It's been a backburner project for a while, but the construction and assembly of the Tintin moon rocket is complete. It's going to need a lot of primer and polishing before it's ready for that gloss red paintjob, but it's well on the way....
Wood filler over the whole fuselage to eliminate large dents and grain imperfections
Although I had already made one wing, I decided to make three more in one go because they would be much more consistent, rather than trying to copy the method for the first wing, which I couldn't for the life of me remember anyway
Rodger did the finer turning on the pods for me once I had roughed out the shape
Wooden dowel added as pins. I had colossal fitting issues with all of the pins, no matter how precise I tried to be, almost none of them fitted the way I wanted
The solution (seen here on wings #1 and #3) was to fill the pin holes with PVA, stick the dowels in the pod, slather the join on the wing side with wood filler. Then push the two halves together and cut/sand away the excess
I had better luck with the fuselage pins' fitting
I used the same squishy wood filler joinery to attach the wing assemblies. I'm genuinely surprised it holds so strongly
Photo of me working, courtesy of Henry, my 10 year old brother
It was THIIIIIIS big
I think I'm most surprised by the fact that it stands up straight....I really thought that there would be balance issues because of the variances and difficulties I had with the wing assemblies
PVA and primer will be the next job...and a lot of fine sanding.
I'm still undecided about whether to create the front cover for "Objectif Lune" or "On a Marche Sur La Lune"
