the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > COSTUMES AND COSPLAY > Replica Movie Costumes
The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST!
Discussion on The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST! within the Replica Movie Costumes forum, part of the COSTUMES AND COSPLAY category; Originally Posted by PR85 it doesn't by chance have a
Reply
LinkBack Thread Tools
Old 11-27-2011, 02:44 PM   #551
erictank has not been awarded enough reputation to matter.
Re: The PEPAKURA question thread - PLEASE READ RULES IN FIRST POST!
Quote:
Originally Posted by PR85 View Post
it doesn't by chance have a perforation feature does it? I am assuming it probably just cuts the piece out and that's it (still a huge time saver).
The Silhouette? Yeah, it does - like German said, any cutter supported by the Pepakura Viewer program will do perforations. Be aware that perfs may sever small pieces like tiny tabs, and make it more likely that you'll rip your parts separating them from the rest of the cardstock.
You'll still be ahead of the game with the machine, though.
erictank is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 12-06-2011, 02:16 PM   #552
danmaccymcleod has not been awarded enough reputation to matter.
excellent thread... That's a lot of information to chew on. Thanks.
danmaccymcleod is offline   Reply With Quote
Old 12-09-2011, 10:44 PM   #553
Indigogyre has not been awarded enough reputation to matter.
Textures in Pep files.
I've seen a few pep models that have had colors assigned to different parts and wanted to know how it's done. I've tried playing with the textures in Designer but have no managed to get them in there.
Here's an example of what I would like to do.
thanks.
Dean
Indigogyre is online now   Reply With Quote
Old 12-10-2011, 01:31 PM   #554
PR85's Avatar
PR85 has not been awarded enough reputation to matter.
Quote:
Originally Posted by PepMaster View Post
I don't use fiberglass anymore at all, all I use inside and out is urathane resin. I hardly even use bondo anymore, I use sheetrock putty now, sand and brush a coat of resin after the sanding is done.
Do you mind my asking where you get your urathane resin at? I have found a few places online, but I haven't really heard from anyone on here where the buy.
PR85 is offline   Reply With Quote
Old 12-10-2011, 02:52 PM   #555
Banned
PepMaster has a reputation level greater than 200!PepMaster has a reputation level greater than 200!PepMaster has a reputation level greater than 200!
I get the Model-Pro resin from Speciality Resin on eBay I usually buy the 2 gallon kit for 100 and it goes a long way.
PepMaster is offline   Reply With Quote
Old 12-11-2011, 01:00 AM   #556
RPF Premium Member
STEALTH's Avatar
STEALTH has a reputation level greater than 50!
if you do a search on polyurethane resin on google. You'd find a lot. That's probably why exact details aren't mentioned as resources are easy to find if you just search
first results that show is "Smooth-on"
check the smooth-on website for a distributor near your area.
Oklahoma
Reynolds Advanced Materials
2131 S. Harwood St.
Dallas, TX 75215
(800) 421-4378
www.reynoldsam.com
You can save some money on shipping if you go directly there most likely.
and should be pretty cheap even if you need it shipped.
STEALTH is offline   Reply With Quote
Old 12-11-2011, 10:51 AM   #557
Lord Magneto's Avatar
Lord Magneto has a reputation level greater than 10!
Anyone have any tips for spot filling?
When I use Bondo I will run into what looks airpockets when sanding.
Should I just try and mix a small batch of Bondo to fill then sand or does everyone use something else.
Lord Magneto is offline   Reply With Quote
Old 12-11-2011, 02:03 PM   #558
Banned
I use Bondo Spot Putty.
Old 12-11-2011, 07:43 PM   #559
Thanks homie. I will look into that
Old 12-12-2011, 06:40 AM   #560
German has not been awarded enough reputation to matter.
Re: Textures in Pep files.
Quote:
You have to texture the model with an external 3D program. If you are building the model from scratch, this is easy to do and you should already know how to build a UV map and texture. Assuming this is a pepakura file that you want to color then you have to do something like:
  1. Export the pepakura model as an OBJ.
  2. Open in your favorite 3D modeling program like Maya, 3D Studio, etc. and hope the model already has a UV map. If it does not, you are out of luck and are going to have create one, do the same things below and also unfold it again.
  3. Then you can just 3D paint or assign colors/shaders by polygons, etc.
  4. Save your texture as a .bmp, .jpg, .png or .tga.
  5. Open up your pepakura file and go to Settings->Texture Settings
  6. The list box on the left is a list of all the polygon groups in the model, most pepakura files only have one but depending on their source, there could be more than one. Each of these would need its own texture. Depending on the 3D program you used, you may just need to specify the same texture image for each group or possibly create new ones for each.
  7. Click Specify Texture Image... and pick your file.
  8. You should see a textured model.
I actually did this to texture the Republic Commando model that is floating around out there. I got lucky and someone created it with a UV map, so all I had to do was screenshot the texture from the game assets and apply it, which was nice.
German is offline   Reply With Quote
Old 12-12-2011, 06:48 AM   #561
AxiomUltra's Avatar
AxiomUltra has not been awarded enough reputation to matter.
German is right. Pepakura is just a glorified UV coordinate layout program. For me, when I do an unfold in Pepakura the parts that are laid out in the 2D 'paper' space are your UVs. When you export your object (.obj) the unfolded parts are assigned as UVs in a 1:1 square space. So it is important that you arrange your page layout to be as square as possible so you can take advantage of the resolution. Pepakura won't import hi-res texture files for me, I think the max is 1024? Someone correct me if I'm wrong I don't remember it's been a while.
AxiomUltra is offline   Reply With Quote
Old 12-12-2011, 07:05 AM   #562
Quote:
Yep, it will warn you about the maximum and then automatically scale it down to 1024x1024 for you.
Old 12-12-2011, 10:23 AM   #563
Keven Skywalker's Avatar
Keven Skywalker has not been awarded enough reputation to matter.
Re: R2D2 help unfolding
Quote:
Originally Posted by ManfromNaboo View Post
Hi,
the 3d model is already completely unfolded. You simply have to print it out.
I suggest changing the paper size to something larger than letter or A4 though, you could have the single pages printed out at a copy shop maybe on DIN A1 paper. Otherwise your R2 might look a little "patchy".
Please see posts in this thread for information about pepakura and how to use it.
In addition I recommend this thread here
http://www.therpf.com/f9/r2d2-budget...tos-up-129597/
or this one from instructables:
Full Size R2D2 on a budget
Looking at the time frame I´d say that you should have enough time to build a basic wooden R2
Michael
RPF staff
Michael,
Thakns for the data the event has passed and here is the result
Thanks for all your help, with some members of the Cruz del Sur base we got it just on time (there remains some details to make, and we will make them in the future)
Also when i get some time i will make a post showing the build.
thanks again
Keven Skywalker is offline   Reply With Quote
Old 12-15-2011, 10:28 PM   #564
Thanks German and AxiomUltra for the UV map and texture information.
Dean
Old 12-19-2011, 11:08 AM   #565
PR85's Avatar
Oklahoma
2131 S. Harwood St.
Dallas, TX 75215
(800) 421-4378
Reynolds Advanced Materials | Everything for Mold Making & Casting
Thanks, Smooth-On is where I have been buying from. I just wasn't sure if there was a better/cheaper alternative and with the vast variety out there of different types of resin, I wasn't sure if anyone had any recommendations as to what would be good to use. I have been trying to research and study up and what all the different aspects do and mean, but I am still pretty new to it all and get confused.
Old 12-19-2011, 01:04 PM   #566
OBI WAN KEN0B1's Avatar
OBI WAN KEN0B1 has not been awarded enough reputation to matter.
3D modeling software ???
What is a good 3D modeling software to use to make Pep Files. I am just getting into this and want to make some original art for Pep modeling. you Know to make some rare Stuff that i can't find. Let me know what Ya'll Think
PEACE OBI
OBI WAN KEN0B1 is offline   Reply With Quote
Old 12-19-2011, 01:21 PM   #567
RPF Staff - Formerly ManfromNaboo
DaddyfromNaboo's Avatar
DaddyfromNaboo has a reputation level greater than 300!DaddyfromNaboo has a reputation level greater than 300!DaddyfromNaboo has a reputation level greater than 300!DaddyfromNaboo has a reputation level greater than 300!DaddyfromNaboo has a reputation level greater than 300!
Re: 3D modeling software ???
Quote:
PEACE OBI
See the first post in this thread.
Michael
RPF staff
DaddyfromNaboo is offline   Reply With Quote
Old 12-21-2011, 06:44 PM   #568
RPF Premium Member
elro's Avatar
elro has a reputation level greater than 10!
Quote:
Originally Posted by TONKA1675 View Post
Is there any way to clean brushes between layers of fiberglass resin, or do you have to kiss one goodbye with each use?
I keep a cup of Acetone to put brushes in between mixing resin. Once the brush is needed Ill dab it on the table to get rid of excess acetone, and flick the bristles a bit. It can be a bit wet still when you dip it in the resin, the small amount of acetone has never had any problematic effects on my resin.
Some people say paint thinner, but I find acetone to be safer to keep on hand - Also effective at cleaning up accidental resin resin spills on the ground or on your skin .
elro is offline   Reply With Quote
Old 12-22-2011, 05:31 AM   #569
The RPF Dinghy
EyeofSauron's Avatar
EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!EyeofSauron has a reputation level greater than 1,000!
remember tho acetone is also not good on your skin, and even worse to inhale.
i prefer the good old method. after i am finished with a batch of resin, i take a lot of paper, and get as much of the resin out as possible with that. that way, im still using my first set of brushes
EyeofSauron is offline   Reply With Quote
Old 12-22-2011, 07:45 PM   #570
RPF Premium Member
elro's Avatar
Acetone will either irritate your skin, or not irritate it. Its not actually that bad.
Here is strange story in terms of ingestion (which you would only ever actually intentionally drink acetone - Drinking by accident is a pretty big fail) :
One case report describes a man who intentionally drank 200 mL (about 7 ounces) of acetone. Within one hour, he had flushed cheeks and appeared drunk. His breathing was shallow and his throat red and swollen. He soon lapsed into coma and did not regain consciousness for 12 hours. Four weeks later, he developed symptoms similar to diabetes (increased urination, thirst and blood sugar levels). The patient fully recovered within 5 months after the incident.
Full article about acetone here : Acetone Dangers Acetone Toxicity
This actually makes me wonder should the RPF start a Workplace Health & Safety sub forum with access to MSDS sheets and general safety guidelines for materials?
Old 12-24-2011, 03:03 PM   #571
Rick Hanson's Avatar
Rick Hanson has a reputation level greater than 10!
elro is right about the acetone - as far as harmful chemicals go, it's actually among the few that don't cause any appreciable health effects via skin absorption. See: nail polish remover. It can cause surface irritation in some people, but it's surprisingly OK to wipe it on your skin. Still ought to wear a respirator around it, though.
I use disposables for resins...chip or acid brushes. Cheaper than dirt in bulk at any industrial or welding supplier.
Rick Hanson is offline   Reply With Quote
Old 12-26-2011, 10:02 PM   #572
Banned
It might cause skin problems with some people. But it's definatly cold as hell.
Old 12-27-2011, 01:42 AM   #573
Zander's Avatar
Zander has not been awarded enough reputation to matter.
Anyone else having the problem?
I have converted my file to a .OBJ, but pep crashes every time I try to open it
Zander is offline   Reply With Quote
Old 12-27-2011, 12:05 PM   #574
Banned
That means there's a problem with the OBJ file, most of the time that's due to a problem with the model being too High Poly, or some other problem with the 3D file. Since it was a conversion from the original file I would say that's where your problem is.
Old 01-02-2012, 12:45 PM   #575
darklord1976's Avatar
darklord1976 has not been awarded enough reputation to matter.
I have a file that needs to be unfolded, can anyone help me? I tried to get the sizing but it seems too big. It is Starkiller's Dark Lord armor. Any help would be appreciated
darklord1976 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pepakura help (yes I already tired the pepakura help thread) SunnyHours Replica Movie Costumes 2 09-07-2011 03:25 PM
PLEASE READ: Updating Thread Titles Art Andrews Announcements and News 0 06-06-2010 12:56 PM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
