This thread is awesome, Can't wait to see the Ultimate Iron man files.
Quick question JF could you explain how you know where to do 45 degree cuts and in which direction they should be in, cause ive cut out all of robostealths mark 4/6 files on paper and i want to start cutting my foam...
Looking forward to seeing your updates![]()
aaaaaaahhhhhhhhhhh that's a perfect explanation, thank you![]()
Thanks so much for putting this together. I'm going to try to build the Mark VII costume in time for Dragoncon. But, since this is the first time I have build something like this, I have a few questions.
1. Why are there two different versions of the back? Which one do you think is easier to build?
2. Is the thigh the right thigh (or the left thigh)? Do I have to turn all the pattern pieces upside down to make the opposite one? Same question for the shin.
3. On the other hand, the upper forearm looks symetric. So, can I just build 2 of these? Or do I have to flip the pattern over? Which parts do I have to flip over?
4. What thickness of foam do you use? The same stuff you used here? (6.5 mm PE foam) Do you think it is ok to use 2 or 3 mm foam? Because, I am not sure if I can get the right foam easily here.
I have another question. When you tape the paper together, there is a border of 0.5" or so on the edge of the paper. Do you cut off this edge before taping the papers together? Or, do you just tape the papers together naturally and ignore that stuff isn't printed on that part?
1- Back 05 is a one-piece built, back 06 is the version with separate flaps. I think you'll save time when making the first one.
2- it's the right leg. Yes you'll have to invert all of your pattern pieces.
3- It's true, arms looks symetric. Even so, in doubt, and since you still have to build a couple of them, you may want to invert pattern however. It costs nothing.
4- I always use 6.5mm, because of its fexibility, and its price ! Using 2 or 3mm, why not ? After all pepakura is basicaly designed for building with paper.
5- Sheets of paper have to overlap one another (or must be cut), in order to avoid blank margins. I usually cut of top and left margins of all sheets, and tape each one above right and bottom margins of the previous neighbour sheets.
Thanks so much for your quick response.
It looks like I will have to modify the pepakura files slightly because I am printing on Letter sized paper rather than A4. Well, unless I can find some A4 sized card stock at office depot or something.
I'm so excited to get started. But, I am still pretty concerned that I am not going to be able to do it, since I am not very crafty. But, I am going to give it a try. I think I will start with the Cod piece. Because if I get that done, but don't have time to complete everything else, I can wear that to the Anything But Clothes party.![]()
I just wanted to add that if you save the scraps from when you're cutting the angles you can use those scraps as spacers for when there's dips/crevices in the model that aren't there in the foam templates. I also used them to add size around some of the pieces that weren't quite big enough due to missing parts in the conversion to foam process.
JF you da man!
Im very slow at this but I have built a full arm so far will take some photos to share with you!
Thank you for all the sharing you do to help us with our builds!
Now avaible too :
Iron Man Ultimate JFcustomized FOAM pepakura files.
Credits for the 3d model : unknown (?)
Since I have "Letter" paper and not "A4", I believe that I can just go into the file->print paper and settings menu and change it to letter. Then, I can drag the parts around a little to save paper. I think this is the right way to do it.
But, if I just open the model and go to print it, it gives me a warning that the paper size of the model and the paper size of the printer don't match and asks if I want to resize it. I am guessing that this would be a "bad thing" and would make the parts the wrong size. Am I right about this?
finally ultimate ironman files!![]()
Now avaible on this 4th of july :
Robo3687's War Machine, JFcustomized FOAM files.
All included but heavy weapons. Helmet design by Stark1138.
your the best man thanks for all these
Thanks! What an incredible gift to the RPF Iron Man /War Machine Fans and builders!
You rock!
M
Thank you dude!!! You are AWESOME!!!!!!!
Noooo! Speed Building foam edits released after I've completed all my WM parts but the Gatling! Just kidding, great work with this JF. I tried your soda bottle pivot trick, but I used cheap water bottles, and they crinkled and melted when I tried to glue them in. Now I'm using heavy duty snaps from the craft store. $.50 a snap, and they're much thinner than bottle tops. Plus if you over stress them, they release instead of tearing the foam. Love your arc tip too. Thanks again for this great thread.
Wow! You are awesome. Those are some incredible seams and straight lines... master in the making there!
M
