the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > MODELS > General Modeling
paint drying problem
Discussion on paint drying problem within the General Modeling forum, part of the MODELS category; Hi all, I'm hoping someone here will be able to
Reply
LinkBack Thread Tools
Old 12-14-2011, 03:44 AM   #1
Named after a sheep!
Nobby's Avatar
Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!Nobby has a reputation level greater than 1,000!
Your Props
Hi all,
I'm hoping someone here will be able to help solve a little problem for me.
I'm building a Galaxy Quest Nebulizer gun made from resin and there are small areas on the handle where the paint just doesn't seem to dry. It always remains tacky.
The rest of the pistol has accepted primer and top coat without a hitch.
I have sanded the handle back several times to bare resin and I cannot see any problems with uncured resin. It always appears 'dry'. I even tried sealing the resin with a thin layer of superglue. Again the surface seemed dry and ready to accept paint.
But guess what? After applying the primer and leaving it to dry, I still had small areas that remained tacky!
Anyone have any tips or ideas?
Nobby is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 12-14-2011, 06:06 AM   #2
Shat happens
robn1's Avatar
robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!robn1 has a reputation level greater than 1,000!
Re: paint drying problem
Is it the primer or the paint that isn't drying? And what paint are you using?
Uncured resin is my first thought, but if you've determined that's not it then I just don't know.
Maybe strip the handle and spray it with self etching primer.
robn1 is offline   Reply With Quote
Old 12-14-2011, 06:13 AM   #3
Nobby's Avatar
Your Props
Yeah, I first thought uncured resin too.
The problem was initially with the primer, which was Rust-oleum general purpose surface primer. But it was fine on the other parts.
This morning I have sanded back the tacky areas again and tried going with my top coat of Plastikote Metal Protekt in silver.
'So far' it seems to have cured the problem, but I'll update with progress later in the day if I can get any more coats on.
Old 12-14-2011, 12:15 PM   #4
Nobby's Avatar
Your Props
well I must say that I am baffled........
The top coats seem to be drying without a hint of tackyness!
Problem solved I guess
Old 12-14-2011, 12:41 PM   #5
BLACKULA727's Avatar
BLACKULA727 has not been awarded enough reputation to matter.
Is it urethane resin? I have found that if you don't mix the two parts adequately enough or even if the ratio of the two parts are off, that the resulting casting will leak an oil substance. It will apear dry, but once you coat it with primer the oil stuff present causes the paint to not cure. Good news is that it will eventually stop and you can then paint. bad news is, it can take a long time. Again this is only what I have personally noticed. So, take it for what its worth. I'm no prfessional at this, so there may be a better explanation.
Tony
BLACKULA727 is offline   Reply With Quote
Old 12-14-2011, 01:38 PM   #6
Nobby's Avatar
Your Props
yeah, that's what I was originally thinking.
but at the moment all seems well. Let's hope that my choice of topcoat paint has solved the problem...............
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Self drying/ adjusting jacket? Steamboat Spidey Replica Movie Props 5 04-07-2012 12:25 PM
Enamel paint problem GrenadeKing Replica Movie Props 8 07-14-2011 10:20 AM
Tacky Paint Problem, please help! Vandark General Modeling 13 12-03-2009 07:42 AM
paint and/or sealer problem dropshipbob Replica Movie Props 1 11-30-2009 01:47 PM
Bondo drying time? BlindSquirrel Replica Movie Props 7 01-23-2008 12:22 PM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
