Should a battery powered LED get hot?
glunark
Been getting a bunch of cheap LEDs, usually ten of the same colour powered by two AA batteries.
Most have been fine, but one of the ones I tested today had a few dull ones not lit as well as the rest, when I touched them they felt a lot hotter than I would expect.
Obviously I don't want to be burying these inside a plastic model if they are going to be getting red hot.
Just wondered if any of you had experience with this sort of thing.
what kind of resistors do you have on them? How do you have them connected (series/parallel)?
What's the forward voltage the LED's can handle? Maybe too much voltage since they're getting 6v??
Is there a color change (other than the lack of brightness)?
I would toss the offending LED's as they could be flawed from the manufacturer.
They were bought as a unit, one battery box connected to a wire with ten lights on, its kind of academic now, as both the lights that were heating have failed completely, so taking both back for a refund.
These aren't the ones, but they are very similar.
fwiw, no they should NOT get hot. neither should the battery (unless you're charging it). I'd say Teddz is correct in that they were being over powered. the fact that they burnt out all but confirms it.
LEDs will generate some heat, however if the heat is enough to be considered "hot" you have thermal runaway and the LEDs will fail quickly.
Its best to design the circuit properly. If you google it you should be able to find several resources online to do so.
TazMan2000
I think designing circuit boards is a bit beyond my skills.
I consider joining two wires quite the achievement.
:lol Sure. Why reinvent the wheel? There are lighting kits out there for all kinds of models that are specifically made to each model, however, they can be modified to suit your own needs.
TazMan2000
You can even get LEDs with resistors built into them that are pretty much ready to go as soon as you get them. You think LEDs are bad try capacitors that explode if you aren't' paying attention to wiring them lol
My definition of an electric success if I dont let the smoke out. But I did learn about capaciters and leds. Yo gotta have them on the pos side or they last a nano second. Like WES said...they now sell them with capacitors already built in.
The easy way to an electronic success is to gut an existing toy and use its innards.
The important thing to remember is that the blue smoke is what makes the electronics work. If you let the smoke out, they won't work any more, and it's a real pain trying to put it back in again.
