1. Join Date
    Oct 2011
    Message Count
    21
    Nov 19, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #526
    I was wondering if anyone had any armor pep files that resembles Frank Jaegar/Gray Fox from MGS1
    reference images
    http://4.bp.blogspot.com/-WO3KXlrHn5...o/s1600/15.jpg
    http://4.bp.blogspot.com/-6xeILzr_mY...M/s1600/16.jpg
    Also if anyone has something similar to the vest and shoulder pads from Snake MGS1
    reference
    http://4.bp.blogspot.com/-weUx_PhCV5...s/s1600/22.jpg
    http://3.bp.blogspot.com/-Gyiu8752Ss...k/s1600/24.jpg
    Only pics i found showing front and back.
  2. Lord Magneto's Avatar
    Join Date
    Oct 2011
    Location
    Rochester, NY
    Message Count
    396
    Nov 19, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #527
    Anyone have any good suggestions for getting rid of excess fiber glass cloth that has been applied to your pep file? I basically have a bunch of excess cloth that is hanging off the edges of my helmet. I've tried using my rotary tool but I'm guessing I need a different attachment. Maybe some sort of cutting attachment
  3. Keven Skywalker's Avatar
    Join Date
    Jun 2011
    Location
    Argentina
    Message Count
    56
    Nov 20, 2011 - R2D2 help unfolding #528
    Hi all, found a full r2d2 pep file on de web and i need some help unfolding (i am relatibly new user pepakura designer)
    and i am without time to learn un unfoldit bevause in 17 days i have an expo an my team an i need to build an artoo fast. if someone could help me to unfold please you could save us all
    link: R2D2 tamano real.pdo - 4shared.com - online file sharing and storage - download
  4. Formerly ManfromNaboo DaddyfromNaboo's Avatar
    Join Date
    Mar 2004
    Location
    Germany
    Message Count
    9,588
    Nov 20, 2011 - Re: R2D2 help unfolding #529
    Keven Skywalker said: View Post
    Hi all, found a full r2d2 pep file on de web and i need some help unfolding ...
    Hi,
    the 3d model is already completely unfolded. You simply have to print it out.
    I suggest changing the paper size to something larger than letter or A4 though, you could have the single pages printed out at a copy shop maybe on DIN A1 paper. Otherwise your R2 might look a little "patchy".
    Please see posts in this thread for information about pepakura and how to use it.
    In addition I recommend this thread here
    http://www.therpf.com/f9/r2d2-budget...tos-up-129597/
    or this one from instructables:
    Full Size R2D2 on a budget
    Looking at the time frame Iīd say that you should have enough time to build a basic wooden R2
    Michael
    RPF staff
  5. Rick Hanson's Avatar
    Join Date
    Aug 2002
    Message Count
    1,643
    Nov 20, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #530
    lord magneto said: View Post
    The reinforced cutoff wheels will make short work of something like that. A dust mask and *good* eye (or full-face, preferably!) protection are an absolute requirement. You may also need to buy the proper mandrel (Dremel part # 402) for them if your kit didn't come with one. Use the wheel to cut off as much excess material as you dare without actually damaging the helmet, and then finish up by hand sanding or filing the remainder off. Should work like a champ.
  6. Lord Magneto's Avatar
    Join Date
    Oct 2011
    Location
    Rochester, NY
    Message Count
    396
    Nov 20, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #531
    Rick Hanson said: View Post
    Much appreciated heading out now to pick it up
  7. Lord Magneto's Avatar
    Join Date
    Oct 2011
    Location
    Rochester, NY
    Message Count
    396
    Nov 20, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #532
    Found exactly what I needed at Harbor Freight for $5 for 5 different sized mini saw blades for my rotary tool... cut through the fiber glass like butter.
    Thanks!
  8. scorpion's Avatar
    Join Date
    Jan 2010
    Message Count
    161
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #533
    need help with pepakura scale!!
    i am building dancingfool's iron pep but i don't know how to scale the armor the original pep size is 1.525000 for 6" thought but i am 5.6"
    example: chest
    hight 347mm
    width 406mm
    depth 197mm
    i will appreciate your help too much guys i'm a bit lost here
  9. Banned
    Join Date
    Apr 2010
    Location
    Arkansas
    Message Count
    1,107
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #534
    Measure from armpit to armpit across the front of your chest, convert the inches to millimeters and put the number you get into the Width Factor in Pepakura Designer.
  10. scorpion's Avatar
    Join Date
    Jan 2010
    Message Count
    161
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #535
    PepMaster said: View Post
    thankss pepmaster
    so number i've got for the chest (example 1.535836) i will have to use in all the files that is correct? or i will have to measure all the body??
  11. Banned
    Join Date
    Apr 2010
    Location
    Arkansas
    Message Count
    1,107
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #536
    You might be able to use the same scale ratio for all the files, I don't know how Dancin_Fool did his files.
  12. Djymm's Avatar
    Join Date
    Oct 2010
    Location
    Fredericton, Canada
    Message Count
    66
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #537
    After searching both this site and google I still haven't been able to find an answer to this question so hopefully someone here can help. My question is about straps, and what stage to attach them. Is this something you would do before resining the mask or after putting on the bondo? Also and tips on what any of you would use for straps and how you would attach them would be great, thanks.
  13. Banned
    Join Date
    Apr 2010
    Location
    Arkansas
    Message Count
    1,107
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #538
    I do my strapping after everything and the aint has been done. Usually nylon webbing, 2 part epoxy and quick release buckles.
  14. Lord Magneto's Avatar
    Join Date
    Oct 2011
    Location
    Rochester, NY
    Message Count
    396
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #539
  15. Banned
    Join Date
    Apr 2010
    Location
    Arkansas
    Message Count
    1,107
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #540
    NEZAHUAL said: View Post
    I was wondering if anyone had any armor pep files that resembles Frank Jaegar/Gray Fox from MGS1.
    There is a awesome pep file of the helmet on the tamasoft pepakura gallery, there are no files yet for the armor a lot of people have just used padding. I've made a couple suits for Grey Fox with a padding method inbetween two zentai suits. It's a lot of work but excellent results.
    @ Magneto- The only cutting machine that works with pepakura is the CraftROBO machines, there's a tutorial on how to run the machine over on the 405th. I've hear a few people testing Pep with Cricut and have not seen any results yet.
  16. Rick Hanson's Avatar
    Join Date
    Aug 2002
    Message Count
    1,643
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #541
    Thanks!
    Awesome, glad it worked out for ya!
  17. Join Date
    May 2010
    Message Count
    79
    Nov 21, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #542
    Looks to me, from a quick pass through a couple of CriCut pages, that those machines are cartridge-controlled rather than taking their commands from a computer connection. I doubt you could get a CriCut to even look at a pepakura pattern.
    The Silhouette SD, a similar machine which I purchased last year for less than the CriCut you linked (not MUCH less - was $180 for the machine, IIRC), will accept commands from the pepakura program over a USB cable, and works like a charm.
  18. PR85's Avatar
    Join Date
    Nov 2011
    Location
    Oklahoma, USA
    Message Count
    27
    Nov 22, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #543
    erictank said: View Post
    it doesn't by chance have a perforation feature does it? I am assuming it probably just cuts the piece out and that's it (still a huge time saver).
  19. Join Date
    Oct 2010
    Message Count
    37
    Nov 22, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #544
    PR85 said: View Post
    Perforation is just making dashed cuts(cut a millimeter or two, lift blade, move a millimeter or two, repeat). Every cutter that is supported by Pepakura Viewer for CraftROBO should be able to do it.
  20. Aphius's Avatar
    Join Date
    Jul 2010
    Message Count
    91
    Nov 23, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #545
    Hey guys,
    I wanted to ask about what people do when sanding stuff made with Pepakura.
    I have been making some things by slush casting resin inside pepakura recently and I've found that when it comes to sanding these things, I sometimes get parts where the paper gets fuzzy from sanding. It feels smooth to the touch but when I apply primer it soaks(?) into the exposed paper and looks pretty ugly.
    I remember someone here on RPF mentioning how they took care of it on their props, but I couldn't find anything through the search. Anyone have any advice/experience with the same thing?
  21. SaberFreak's Avatar
    Join Date
    Dec 2005
    Message Count
    1,984
    Nov 24, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #546
    Either coat the outside with a layer of resin, or paint the exposed areas with emulsion paint, lightly sand(with 600-800 grid sandpaper), then prime.
  22. Banned
    Join Date
    Apr 2010
    Location
    Arkansas
    Message Count
    1,107
    Nov 24, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #547
    The problem is that I've found that the paper does'nt like paint without something like resin inbetween. So the trick is to sand the resin but don't sand down to the paper. For me I use urathane resin on all my pep pieces, I brush 2-3 coats on the outside and do a quick slush cast inside and it turns out pretty good and not a lot of sanding to do.
  23. Join Date
    Oct 2011
    Message Count
    21
    Nov 25, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #548
    do you use fiberglass or just the resin?
  24. Banned
    Join Date
    Apr 2010
    Location
    Arkansas
    Message Count
    1,107
    Nov 26, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #549
    I don't use fiberglass anymore at all, all I use inside and out is urathane resin. I hardly even use bondo anymore, I use sheetrock putty now, sand and brush a coat of resin after the sanding is done.
  25. Join Date
    Mar 2011
    Message Count
    145
    Nov 26, 2011 - Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! #550
    tutorial?!?!?!?
Similar Threads
  1. Replies: 77
    Last Post: Dec 4, 2012, 10:48 AM
  2. Convention rules question (weapon related)
    JediJayne, Replica Movie Props
    Last Post: Feb 28, 2012, 11:24 AM
1 2 3 4 5 6 7 8 9 10 11
