Subscribe
  1. Capn_Jack_Savvy's Avatar
    Member Since
    Mar 2007
    From
    Tortuga
    Messages
    2,812
    Sep 15, 2010, 4:38 PM - Dying from dying a synthetic wig dark brown - HELP!! #1
    I am trying a technique of dying a costume wig that is blonde to a darker brown using 70% Isopropyl alcohol and FW Ink. Using a cup of alcohol and a few squirts of the ink, mixed in a spray bottle, and sprayed onto the wig. The alcohol evaporates but leaves the ink on the wig.
    I can definitely say I am not having much luck at this. The wig is turning a slight tint of brownish green and it does not seem to take on the color very well. I am trying a second coat tonight to see what happens.
    Anyone have experience in this technique and can recommend some hints?
    This is the wig. You can see the dark blonde on the back and this is the area I want to make even darker. The wig is a blend of Kanekalon synthetic hairs mixed with highlights of human hair.
  2. Renevo's Avatar
    Member Since
    Jun 2010
    From
    Connecticut
    Messages
    27
    Sep 15, 2010, 4:47 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #2
  3. mdb's Avatar
    Member Since
    Nov 2006
    From
    New Zealand
    Messages
    819
    Sep 15, 2010, 8:35 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #3
    Less alcohol more ink. I coloured my Leia plaits this way:
    mdb- costumes
    Scroll down and you'll see the colour of the original vs dyed.
    I think I wound up nearly 1:2 ink to alcohol.
    As a hint it will turn crispy so you'll want to follow up with a silicon spray treatment. It'll also act as a sealant for the colour.
  4. RPF Premium Member
    Member Since
    Apr 2005
    From
    Atlanta, GA
    Messages
    1,547
    Sep 15, 2010, 10:11 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #4
    I would also try the RIT dye method. You can dye a synthetic wig to a degree with RIT dye. After you dye it you can break it up with a brown sharpie. As real hair has various tones in it, the sharpie helps keep the synthetic from being too uniform.
  5. rollerboi's Avatar
    Member Since
    Sep 2000
    From
    Portland, OR
    Messages
    3,777
    Sep 15, 2010, 10:55 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #5
    Oh, I thought you got cancer from the chemicals involved in dyeing the wig, and were dying as a result.
  6. Member Since
    Jun 2010
    Messages
    306
    Sep 15, 2010, 11:07 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #6
    thats what i thought too! haha
  7. Member Since
    Aug 2010
    Messages
    113
    Sep 16, 2010, 2:00 AM - Re: Dying from dying a synthetic wig dark brown - HELP!! #7
    Rit dye.
  8. RPF Premium Member BornKilr's Avatar
    Member Since
    Apr 2010
    From
    North Carolina
    Messages
    734
    Sep 16, 2010, 3:36 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #8
    I tried concentrated RIT dye and USMC Boot Black dye on a synth wig, and they rubbed came off. I ended up going to a beauty shop that sells hair (for weaves and extensions, I guess). It says its real hair but I'm skeptical because of the price being so cheap. But it dyes and holds shape better than any synthetic does. I just cut it apart and epoxied it to a bald cap. Worked great.
  9. Capn_Jack_Savvy's Avatar
    Member Since
    Mar 2007
    From
    Tortuga
    Messages
    2,812
    Sep 16, 2010, 3:50 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #9
    Epic fail and a now a brunette. Soaked it overnight and the color changed maybe 1 level of brown. So it went from blond to brunette.
    Off to find a newer wig!
  10. Member Since
    Aug 2010
    Messages
    113
    Sep 16, 2010, 4:36 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #10
    The problem is you have a wig with both sythetic and real hair. You needed to dye the human hair first with a tradition hair dye, but not too dark and them use the rit dye method, probably mixing different collors together to get the proper depth and color. The stove top method, not forgetting to use salt and then always rinsing in a a vinegar and water solution to set the dye.
    I have never had to work with a mixed wig, but know rit dye is what is used by theatre hair designers with synthetic wigs. You can't get black from a blond wig but you can darken the blond to light brown or brighten with non traditional colors.
  11. Member Since
    Oct 1999
    From
    Marietta, GA
    Messages
    949
    Sep 18, 2010, 3:42 PM - Re: Dying from dying a synthetic wig dark brown - HELP!! #11
    I have a friend who swears by Sharpie markers for her anime wigs. She sits in front of the TV, grabs a small chunk of hair, and colors it.
  12. Member Since
    Mar 2014
    Messages
    2
    Mar 31, 2014, 2:28 AM - Re: Dying from dying a synthetic wig dark brown - HELP!! #12
    I used IZIWIG wig a few years ago when I shaved my head after mutilating it with chemicals and I really loved it. Wig will completely change your confidence. It's just so pretty when put on. You can't even tell how nice it is when it's in the bag. Just like the marker method, the color is permanent. The only way to remove the color is with rubbing alcohol, or cleaners which contain a large amount of alcohol or ammonia. (Some styling products which contain a lot of alcohol, like hairspray, may partially dissolve the color, but you can either rinse out or wipe off the excess.) The color will not rinse out in cold water, so it is safe to wash your wig.
Similar Threads
  1. Dying milliskin
    LaytonSpider, Marvel Costumes and Props
    Last Post: Sep 9, 2014, 5:34 AM
  2. Need help dying visors
    Ozymandius, Replica Props
    Last Post: Oct 17, 2012, 10:59 AM
  3. Help with fabric dying??
    GBrittelleJr, Replica Costumes
    Last Post: Jul 15, 2011, 9:12 AM
  4. Dying Fabric?
    n0x23, Replica Costumes
    Last Post: May 17, 2010, 10:57 AM
