1. Formerly Spencer Etewaf's Avatar
    Join Date
    Jun 2010
    Message Count
    118
    Jul 20, 2010 - Green MMPR Power Ranger Pepakura WIP #1
    Hi All.
    I started this in late June, and have been working on it whenever there is a break in the hot weather. I thought I would post the progress pics as thumbnails as I go along, but if you guys prefer plain links, just let me know and I will change them to plain links.
    This is my first pepakura project. I found the file on Rangerprops.com and thought it would be a good way to start out. Just a single helmet. I've been reading about pepakura for years, but never found a model I thought I would commit to. Anywho, I printed out the files (yes, on red and yellow cardstock :P) and it was pretty intimidating at first. It took about four hours to cut out all the pieces with an exacto knife, and about ten hours to glue together. I popped in some DVDs and just went with it, ya know? I ended up with an interesting, Ronald McDonald kind of helmet.
    I didn't glue the back and front together completely because I wanted to see how it fit. It was about an inch too short. In the pics where I am wearing it, it looks like it fits alright, snug, but alright. I'm actually tipping my head back so my chin will fit. That was incredibly uncomfortable. On top of the height issue, the visor is also way too small.
    At that point I figured I would glue the back, and forget about the visor piece that came with the file. I started painting on layers of fiberglass resin to make the cardstock rigid. In the first photos, I think I had two or three complete layers on, in the later ones I kind of got sloppy when I wanted to go a tad thicker. As you can see, there is a chunk of washcloth that got stuck accidentally while it was drying. It must have fallen onto the model. There are also runs and whatnot, but I'm not concerned since it will have to be sanded and detailed anyway.
    So once it was rigid enough I made a line from one corner of the visor hole to another. I don't know why I used the string to make the guideline, I should have just used a Sharpie. It was like 8 AM though, so my brain wasn't going at full speed yet. Once it was cut, I used cardboard strips and evenly spaced the two halves by an inch. I think I ended up using about six strips total, and it was strong enough to begin working. I used strips of fiberglass matting about two inches wide and six or seven inches long and laid them on the inside over the seam and the visor hole. The cardboard strips and duct tape peeled off easily enough, leaving only a bit of cardboard stuck to the fresh resin.
    Personally, I think that one inch made all the difference. It doesn't look so 'squatty' anymore, and it opened up the visor quite a bit. It has a nice, sleek, elongated look to it now, closer to the helmet on the show.
    Next I will begin layering more matting on the inside of the helmet, giving it some bulk to work with in case I end up sanding through the layer of cardstock. I will be rough grit sanding it hopefully tomorrow as well as bondo filling and rough detail work.
    Overall, this style of helmet making is enjoyable. I attempted sculpting the helmet with clay once before, and it's still sitting in my basement. I have an easier time working with hard materials that can't easily be messed up, so if you are the same way, you may want to give pepakura a try.
    I will keep everyone updated on this as I go. Any comments or constructive criticisms would be appreciated.
    ~Spencer
  2. Join Date
    Jun 2010
    Message Count
    49
    Jul 20, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #2
    Nice job man! Keep it up.
    I am currently making Power Rangers/Super Sentai costume.
    Can't wait to see your helmet finish.
  3. Formerly Spencer Etewaf's Avatar
    Join Date
    Jun 2010
    Message Count
    118
    Jul 21, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #3
    Are you on Rangerprops? Your outfits look familiar.
  4. Don't ask me. Use Google. STEALTH's Avatar
    Join Date
    Jan 2010
    Location
    Canada
    Message Count
    2,421
    Jul 21, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #4
    cool project, good luck on it. I'm doing a Green Ranger costume too
  5. Join Date
    Jun 2010
    Message Count
    49
    Jul 21, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #5
    Spencer said: View Post
    Yes, I am on Rangerprops and Rangerboard.
  6. Formerly Spencer Etewaf's Avatar
    Join Date
    Jun 2010
    Message Count
    118
    Jul 21, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #6
    STEALTH said: View Post
    Are you doing the helmet yourself or have you purchased one?
  7. El Duderino's Avatar
    Join Date
    Aug 2007
    Location
    Ohio
    Message Count
    927
    Jul 22, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #7
    Great start to the helmet man, I've always wanted one.
  8. Formerly Spencer Etewaf's Avatar
    Join Date
    Jun 2010
    Message Count
    118
    Jul 30, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #8
    Hey guys, making a bit more progress since the weather has been cooler here lately.
    I sanded the exterior of the helmet and applied a decent coating of spot putty over the entire surface. It took about three days to fully dry. I then hand sanded with 60 grit sandpaper to knock the bulk of it off. It left me with a good idea of what needs to be fixed and filled. I also did a bit of slush casting on the inside with the fiberglass resin to thicken up the top, I'm going to be doing a lot of work up there.
    Yesterday I put a few coats of automotive primer on the helmet that way I could see it all in one uniform color. It was hard to determine what needed to be done with the color of the paper, the resin, and the bondo all mixing together with each other. As you can see, the left lower half needs to be thickened up a bit, as well as the upper right.
    In between all the repeated fillings and sandings I will begin cleaning up around the mouth and visor, and eventually move on to the detail work.
    This is going to be a long project, especially once I get to the details, but I think the finished product will be pretty cool. And, if I get burnt out on working on this helmet, I've got a Mandalorian pepakura I'm working on too. It'll be nice to switch between the two.
  9. superfunk's Avatar
    Join Date
    Sep 2010
    Location
    South Georgia
    Message Count
    24
    Dec 10, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #9
    Did this ever get finished? I would love to see updates on this!
  10. Join Date
    Dec 2010
    Message Count
    4
    Dec 10, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #10
    Me too! Im trying to make a Green Ranger Helmet myself. Is this helmet going to be wearable eventually or just a sculpture?
  11. superfunk's Avatar
    Join Date
    Sep 2010
    Location
    South Georgia
    Message Count
    24
    Dec 10, 2010 - Re: Green MMPR Power Ranger Pepakura WIP #11
    Joan, I finished a Green Ranger helmet about a month ago and I'd be glad to help ya if you need anything.
  12. Join Date
    Jun 2011
    Message Count
    Jun 17, 2011 - Re: Green MMPR Power Ranger Pepakura WIP #12
    @007halu......AWESOME costumes! Looks like exact replica of the show. Have you made them for purchase?
Similar Threads
  1. Go Green Ranger, Go! MMPR costume
    wholesomejoe, Replica Movie Costumes
    Last Post: Apr 12, 2013, 1:22 AM
  2. MMPR Power Rangers Black Ranger WIP
    MrPinski, Replica Movie Props
    Last Post: Apr 5, 2013, 1:49 PM
  3. MMPR Green ranger helmet pepakura question
    Last Post: Feb 22, 2013, 5:00 AM
  4. MMPR green ranger help
    bladud, Replica Movie Costumes
    Last Post: Jan 28, 2012, 5:20 PM
  5. MMPR Alien Ranger Power Coins Review
    tomahawknutter, Replica Movie Props
    Last Post: Aug 1, 2011, 2:41 PM
1 2 3 4 5 6 7 8 9 10 11
