Replica Props |
Screen Used Props |
Replica Costumes |
Sculpture and Makeup |
General Modeling |
Studio Scale Models |
Movie Discussion |
| Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models. |
#76 |
Re: TOS AMT/ERTL 18 inch Enterprise Custom Build
Definitely one of the nicest AMT builds that I've seen!
RPF Sponsors
#77 |
#78 |
#79 |
This is awesome! I used to build these as a kid and I never ever thought I would want to build another one... but now seeing this.... I gotta build another one
#80 | |
Quote:
#81 | |
Quote:
-or- TOTALLY COOL, DUDE!!!!!!!!!!!!!!!!!! I will will will WILL do one nearly as good!
#82 |
Chrisisall thanks! I look forward to seeing your progress on your ship. I know you can build it. The Enterprise is hailing, we need more starships!
#83 |
Great job on your 18" AMT Enterprise build! Just looked at your thread. I've been working on one myself and am curious as to how you drilled out the rectangular windows so cleanly? I have ultra fine drill bits - perfect for the round windows used with a Dremel. Thinking of drilling pilot holes and then manually filing out the rectangles.
#84 |
sweet build.
thanks for posting pics. |
#85 |
That turned out very nice! Cudos to you for putting in all the effort to make a splendid version of this iconic ship!
#86 |
Banned
Awesome build! I am just starting on mine. I hope it looks half that good when finished.
#87 | |
Quote:
#88 | |
Quote:
#89 |
You never get tired of seeing a Enterprise build beautiful job.
#90 |
I used the 18" kit to build the Copernicus from Star Trek Phase II. If I had remembered that I had a stack of 22" cuta-a-ways in storage, it would have been a different project.
I felt compelled to fix the inaccuracies in the kit before emplimenting the saucer and nacels to the Copernicus project. GT Graphics makes the most accurate parts for this kit anywhere and was nice enough to donate some of his products for this build. Thnx again Jeff! 1. Saucer profile - ERTL edge is too virticle, needs more angle 2. Saucer contour - remove the hard edge, fill 3 divits, and remove planetary dome bases lip 3. Bridge and B deck profile 1a. Here styreen is laminated to the side of the lower saucer to build a base to correct the angle. Copernicus :: Laminated Styreen picture by Tracy_Mann - Photobucket 1b. Results Copernicus :: Profile corrected picture by Tracy_Mann - Photobucket 2a. Filled the bottom saucer with cheap resin to give strength and support before grinding out the correct bottom profile - resin Copernicus :: Re-Enforcement picture by Tracy_Mann - Photobucket 2b. Using a dremel w/ drum sander to grind out the hard edge, then smoth with varing grits of sand paper to work down to the proper profile. Copernicus :: Filler picture by Tracy_Mann - Photobucket and finished... NO LIP Copernicus :: Corrected saucer picture by Tracy_Mann - Photobucket 3a. Fixing the bridge and B deck. removed cutting horizontaly, not down into the saucer. Copernicus :: Saucer and Plug picture by Tracy_Mann - Photobucket 3b. Styreen plug Copernicus :: Top on picture by Tracy_Mann - Photobucket 3c. Referance for correct B deck profile directly from Custom Replica's 5 1/2' Enterprise - Copernicus :: A/B Deck Comparison picture by Tracy_Mann - Photobucket - B deck filled with resin to allow gringing to shape Copernicus :: Before picture by Tracy_Mann - Photobucket Results - Copernicus :: After picture by Tracy_Mann - Photobucket 3d. Fully corrected with new bridge Copernicus :: A/B bridge complete picture by Tracy_Mann - Photobucket Mold and cast new master. Copernicus :: Bridge A/B deck ready for rubber picture by Tracy_Mann - Photobucket Copernicus finished with corrected Enteprise sections and JT Graphics parts a decals. Copernicus :: 8Completed1.jpg picture by Tracy_Mann - Photobucket Tracy |
#91 |
Needle files work like a charm on the rectangular windows. Also using a Dremel reamer bit to open up the window opening more and reducing the amount of filing needed. Looks nasty at first until the corners take shape. Most of the ones I've done so far extend just outside the window border, but when smoothed out and held against a worklight for backlighting, they look great!
#92 |
On my 18 incher I wanted the lit windows to look lit even when the power was off so I covered the clear resin with white decal film. The resin wasn't all that transparent anyway after I got done sanding the outside; more translucent. The decal film gave the windows a nice even glow when lit.
#93 |
Quote:
This is very nicely done! I like the lighted end caps. |
#94 |
