so it lays smooth, gives a crisp edge to the front and of course supports the lapels and collar. Apparently you can also add some to the hem as well to give it weight? So says the Tailoring book.
So unless you are using some really light weight wool, you wouldn't need a complete interlining? And NOT in the mohair throughout! That stuff is heavy and stiff - you'd feel armour-plated.
So taking into account the above, no you don't need 6 m of mohair interlining for sure. Just for the front and collar. If she's pad stitching it, you probably don't need much fusible. I used some on the patch pockets, the welt pockets, the inner front and the top collar. The under collar had mohair for stiffness and shaping. Check the third pic down
here. I should have taken more pics, I guess, but...hey.sewing. In the guts link above, you can see I pad stitched mine, but had to do it ye olde way by hand. Machine pad stitch? Jealous!
I think I bought 6 m of wool originally. I didn't need it.... OR SO I THOUGHT. I decided the coat wasn't long enough and re-cut the back skirt. STILL had plenty. Oh and of course I mucked up the armscythe on the sleeves in SPITE of having made a test coat. So those got re-cut as well. And one path pocket ended up with the pattern of the houndstooth going the wrong way so that got recut. I am embarrassed to say there wasn't a meter of wool left by the end.
Oh and the back stay is just some light tight weave cotton broadcloth, nothing fancy.
**edit - Oh wait, just forgot - my journal is marked as adult content, not for the coat stuff unless you count swearing. But you probably have already seen that.
