im the same height as you and muscular as well for example 5'11'' 36'' waist 11 shoe 24 '' head. but im also 250 lbs! 52'' chest 20'' neck 19'' bicep so scaling is tricky to say the least...scaling and maintaining proportion even more of a pain in the ass. but no worries ths is doable bro. it took me a while. learning from the tutorials put out by stealth and jfcustoms i finally figured it out.
-ok 1st things 1st lets figure out your basic scale based on your height.
thank you Darkside501st for this awesome scaling chart:
5'3" - 5'4" try in between scale 22 - 23
5'5" - 5'6" try in between scale 23 - 23.5
5'7" - 5'8" try in between scale 23.5 - 24
5'9" - 5'10" try in between scale 24 - 24.5
5'11" - 6' try in between scale 24.5 - 25.5
6'1" - 6'2" try in between scale 26 - 26.5
6'3" - 6'4" try in between scale 26.5 - 27.5
this is an excellent starting point. but your still not out of the woods. because were built like gorillas we have to slightly scale up the upper torso to accommodate the extra muscle size. for your height start with a 25.4 as a base.
I. chest shoulder brace and back : scale up to at least 26 but no more than a 10% increase in scale depending on how built you are.
II. bicep forearms abs cod thigh shin and boots: keep at the 25.4 scale. if you go up in scale they will be too long!!!!! just trust me ok.
at this point we transition into the test piece stage!
- simply assemble the foam pepakura templates you just cut out with scotch tape and try it on. make adjustments
-how the hell do i do this?
here you go. the wizard as kind enough to explain his tuning technology:
http://www.therpf.com/f24/howto-fine-tuning-pepakura-foam-parts-size-161530/
you can either do this the hightech way on the computer like the master does or the lowtech way i do it by doing it manually with scissors adding panels and taping them in. i also like making test pieces in cardboard it gives you a chance to "practice" how to assemble this thing, in addition to letting you check for size fit and mobility oh and also lets you trim/doctor up pieces to fit you better before you actually go to foam.
note: in general this works with the scales in the chart (ex: 25.4). however if the scales on your file are larger numers (ex. 425)
then we must go with plan b. cerealkiller put together this awesome tutorial that explains what we must do. watch it several times.
How To Scale Pepakura.mp4 - YouTube
to be continued...
