Triton said:
To both Stealth, and CaptainMarvel. You two need to take a heaping tablespoon of your own advice. I never said anyone owed me ANYTHING. Nor did I come across that way, so take a chill pill.
You both act like I haven't spent hours wasting money trying every way people have mentioned to cut a 45 in foam. The truth is, if I didn't care, my suit would have been built by now. Trouble is, when I dry fit after a cut, and see that it isn't perfect, I'm not happy and I won't carry on with that piece. I'm glad that X method works for you. Truth is, it doesn't work for everyone, and a large contingent on these forums lately have been having the same problem. If I was competent in putting together a suit like some of you guys do ( which I've gave you your due kudos on, AND thanks for the videos you HAVE put out Stealth ) I'd put out my own video to help all the guys struggling. Unfortunately, I haven't found a method that works well enough for my standards.
If I ever do figure it out, I'll be sure to share as well.
