1. davekufner's Avatar
    Join Date
    Apr 2010
    Location
    Houston
    Message Count
    52
    May 2, 2010 - Help with project #1
    I made a cereal box Spartan Helmet and covered it with spackle. I need help to continue the project, where do I go from here? I'd like to strengthen it and also add details.
  2. irishamericanlad's Avatar
    Join Date
    Aug 2007
    Location
    San antonio, TX
    Message Count
    1,008
    May 2, 2010 - Re: Help with project #2
    u could lay the inside with thing fiberglass... or even the outside and then sand it and add the detail...
    good looking cereal box by the way
  3. davekufner's Avatar
    Join Date
    Apr 2010
    Location
    Houston
    Message Count
    52
    May 2, 2010 - Re: Help with project #3
    Is there a certain resin I should use? I tried doing some stuff with fiberglass cloth and some epoxy stuff and it was a disaster.
  4. DocTony's Avatar
    Join Date
    Aug 2007
    Message Count
    265
    May 2, 2010 - Re: Help with project #4
    Have you thought about bondo?
  5. davekufner's Avatar
    Join Date
    Apr 2010
    Location
    Houston
    Message Count
    52
    May 2, 2010 - Re: Help with project #5
    DocTony said: View Post
    That may have been what I used. It was thick and green and sucked to work with and dried hard as nails.
  6. Join Date
    Jan 2009
    Location
    New Hope, MN
    Message Count
    296
    May 3, 2010 - Re: Help with project #6
    fiberglassing, from what I understand, involves dipping a cloth into a resin and then putting on your project. Repeat until desired thickness/coverage is reached. Let dry, sand down and detail as needed.
    That's the very undetailed overview, heh.
    Bondo is typically a mixture of two chemicals that then harden. I haven't done too much with it, but yes I noticed it dries pretty fast and it does become very strong, which is why it's used to patch holes in cars. Someone told me that I may have had too much of the setter in my mix though if it dried as quickly as it did for me. But...yeah, bondo or fiberglass would work well to strengthen your project.
    Looks great though!
  7. davekufner's Avatar
    Join Date
    Apr 2010
    Location
    Houston
    Message Count
    52
    May 3, 2010 - Re: Help with project #7
    PadawanLearner said: View Post
    Looks great though!
    Thanks for the kudos. I'll look into the fiber glass/resin. I am thinking of doing a detail layer of air drying clay but need the under part hard so I'll probably coat the under part with fiber glass and do some sculpting on the outer shell.
Similar Threads
  1. 1:6 Vader Project & Digital Scan project
    Too Much Garlic, General Modeling
    Last Post: Aug 15, 2012, 7:06 PM
  2. Need help with a new project.
    BigJoe88, Replica Movie Props
    Last Post: Jul 9, 2012, 8:37 PM
  3. Replies: 2
    Last Post: Nov 14, 2011, 1:01 PM
  4. Project Arbiter: a film project my brother is helping with
    Trooper_trent, Entertainment and Movie Talk
    Last Post: Apr 5, 2010, 8:01 PM
  5. What new project needs doing?
    micdavis, Replica Movie Props
    Last Post: Mar 3, 2006, 8:05 AM
1 2 3 4 5 6 7 8 9 10 11
